| Author |
RichardM Lifetime Member
Posted: Mon Jun 13, 2005 11:00 pm Post subject: Camera database |
Hello all I am new to this forum but would appreciate some help. I have a TomTom Go and want to install the speed camera database. I have downloaded this and unzipped it but am not sure which files to transfer despite reading various forum comments.
I have the following
alternative bmp files
csv files
ov2bmp files
single file version
speed zoned
wav files
xls files
plus some others like readme, licence,etc
Any help would be great. Thanks in anticipation |
| Back to top |
PJEvans Regular Visitor
Posted: Mon Jun 13, 2005 11:42 pm Post subject: |
You need to use the ov2 and bmp files
Open the folder marked ov2bmp and transfer all the files into your GB map folder
Then do the same with the speed zoned file. Open the Gatso folder and transfer all the contents then do the same with the mobile folder.
The ov2 files are the infomation and the bmp files are the icons that go with then.
Remember you have to transfer the files in the folders, just transfering the folders won't work |
| Back to top |
sgould Frequent Visitor
Posted: Mon Jun 13, 2005 11:46 pm Post subject: |
When you do this you will end up with all the cameras in twice.
Don't panic. Set the speed zoned ones to shorter distances than the "all in one" set and you will have two warnings for each camera. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
| Back to top |
Posted: Tue Jun 14, 2005 12:15 am Post subject: |
| sgould wrote: | When you do this you will end up with all the cameras in twice.
Richard M sorry about that hopefully you haven't got around to doing it yet
sgould
Now I know why I'm getting the double warnings. I read on another thread that you should have 17 files. If you use the Gatso and Mobile files that makes 14. Are the other 3 the Specs Temp and Redlight from the ov2bmp folder  |
| Back to top |
Posted: Tue Jun 14, 2005 12:16 am Post subject: |
Thanks for the quick replies. I presume I use the ov2 files in both the gatso and speed zoned files and ignore the csv files in these two folders?
I've already made the mistake of transferring folders and not files so I will have to sort that out!
If I use a new SD card because the original is too small do I have to format it first and is it OK to use a card reader instead of TTG for all the file transfers?
Thanks for the help |
| Back to top |
Posted: Tue Jun 14, 2005 11:37 am Post subject: |
| RichardM wrote: | | Thanks for the quick replies. I presume I use the ov2 files in both the gatso and speed zoned files and ignore the csv files in these two folders? |
That correct
| RichardM wrote: |
If I use a new SD card because the original is too small do I have to format it first and is it OK to use a card reader instead of TTG for all the file transfers? |
I always format the card prior to use. Some people use a card reader to do the transfers, but I just do it straight to the TTG (probably because I haven't got a card reader ) |
| Back to top |
Posted: Tue Jun 14, 2005 2:46 pm Post subject: |
sgould
sgould
Now you've got me confused. Am I supposed to do as in the original answer or not, as I don't want to duplicate the sites.
Thanks |
| Back to top |
Posted: Tue Jun 14, 2005 3:10 pm Post subject: |
The "single file" version gives you one .ov2 and one .bmp file. This will include all the cameras but not distinguish between the type or speed. It is best used if you are short of space for PoIs. There is a max of 40 new groups.
The "ov2 bmp" folder gives all the cameras broken down by type. Again, if speed of camera doesn't bother you, this is the one to use.
The "speed zoned" set include all the gatsos and mobile sites only, but subdivided into speed limits plus a "tba" set where the speed limit has not yet been reported. These sets replace the gatso and mobile files in the "ov2 bmp" folder. So if you load these, you will need to load the redlight, specs and temp files from the "ov2 bmp" set as well.
The continental set only work on the European maps, incl. the Major roads of Europe. _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
| Back to top |
Posted: Tue Jun 14, 2005 3:17 pm Post subject: |
This is my set:
pocketgps_uk_mobile_20.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_30.ov2
pocketgps_uk_temp.ov2
pocketgps_uk_specs.ov2
pocketgps_uk_redlight.ov2
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_50.ov2
Plus the matching .bmp files _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Tue Jun 14, 2005 6:24 pm Post subject: |
That's exactly right!
It IS confusing how they are packaged in the download, but I think it is because other systems cannot handle more than one set of POIs at a time.
The next thing to confuse you, are all your options for the .bmp files. When you've installed it all, you'll find that you have little speed limit signs for the fixed Gatsos where the speed is known, and a picture of a camera for the others. The mobile camera sites however, only have a single picture of a camera on a tripod.
If that's OK for you then fine, but if you want a little extra, that's where the idea of alternative bmp files comes in. There are a couple of folders of different icons bundled with the database, one of which ("Khan") does have zoned mobiles.
However, if I may repeat myself from another post, in the end I made my own to match the ordinary Gatso ones (and did a question mark one for both "t.b.a." cameras while I was at it).
They look like this, and were easy to do in a paint package on the P.C.
Don't try to use the actual files above - they are .jpgs, I couldn't get the .bmps to show up on the forum) but if anyone wants them, I sent the full set to PocketGPS when I submitted a couple of camera updates, so MAYBE they will get distributed with the next update (Fame at last? :D).
Otherwise if anyone wants them I've put my full set (i.e. every one I use including the default redlight, specs etc.) up on the web here
Feel free to use them, just remove the two .jpgs that I used above. |
| Back to top |
Posted: Tue Jun 14, 2005 6:28 pm Post subject: |
And then, Richard, you can embark on the madness that is "speed-zoned speech alerts"... which I haven't managed to sort out myself yet! (lots of different variations of files, depending on what software version you've got ) |
| Back to top |
Posted: Tue Jun 14, 2005 7:45 pm Post subject: |
I'm glad I'm not the only one confused by all the different files. It looks like I'll have to spend some time sorting it all out! All I really want is a beep or something when any camera is coming up and try and keep it simple at first
thanks for all the help |
| Back to top |
nich Regular Visitor
Posted: Tue Jun 14, 2005 9:47 pm Post subject: |
| How often is the camera data base updated? and do you have to start from scrach every time? |
| Back to top |
Jim-Bob Regular Visitor
Joined: Apr 28, 2005 Posts: 125 Location: Yorkshire, England!
Posted: Tue Jun 14, 2005 10:26 pm Post subject: |
| RichardM wrote: | I'm glad I'm not the only one confused by all the different files. It looks like I'll have to spend some time sorting it all out! All I really want is a beep or something when any camera is coming up and try and keep it simple at first
There is nothing to say you have to change the data.chk file stick to the origonal and you can just have a beep when a camera comes up. There is also nothing to say you have to have all the diferent files. there is a file with all the speed cameras in it this won't tell you what type of camera or the speed limit.
| nich wrote: | | How often is the camera data base updated? and do you have to start from scrach every time? |
The database is usaly updated every month all you have to do is delete the .ov2 files and add the new ones you download the warnings will stay set. |
| Back to top |
Posted: Tue Jun 14, 2005 10:27 pm Post subject: |
| I believe that it's updated every month. All you have to do to update is download the zip file then transfer the .ov2 files into the map folder. It will say file alreday exists do you want to replace click yes and it's done |
| Back to top |
| Back to top |
