| Author |
ScaredyCat Regular Visitor
Posted: Thu Aug 04, 2005 2:29 pm Post subject: |
| entwood wrote: | @ Scaredycat
Hi .. I'm very new to this so please forgive any misdemeanors .....
Fantastic set of stuff for the tomtom700 ...well impressed .. thanks ...
I do have one small query ... using the "navigate to lat/lon" beta from the link on the first page ... I've sussed that - means west, + means east and that default (no sign) gives eastings... so I can enter an accurate easting eg 1.21.45, however if I want an westing the most I can input is -1.21.5 and for northings the same limit applies 51.23.6 .. |
Ok, here's your problem. At the moment you can only enter coodinates like
52.5599
-4.6545
etc...
SC |
| Back to top |
Posted: Thu Aug 04, 2005 2:32 pm Post subject: |
| CaptainBoo wrote: |
For ScaredyCat
In the UK current time is UTC/GMT +1, with the timezone set to +1 the 'What Time is it' app shows the correct time but the clock on the status bar shows UTC/GMT and consequently arrival time for a route is also UTC/GMT. Is there any way of changing this - So status bar time is also same as 'What Time'? |
Odd works fine here, even if I set it as +1 (i'm in +2) - are you sure you don;t touch the built in clock application? If you do it *looks* like the ttg app ignores the real clock...
| CaptainBoo wrote: |
Also if you powerdown the Go with the 'What Time' App running it appears to freeze on next startup - I presume this pobably due to the app running at the time but would it be possible to reduce length of time it displays the time/date for? Only a minor niggle if at all but they are great apps. and otherwise work flawlessly on my TTG500. Great work. :D |
Will look at this, is a couple of seconds enough to see the time?
SC |
| Back to top |
ncsl Occasional Visitor
Posted: Sat Aug 06, 2005 10:46 am Post subject: Nav 5 for PDA |
Is it possible to save Lat/Lon from TT 5 on my HP Ipaq PDA?
I sue the TT on a boat on the rivers and would like to plot / save position every -say - 20 mins?
Then when I return I can use these waypoints / POI to find my way back?
Any help would be great. Thanks |
| Back to top |
riddler Regular Visitor
Posted: Sat Aug 06, 2005 10:58 pm Post subject: 5.202 can,t get this application to work.help! |
Hi, i have now been trying to get this application to work for a week now installing ,uninstalling all to no avail.I can,t be doing that much wrong because all the icons are in the menu system.I,ve done exactly what it says on the tin but the go just locks up when i press the new camera button and i have to pull out the sd card out.I,ve downloaded 5.202 and put it in the root of the go,plus put the other files where it says you should put them.any help will be appreciated.
go 300/5.200 |
| Back to top |
Jim-Bob Regular Visitor
Joined: Apr 28, 2005 Posts: 125 Location: Yorkshire, England!
Posted: Sat Aug 06, 2005 11:36 pm Post subject: Re: 5.202 can,t get this application to work.help! |
| riddler wrote: | | go 300/5.200 |
Well you say you downloaded V5.202 but unless you install it it wont do any good.
Perhaps you mean go 300/5.202
Otherwise install it. _________________ Jim-Bob
Clasic Go
Version 5.202 (5302/050715)
Great-Britain-Map v390 |
| Back to top |
Posted: Sat Aug 06, 2005 11:54 pm Post subject: |
| It says put in the root of the go,which is what i,ve done, allthough it didn,t give me the option to overwrite the current files,so maybe i,ve done it wrong.Not sure what you mean. |
| Back to top |
Posted: Sun Aug 07, 2005 12:03 am Post subject: Re: Nav 5 for PDA |
| ncsl wrote: | Is it possible to save Lat/Lon from TT 5 on my HP Ipaq PDA?
Have a look at this
Not tryed it myself bul looks kinda like what you want.
Not sure how you will manage on rivers tho the go kinda likes to snap to roads.
Alternatiley create yourown itinerary and add waypoints as points on the map where you center on position and make sure it shows you on the river. _________________ Jim-Bob
Clasic Go
| Back to top |
Posted: Sun Aug 07, 2005 12:06 am Post subject: |
| riddler wrote: | | It says put in the root of the go,which is what i,ve done, allthough it didn,t give me the option to overwrite the current files,so maybe i,ve done it wrong.Not sure what you mean. |
Did you put the files inside the the folder called ttgoapp-5.202 into the root or just the folder. you need to put the files in. _________________ Jim-Bob
Clasic Go
| Back to top |
Posted: Sun Aug 07, 2005 10:10 am Post subject: |
| Thanks for your help bob i just put the folder in as whole,didn,t realise i had to take the files out first.Does this also apply to the other folders which you have to put in the root as well,you have to take the files out first!You Can tell i,m from Barnsley. |
| Back to top |
Posted: Sun Aug 07, 2005 11:55 am Post subject: |
Bob think i,m getting there now just a couple of probs if anyone can help us out the quick add cam icon is on page 4,i,d like it on page 1.
plus my voices have now changed back for the speed cam warnings to the standard bells & whistles.
tom tom go 300/version 5.202.thanks again! |
| Back to top |
Posted: Sun Aug 07, 2005 1:59 pm Post subject: |
| riddler wrote: | Bob think i,m getting there now just a couple of probs if anyone can help us out the quick add cam icon is on page 4,i,d like it on page 1.
If you were a good boy and backed up your Go before doing this then just copy the file data.chk from your backup (assuming it was a 5.200 system not a 4.21)
Loot at the FAQ for positioning icons. Basically the order (date/time) that the .cap files were copied to the Go relate to the position (TASK_SDKx) number.
SC |
| Back to top |
Posted: Sun Aug 07, 2005 2:06 pm Post subject: |
Have a look at this and this _________________ Jim-Bob
Clasic Go
| Back to top |
Posted: Sun Aug 07, 2005 2:51 pm Post subject: |
| sorry boys that sort of stuff is way above my head,i struggle to use a computer as it is,if i put the original data chk file back will it not affect the operation of the stuff i,ve just added. |
| Back to top |
Posted: Sun Aug 07, 2005 3:08 pm Post subject: |
Try putting the origonal data.chk file back. It cant harm. worst that will happen is they wont work. In that case put the new one back.
Go into the GOs root then into the SdkRegistry then rename the file called tomtom.mnu or called tomtom if you cant see the extention to something like tomtom1.mnu
Now turn on the go and goto menu page 4 and report back the order the icons apear in order from top left to top right then from botom left to botom right. _________________ Jim-Bob
Clasic Go
| Back to top |
Posted: Sun Aug 07, 2005 3:10 pm Post subject: |
forgot to say. Do the same on page five aswell if you have a page 5. _________________ Jim-Bob
Clasic Go
| Back to top |
| Back to top |
