| Author |
soweezy Pocket GPS Verifier
Posted: Fri Jun 10, 2005 11:47 pm Post subject: |
ok, decided to give this a go using TomTomTim's instructions (page 9 of this thread)
I presume I've done everything correctly but get the error message:
Not a good DATA.CHK file. Please report your build version of the TomTom program to lutz@pocketgpsworld.com
I've tried naming the file 5158.data.chk 2852.data.chk 4109.data.chk and 4890.data.chk (that's my build version) and changed the number in the VB code accordingly but none of them seem to work
the .ogg files I've created are in 11025 Hz, 1600 Hz and 22050 Hz
I listed the 11025 and 22050 in the excel speadsheet
I've even tried downloading Ray's PPC data.chk file (file 4) and using that with 5158 and 4890
can anyone help ?
TTN 5.000 build 4890 (PPC not Go)
thanks _________________ SW
Garmin Zumo 390LM |
| Back to top |
Posted: Fri Jun 10, 2005 11:50 pm Post subject: |
BTW, forgot to add, Rays file works on my PPC... what build is it Ray ?
and can I use it as the base file instead of my original data.chk file ? _________________ SW
Garmin Zumo 390LM |
| Back to top |
rayflan Frequent Visitor
| Back to top |
Posted: Sat Jun 11, 2005 12:31 am Post subject: |
thanks Ray, that data.chk file you made works a treat
just realised I forgot to boost the volume on a couple but what the heck...
I've tried all sorts of combinations with TTTims Excel spreadsheet solution but had no luck, other than Excel refusing to shut down
in hindsight that might have been an indication something was happening but it was about 5 minutes after pressing the command button and there's nothing to indicate it's doing anything
I removed the module check lines but that didn't seem to make a difference, other than not give a warning...
oh the frustration.... I could crush a grape ! _________________ SW
Garmin Zumo 390LM |
| Back to top |
Posted: Sat Jun 11, 2005 2:27 pm Post subject: |
| Barsnake wrote: | You Guy's Have Been Busy With All The New Variation's
One Thing Is Can The Volume Be Increased ?
I Know This Might Be Old Ground |
Are you using ppc or the go? _________________ Ray
New Url www.tomtomsatnav.info
Visit my site |
| Back to top |
minesapint Occasional Visitor
Joined: 19/04/2003 22:42:21 Posts: 41 Location: United Kingdom bucks
Posted: Sat Jun 11, 2005 5:10 pm Post subject: how to find the file data.chk |
How do i find the file {data.chk}on a a ipaq h2210 with maps on sd
i have tried the explore button in Microsoft activesync.
thanks.
ipaq H2210
tomtom 5
clip-on bluetooth |
| Back to top |
Posted: Sat Jun 11, 2005 5:30 pm Post subject: Re: how to find the file data.chk |
| minesapint wrote: | How do i find the file {data.chk}on a a ipaq h2210 with maps on sd
thanks.
ipaq H2210
tomtom 5
clip-on bluetooth |
Using activesync do you have a folder/icon called pocket pc or system folder?
Inside pocket pc find folder program files then you should be able to find the folder for ttn5, not sure what it will be called.
Only guessing have no experience of ttn5 and very little experience of ppc's. _________________ Ray
Visit my site |
| Back to top |
Posted: Sat Jun 11, 2005 5:34 pm Post subject: |
it should be in the Progam Files / Navigator folder _________________ SW
Garmin Zumo 390LM |
| Back to top |
Posted: Sat Jun 11, 2005 6:24 pm Post subject: |
O well i wil have to keep looking as i can not find this file using explore in active sync. double click my pocket pc then, program files still no {data.chk} file.
thanks anyway.  |
| Back to top |
Posted: Sat Jun 11, 2005 7:02 pm Post subject: |
in progam files is there a folder called Navigator ?
that's where it should be  _________________ SW
Garmin Zumo 390LM |
| Back to top |
Posted: Sat Jun 11, 2005 7:31 pm Post subject: |
yes there is
double click the file navigator, it comes up with 3 files.
data, navigator.cfg, tomtom navigator,
thanks anyway. |
| Back to top |
Posted: Sat Jun 11, 2005 8:15 pm Post subject: |
mine has the same files, except data is called data.chk
maybe your's just isn't showing the file extension ?
try copying the data.chk file into that folder, if a warning comes up asking if you want to replace the current file then it's almost certainly the data.chk file
alternatively, try renaming the data file to dataold then copy data.chk to the folder and see what happens _________________ SW
Garmin Zumo 390LM |
| Back to top |
Posted: Sat Jun 11, 2005 8:41 pm Post subject: |
THANKS got it to work in the end.
that's what it was my file was just called data
no {chk} at the end of it
thanks again. |
| Back to top |
Barsnake Lifetime Member
Joined: Feb 13, 2005 Posts: 50 Location: Snottingham UK
Posted: Sun Jun 12, 2005 8:28 pm Post subject: |
| rayflan wrote: | | Barsnake wrote: | You Guy's Have Been Busy With All The New Variation's
Are you using ppc or the go? |
The Classic Go |
| Back to top |
Posted: Mon Jun 13, 2005 1:30 am Post subject: |
OMG... it worked !!!
huge huge thanks to Lutz for the code and TomTomTim for the "quick and dirty" solution
have a pint on me...
b****cks...
knew it couldn't last... just tried the new data.chk file and TT wouldn't start up (well the hands appear in the bottom right corner but that's it)
if I clicked on the little hands the GPS status page comes up (eventually), but in german and locks anyway, I changed back to the original file and it was fine again... grrrrr  _________________ SW
Garmin Zumo 390LM |
| Back to top |
| Back to top |
