Pocket GPS World :: View topic - Memory-Map release MM Navigator 2004 OS version 4.4.2
PostPosted: Sun Apr 24, 2005 12:14 pm    Post subject: Memory-Map release MM Navigator 2004 OS version 4.4.2 Reply with quote
This week Memory-Map UK have released a minor upgrade to the Memory-Map Navigator from 4.4.0 to 4.4.2.
Primarily this adds in support for the Garmin 301 with heart rate profiles. I will have to get one and see how the old ticker works on a hill climb on my bike. Could be interesting 8O
The software is available on the Memory-Map site and can be dounloaded from within the Memory-Map Navigator application.
The full list of changes is as follows:
Memory-Map Release Changes wrote:
Added: Garmin Forerunner 301 support including Heart Rate profile
Added: Garmin GPSMap276c support including GPS altitude graph
Added: Maptech BSB5 chart format supported
Added: Keyboard shortcuts Ctrl-P (print), Ctrl-F (find), Ctrl-M (Map list), Ctrl-O (Overlay Props)
Added: Position format Lat, Long (+/-)
Added: Pocket PC Today Screen menu command
Added: Pocket PC Save As in overlay popup menus
Revised: Printing grids with colour & thickness
Revised: Speed & elevation profiles axes labels
Revised: Pocket PC use of hardware buttons
Revised: Pocket PC Mark Current Position command
Revised: Graphics for Pocket PC hi-res VGA screens
Revised: Pocket PC taskbar display - Always/With Toolbar/Never
Revised: Pocket PC Elevation and Nautical chart Depth Units to data popup
Revised: Pocket PC maps at cursor menu
Revised: Merged map filename based on name of map
Revised: Merged map does not delete original unmerged map
Fixed: GPX <link> tag error
Fixed: Overlay Props Ctrl-X/C/V shortcuts
Fixed: Edit of map datum offset in meters
Fixed: "Please enter a number" error in Simulator dialog
Fixed: Pocket PC OS Edition toolbar tooltips
Fixed: Nav data - DTE, TTE, ETA work with Goto Waypoint and Follow Route
xda
PostPosted: Mon Apr 25, 2005 9:58 am    Post subject: Reply with quote
Already using 4.4.0 looking on their update site it tells me I am already using the latest, no mention of 4.4.2
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
PostPosted: Mon Apr 25, 2005 10:20 am    Post subject: Reply with quote
Are you using the OS version or the European Version?
Did you use the Web->Check for updates option?
Mine found 4.4.2 and upgraded accordingly.
xda
PostPosted: Wed Apr 27, 2005 11:59 am    Post subject: Reply with quote
I have both, my mistake, I was running the OS version at the time as all of my UK maps are OS but the European ones use the European vesion as that won't load the uk OS ones from 2004.
Graham.
Nokia 925 Windows 8
richard2004
PostPosted: Thu Apr 28, 2005 4:50 pm    Post subject: Reply with quote
Using the new version on a Toshiba E800, a rather remarkable increase in visual detail can be observed.
The Greater London map is outstanding as is the MM 25000-1 of the lake District.
Good old memory map "Say's I to myself Say's I"
Now if only TomTom would follow suit and someone would produce a PDA with a 19" screen, life would be complete for me. Laughing :P
PostPosted: Sun May 01, 2005 9:33 pm    Post subject: Reply with quote
Well it might not be a PDA but I am running MM on my PC with two 19 inch screens! :P
xda
PostPosted: Mon May 02, 2005 2:00 pm    Post subject: Reply with quote
Try Microsoft Flight Simulator on three 21" monitors it's awesome, front,left and right views all at the same time.
Graham.
Nokia 925 Windows 8
chris_de_wet
PostPosted: Wed Jan 21, 2009 5:32 pm    Post subject: Reply with quote
Can anyone advise if this upgrade, or 4.4.3 are still available?
Many thanks ...
PostPosted: Wed Jan 21, 2009 6:25 pm    Post subject: Reply with quote
Its certainly no longer listed for download on the Memory Map web site see Here, the only version 4 exe file I have is v4.2.1 if thats any use to you? but why do you need such old Memory Map software - Mike
dales
PostPosted: Wed Jan 21, 2009 7:05 pm    Post subject: Reply with quote
Hi there,
Version 4.4.3 is still available on the Memory Map site.
It's here: http://www.memory-map.co.uk/dl_mm_OS_2004.htm
Dales
PostPosted: Wed Jan 21, 2009 7:50 pm    Post subject: Reply with quote
dales wrote:
Hi there,Version 4.4.3 is still available on the Memory Map site.
As you found that version have you any idea where 5.1.1 can be downloaded from as I want SmartPhone support without having to use the latest version 5 release - I used to have this version on the previous PC which expired around 12 months ago! - Mike
Edit to add - Once I opened my eyes I and looked properly I managed to find 5,1,3 which will do exactly what I want, it is 5,2,7 that I refuse to use due to reasons posted elsewhere - Mike
chris_de_wet
PostPosted: Wed Jan 21, 2009 9:18 pm    Post subject: Reply with quote
Why 4.4.3?
Because I am still happily using MM 2004 and have the maps for it ...
Just noticed I was running 4.2.4 and thought I'd update it.
Do I just run the .EXE file as it stands to update? I assume that will work and retain the licence.
dales
PostPosted: Sat Jan 24, 2009 6:32 pm    Post subject: Reply with quote
Yes, just running the EXE should do the job.
(But, to be safe, I would first of all be sure I had a note of my licence key number and also my original discs to go back to if necessary).
Dales.
24.034 (25 Mar 26)
