Pocket GPS World :: View topic - Does TT5 Work with CF Gps Reciever
Goto page 1, 2, 3  Next
petchy
PostPosted: Sun Jul 10, 2005 4:12 pm    Post subject: Does TT5 Work with CF Gps Reciever Reply with quote
Can someone confirm please before i buy a CF reader?
minion
PostPosted: Sun Jul 10, 2005 6:01 pm    Post subject: Reply with quote
i just bought one and i can't get it to lock onto satellites, after hours of exposure to the naked sky and using NMEA 0183@4800 baud settings with CF GENERIC CARD selected.
maybe someone else can confirm for sure?
i recommend you buy a wired one or bluetooth.
ps. i bought this one on ebay (from an infamous seller i now know) http://www.iternet.com.tw/cf-gps/ps2200-f.htm
bjellys
PostPosted: Sun Jul 10, 2005 8:22 pm    Post subject: CF receiver Reply with quote
Yes I recently installed Tomtom 5 for my friend when she updated to tt5
she has a HP2210 with a globestat cf receiver which works perfectly.It did take about 45 mins to lock on the first time (because she had not used it for a few weeks) but with daily use it's been working 100%.
scoobydoo711
PostPosted: Mon Jul 11, 2005 10:06 am    Post subject: Reply with quote
TT5 worked fine with my Globalsat BC-307.
Scooby Smile
intertoto
PostPosted: Mon Jul 11, 2005 10:53 am    Post subject: Reply with quote
We have tested TomTom Navigator 5 with all our Compact Flash GPS receivers and they have all worked fine. We got the best performance out of our SysOnChip CF Plus II (www.globalpositioningsystems.co.uk/p687).
One thing to note it is better to close TomTom before inserting your CF receiver.
To set-up simply tap on the screen to bring up the Main Menu, tap change preferences, then next until you see Show GPS status, then select Configure.
Cycle through to Other Cable NMEA GPS and tap select, select GPS baud rate as 4800 then tap done. The top option on the next page should be your CF GPS receiver. On ours it stated 'SysOnChip Sys_On_G', you may see CF Card Generic or similar.
Hope this helps
Jonathan Bowes
Product Manager
petchy
PostPosted: Mon Jul 11, 2005 1:42 pm    Post subject: Reply with quote
Thats super thanks for your help...now just to buy a CF reciever....
Jonathan, did you get the same results for the SysOnChip CF Plus II and the SysOnChip CF Plus II with 256MB Ram.
I am about to make a purchase of one of the above and cannot decide which one. I currently have a 512MB SD Ram stick but thought for the extra £16.50 i may as well get the SysOnChip CF Plus II 256MB instead of the one without (normal SysOnChip CF Plus II receiver would cost £102 inc del and one with 256mb ram 119).
I have heard and read that the "combi" reciever+memory , users have had problems with the PDA not reading the memory and driver errors etc.
Hope you can help,
JP
intertoto
PostPosted: Thu Jul 14, 2005 1:14 pm    Post subject: Reply with quote
Hi Petchy,
Once the drivers are all installed correctly the CF Plus II with Memory product operates the same as the CF without memory.
We have had TomTom 5 running successfully on a CF Plus II with 256 Memory without any problems. It was a little niggly sorting out the drivers though. Perseverance is the word!!
The standard CF Plus II will be easier to set-up
Hope this helps
Jonathan Bowes
Product Manager
YooNoo Ltd
countyboy239
PostPosted: Fri Jul 22, 2005 5:57 pm    Post subject: Reply with quote
My syson chip workrf perfectly well with Tomtom 3...Have tried everything with TT5 and whils it is receiving and I have followed the instructions above all I get is "no gps device" What am I doing wrong ?
countyboy239
PostPosted: Sun Jul 24, 2005 6:59 pm    Post subject: TT5 Syson Chip Reply with quote
Just to answer my own question. If you are having problems download the patch from TomToms website. This seemed to sort it out and Jonathons instructions then worked fine
petchy
PostPosted: Tue Jul 26, 2005 9:28 am    Post subject: Reply with quote
Hi countyboy239,
What patch was it that you downloaded? and could you provide a link?
ta
petchy
PostPosted: Fri Jul 29, 2005 11:05 am    Post subject: Reply with quote
Is this the tomtom navigator 5 patch?
KW
PostPosted: Sat Jul 30, 2005 8:59 am    Post subject: Reply with quote
I can tell as fact and based upon hands-on experience, the CF Haicom 302 and 303's (be it with Sirf-II or with the cheaper Evermore) both with perfectly using either Loox600 (not on compatibility list) and Acer N10 (not on compatibility list either) and TT5. This includes the older non-foldable models too.
Also, the Sirf-II's from Rikaline have no problems working on a TT5+Acer N10 combo.
countyboy239
PostPosted: Sat Jul 30, 2005 12:31 pm    Post subject: Reply with quote
Yes it is the TT5 navigator patch
http://www.tomtom.com/support/rightnow.php?Page=http://62.250.17.58/cgi-bin/uk.cfg/php/enduser/std_adp.php?p_faqid=3361
neillyb
PostPosted: Sat Jul 30, 2005 2:17 pm    Post subject: Reply with quote
Ive just loaded TT5 onto my Dell Axim X5 with a Rikaline 6021 X6 CF GPS card and am still struggling to get a complete GPS signal.
I downloaded the Patch from the TomTom site that states it to help with problems of third party GPS devices but still fail to get the thing to work - Im getting 9 satellite signals all bouncing around the marker line or just below and have had it pointing to the sky for hours - The neighbours must think ive gone bonkers.
Ive got it set at 4800 baud rate with a GP Leadtek (top of the list) setting
Anything else I can try before throwing the damn thing in the bin. Embarassed
alix776
PostPosted: Sat Jul 30, 2005 4:58 pm    Post subject: Reply with quote
if the lines go blue then you have a lock singal strenght will vairy
device Lumia 950 xl
Page 1 of 3
24.041 (01 Apr 26)
