| Author |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Mon Sep 12, 2005 3:30 pm Post subject: |
| just got my i3..but cant decide where to put it..on the windscreen or use the 'sticky pad' to put it on the dash...where's yours been put? |
| Back to top |
blackrat62 Occasional Visitor
Posted: Mon Sep 12, 2005 5:04 pm Post subject: i3 |
Had mine a week now - I like the camera warning even if it does get a bit intrusive with all that 'bonging' when the camera is on the opposite carriageway.
I have had three 'lock ups', and today two 'switch offs'.
I have also found that 2300mAh batteries only last 3 hours before the i3 reports a low battery (note: power switch off was on the brand new alkaline ones).
That said - I am happy with it, it is small and easy to use AND very good value.
Just hope that Garmin sort out the locking up etc (which they seem to be working on) as the temptation is to do it on the move. |
| Back to top |
overide Occasional Visitor
Posted: Mon Sep 12, 2005 5:12 pm Post subject: i3 Lockups |
Can everyone who is having problems with this unit, especially lockups to register your problem at http://www.garmin.com/contactUs/techSupport.jsp
Hopefully, Garmin will then realise how big a problem it is.
Thanks |
| Back to top |
RichardCr Occasional Visitor
Posted: Mon Sep 12, 2005 6:56 pm Post subject: Re: i3 Lockups |
Here's the latest news from Garmin on this subject (lock ups)
| Quote: | Hello Richard,
Thank you for the information.
Our engineers have implemented a software update and are just finishing it off. It will be released shortly.
Thank you.
If you have any further questions please let me know.
Customer Support
Sales Support Associate
Garmin (Europe) Ltd
| Back to top |
Posted: Mon Sep 12, 2005 9:29 pm Post subject: |
| Thanks for the update. |
| Back to top |
swampmonster Occasional Visitor
Posted: Mon Sep 12, 2005 9:42 pm Post subject: |
| Skippy wrote: | | swampmonster wrote: | | On the 170 mile trip it also sent me on some very minor roads and although we got there in the end it was pretty hairy, single track roads etc. My normal route of sticking to major roads although longer in distance was definately much safer and quicker. |
Yes, they can give you some interesting routes at times. ;)
Do you have the routing options set to Quickest or Shortest? Quickest is probably the best one to use. |
Thanks for the reply - It was set to Quickest though!! |
| Back to top |
Posted: Mon Sep 12, 2005 9:50 pm Post subject: Re: i3 |
| blackrat62 wrote: | Had mine a week now - I like the camera warning even if it does get a bit intrusive with all that 'bonging' when the camera is on the opposite carriageway.
I have had three 'lock ups', and today two 'switch offs'. |
I'd love to hear the bonging noise!! How do you set it up so you get the audible warning as I only seem to get bonging on approaching changes in direction.
I've had two more lock ups today within five minutes of setting out while running off the cigar lighter with alkeline batteries in the i3, however I took the alkeline batteries out ran it just off the cigar lighter and didn't get any more lock ups. Don't ask me why though!! |
| Back to top |
Posted: Tue Sep 13, 2005 3:03 pm Post subject: Audible warning of speed cameras |
| I just downloaded the files as discussed on this forum - it did the rest for me automatically. |
| Back to top |
garyrk Occasional Visitor
Posted: Tue Sep 13, 2005 11:18 pm Post subject: More on I3's |
Have had a unit since last week and been in discussion with Maplin, Garmin UK & Garmin US over maps & hangups.
Hangups happen far too often requiring disconnection of external power and batteries. Managed to get hard reset key sequence from Garmin. Works, keeps downloaded POI but seems to delete other user prefences.
Basically great unit compared to opposition. Have loaded loads of POI (such as speed camera's, Congestion Charge, local motor deals and our business sites) by following instructions on this site and using link to Garmin's POI loader and POIEDIT. Bitmaps work and seem fine.
Have installed external arieal as I have a solar reflecting windscreen. waiting to see if improves reliability
Have obtained compatiable addtional power cable (Blackberry 6510/7100) via mailorder
Also obtained 256mb transflash and SD reader and intend to play around with card to backup etc.
