| View previous topic :: View next topic   |
		| Author |
		Boxbrownie Lifetime Member
  Joined: 22/03/2003 16:18:25 Posts: 128 Location: United Kingdom
				 Posted: Sun Sep 14, 2003 8:04 am    Post subject: How do I exit TT2 GPS???? |
Seems a silly question but, when I close TT2 the small GPS icon is running in the task bar, but there seems to be no way to actually exit this piece of software short of a soft reboot!
How do I exit the programme completely?
Best regards  David |
		| Back to top |
		Dave Frequent Visitor
				What you need to do is use iTask if you're running an iPAQ or something like WisBar or Icbar as these will not only skin the title bar, but also give you a program manager allowing to close programs properly.  Pocket PC 2002 is designed to keep applications still running in background unlike PC's and this can become very annoying when you actually want to close an application.
Check out Icbar at www.ictinus.com/icbar |
		| Back to top |
		Chris Occasional Visitor
  Joined: 19/08/2002 23:27:00 Posts: 12 Location: United Kingdom
How are you closing down TTN2?
If you just click on the X at the top of the screen, the program will still be running in memory and the GPS icon remains on the task bar.
But if you close down TTN from "MAP Screen" bottom left click File>Exit it should remove TTN2 from memory and the GPS icon should disappear.
Chris
		| Back to top |
				Hi Chris,
Yep thats it, I assumed the "X" was for shutting down just as in PC programmes, thanks for that.
		| Back to top |
		timtim Occasional Visitor
  Joined: 23/05/2003 15:15:15 Posts: 47 Location: Staffordshire
				If you install something like Omega one s Battery Barthe 'X'button has two functions: Tap to send application to the background, or tap and hold to fully close the application. _________________ It seems I don't know anything after all |
		| Back to top |
		Houmark Occasional Visitor
  Joined: 09/04/2003 23:43:16 Posts: 4 Location: Denmark
				David, go to the map mode, click File -> Exit - which will make your TTN2 exit completely...
*** UPDATE ****
And Chris did already tell you that - sorry for not seeing that   |
		| Back to top |
				 Posted: Today    Post subject: Pocket GPS Advertising |
  Have you considered  making a donation towards website running costs?. Or you could disable your ad-blocker for this site. We think you’ll find our adverts are not overbearing!
		| Back to top |
