| Author |
brommers Occasional Visitor
Posted: Sun Nov 14, 2004 5:15 pm Post subject: Rikaline 6010 GPS mouse |
We have just brought axim x5 which came with a rikaline 6010 and tomtom3. We though we were ready to go but when we put it in the car tomtom3 said GPS unreliable.
Tomtom tells us how to get there using the manual map but, when it comes to the GPS we can't pick anything up. Everything is pluged in and installed correctly.
We have noticed that there are alot of topics on the rikaline 6010. Can you please help us with any solutions to our problem?
Please be gentle as we are new to all this.
Many thanks |
| Back to top |
Brandon Occasional Visitor
Joined: Jun 14, 2004 Posts: 28 Location: Rochester, MN
Posted: Wed Nov 17, 2004 5:56 pm Post subject: |
When TT tells you that the GPS position is unreliable, what is the status of the green light on the Rikaline 6010?
If it is solid, then it does not have a valid GPS fix (hence the error).
If it is blinking, then it has a valid GPS fix. If this is the case, then I would suggest looking into your COM port settings, and make sure you have a baud rate of 4800 selected.
Good Luck,
Brandon |
| Back to top |
WGJK7 Occasional Visitor
Posted: Thu Nov 18, 2004 10:09 pm Post subject: DELL AXIM Rikaline |
| I have just bought the same del package and mine also came with the rikaline instead of the tomtom. I have exactly the same problem. Brommers if you got yours working please tell me how. |
| Back to top |
Cwill Occasional Visitor
Posted: Sat Jan 08, 2005 6:20 pm Post subject: rikaline connecting problem |
| I have same problem with 6010 and viewsonic v37 anyone hLep me! |
| Back to top |
ESS Occasional Visitor
Posted: Mon Feb 21, 2005 12:33 pm Post subject: Ipaq 3850 and Rikaline wired 6010 |
Hello, i have the same problem, i have a Compaq Ipaq 3850, and i don't get nay SAT signals on my pocket PC using the Rikaline 6010 Wired GPS, i used the WinFast Navigator to fix the problem, i get the Com Port 1, but when i select it in the GPS setting i get an eror meassage cannot open 'Com Port 1'
So if anybody has come solved the problem or has any tips please let me know.
Ess |
| Back to top |
DavidW Pocket GPS Moderator
Posted: Mon Feb 21, 2005 2:28 pm Post subject: |
Soft reset and try again. If you're still getting an error, something is keeping your COM1: port open, such as a keyboard driver. You need to find and disable the offending piece of software.
David |
| Back to top |
Pete2 Regular Visitor
Posted: Mon Feb 21, 2005 6:27 pm Post subject: |
try going to srart/settings/connections and selecting Irda (infrared) and if the box is ticked untick it (sometimes the infrared hogs com1).
Then start tomtom and go to GPS and select rikaline from drop down list along with com1.
When I first started using my pda/gps mine wouldn't work untill i unticked the receive all incoming beams box at the infrared connections setting.
I've had a Jornada 568 and a 928 and I'm currently using an xda2 all with the rikaline 6010 wired receiver.
Hope this helps  |
| Back to top |
redtomuk Occasional Visitor
Posted: Sat Apr 16, 2005 9:48 pm Post subject: |
| :D Just to sy that I found these posts really helpful and got my xda + rikaline 6010 working thanks to you lovely people Thanks |
| Back to top |
| Back to top |