Recieved interesting response from Garmin UK - Maplins product packing was put together to keep cost down by not including other map or CD. Said I would have to wait for the release of other transflash cards to get other EU countries.
Posed a similar question to Garmin US and got a better response to hanging and map availability/compatibility - please see:
| Quote: |
Hello Gary,
There is to be shortly a software update to eradicate the freezing up problem.
You could also try a master reset this may help the voice problem.
Warning! You will lose any user data saved locations etc.
Switch unit off.
Then press and hold the left hand button as well as the wheel button then also press and hold the power button until a message appears on the display asking you if you wish to erase user data? You would select "yes" to this.
The unit has now completed the reset. Now try the unit and see if this resolves the problem.
If not the software update to be released shortly will hopefully resolve the issue.
There will be additonal regions for Europe to purchase. These will be available soon but there is no confirmed shipping date. To be honest 2 weeks time is unlikely for you.
You could purchase city select Europe via an automotive kit say for our GPS MAP 60c. This will have City Select Europe maps on CD ROM which will enable you to use on your unit. YOu will need to also purchase a blank mirco SD card from a computer/camera shop. The Automotive kit RRP at 186.48.
The pre programmed cards will RRP at £76.66 ex VAT each.
The regions will be split down to 8 regions with France and Benelux being one of them.
Thank you.
Hope this helps and shows that Support are working the issues.
Look forward to other feedback |
| Back to top |
upthegardenpath Occasional Visitor
Posted: Tue Sep 13, 2005 11:52 pm Post subject: |
Reading with great interest at the moment (have just ordered mine from maplins.)
Has anyone managed to back up the transflash card onto a clean one and get it to work? Surely if they will be selling the European cards at 70quid +VAT they will be copy protected to prevent illegal copies? |
| Back to top |
Posted: Wed Sep 14, 2005 9:29 pm Post subject: Re Voice problem |
I posted a question at Garmin support re the problem I was having with voice commands and the hanging problem. Customer Support at Garmin Support seems a really good guy and responds quickly. The master reset on it's own didn't solve the problem and I wrote again and he suggested doing the master reset again but when it asks you for a language choose
a non english option. Then once that has been installed you will need to
then change the voice back to English. It might be worth noting that I waited whilst the language files loaded and didn't press the wheel as instructed, after about five minutes it went the next option on it's own. This worked brilliantly and I now have a unit that seems to work. Today is the first day without hanging as well!!
He also said "The software update will be released by the end of the week. |
| Back to top |
FriendlyBloke Occasional Visitor
Posted: Thu Sep 15, 2005 1:09 am Post subject: |
Yipee, finally found people who seem to know more than the experts!
I too have been having lock-up/freezing problems with my i3 and have been told to do a system reset also by Garmin (hasn't worked so far). Also been advised to purchase an antenna which I am awaiting from ebay.
Haven't had a chance to read all these posts yet, but does anyone have any straight forward instructions for downloading extra data, like speed cameras etc?
If anyone has any questions about my experiences so far please let me know. I will try and contribute to this forum as much as possible just as others have done.
Will be watching with interest! |
| Back to top |
BERT_UK Occasional Visitor
Posted: Thu Sep 15, 2005 2:31 pm Post subject: |
Does anyone know can you purchase the US maps for use on the European i3? I'm guessing you can......
Many thanks for any adivce. |
| Back to top |
Posted: Thu Sep 15, 2005 5:09 pm Post subject: |
| bert_uk..i think you can load any mapping software onto a spare transflash card and then put into the i3... |
| Back to top |
Posted: Thu Sep 15, 2005 5:44 pm Post subject: |
BERT_UK,
see my post a short while, I also asked - the answer was the same as buying City Select for Europe - just need to shell out money for CD & Transflash cards.
Friendly_bloke
I have managed to get the speed camera database working ok, along with a few other POI files and set up my own work related sites. Let me have a email contact and I'll help if I can
Works great (when it doesn't hang and give spurious spoken distances that do not match the correct visual distances!!!!) |
| Back to top |
| Back to top |
