| Author |
carcuscrae Occasional Visitor
Posted: Tue Sep 27, 2005 7:14 pm Post subject: MIO 168 Battery Replacement |
I think the battery on my MIO 168 is dying as it hardly lasts anytime at all now. Is it possible to replace the battery or do I have to replace the whole unit?
Thanks |
| Back to top |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Sep 27, 2005 8:20 pm Post subject: |
Try these web sites
Here
And Here |
| Back to top |
neil01 Frequent Visitor
Posted: Wed Sep 28, 2005 12:29 pm Post subject: |
This question seems to be asked a few times, and the information is not that easy to find. Especially since the official response seems to be that the battery is not replacable and the unit should be replaced when it expires.
Would this be a suitable post to be made 'sticky'? |
| Back to top |
LiveLifeGoJump Regular Visitor
Posted: Wed Sep 28, 2005 11:29 pm Post subject: |
| neil01 wrote: | This question seems to be asked a few times, and the information is not that easy to find. Especially since the official response seems to be that the battery is not replacable and the unit should be replaced when it expires.
The Mio-tech site is easy to find & one of the FAQ is aboult battery replacement.
Question & Mio response
» Mio168
Can I replace a dead battery by myself?
Last update: 2004-10-14 14:28
Batteries can only be replaced by returning your device to your dealer. Any attempt to replace the battery yourself will result in a loss of all waranty.
Check it out yourself at
http://www.mio-tech.be/support/faqs/index.php?sid=19995&lang=en&action=artikel&cat=3&id=23&artlang=en
Mio 168 FAQ page is at http://www.mio-tech.be/support/faqs/index.php?action=show&cat=3
Cover many more Mio units as well. _________________ If riding in a plane is flying then riding in a boat is swimming. If you want to experience the feeling
GET OUT OF THE VEHICLE |
| Back to top |
lamplight Regular Visitor
Posted: Thu Sep 29, 2005 4:36 pm Post subject: |
Given the warranty issues (which I guess will soon not apply to my Mio 168, given it's age), I'm interested to know if anyone has experience of replacing a battery for themself. And if so, how complex a procedure was it?
Always good to be prepared.  |
| Back to top |
Sequin Occasional Visitor
Posted: Sun Oct 02, 2005 10:38 am Post subject: |
I've just had mine open to see if I could fix a problem with the joystick (I couldn't) but it looks like a battery replacement would be an easy enough job.
Backup your system first - removing the battery will cause a hard reset, wiping everything off.
Remove the four screws in the corners of the back (no need to take out the one on the antenna hinge) then gently prise apart the case at the bottom using your fingernails- the back will come away and you will see the battery in the middle of the innards - it is stuck down, so you will need to free it (I think it is held down with one of those sticky pads) then disconnect it from the circuit board. Connect the new one and re-assemble, making sure you connect the antenna lead to the circuit board before you put it back together, as it pops off when you remove the back - it's a bit fiddly, but easy enough.
Click the case back together and replace the screws. Charge up the new battery and you should be good to go.
Don't forget that this will invalidate your warranty |
| Back to top |
Posted: Mon Oct 03, 2005 12:13 am Post subject: |
| Sequin that's a really useful piece of information. Thanks. Hope I never have to use it, but I for one will keep it handy just in case. |
| Back to top |
ps73uk Regular Visitor
Posted: Tue Oct 04, 2005 9:47 am Post subject: |
Shame you cant yet get the battery in the UK though (not that i can find anyway?), it's $52 to ship it from america! _________________ Garmin Streetpilot i3,
Tomtom One
Paul |
| Back to top |
| Back to top |
LeighB Regular Visitor
Joined: Jan 23, 2005 Posts: 156 Location: Ipswich Suffolk UK
Posted: Wed Oct 05, 2005 11:34 am Post subject: |
As a matter of interest do we know what the capacity of the standard Mio 168 battery is?
The replacement on that link is 1300 mah, and it seems to suggest that this is a higher capacity.
Anyone know? _________________ Leigh
Mio168 Kingston 256SD
TomTomNavigator3 3.07
TomTom Navigator 5
Memory Map 2004 OS 4.4
Checkpoint 2.02 |
| Back to top |
| Back to top |
Posted: Wed Oct 05, 2005 1:14 pm Post subject: |
Thanks,
It does sound well worth while when the original fails.
What experience have owners of the Mio of initial battery life?
Is it a couple of years, or maybe less? _________________ Leigh
TomTom Navigator 5
Checkpoint 2.02 |
| Back to top |
Posted: Wed Oct 05, 2005 5:46 pm Post subject: |
| The standard battery size IS 1350mAH period. |
| Back to top |
Posted: Wed Oct 05, 2005 8:21 pm Post subject: |
It says 1350mAh on mine! |
| Back to top |
Posted: Wed Jun 28, 2006 12:51 am Post subject: |
Sequin,
You posted helpful instructions here about how to replace the battery.
I have followed these, and all seemed to work well, but I no longer have a GPS signal.
I opened the case again twice to check that I had connected the antenna lead, and I am sure that it is securely fixed, is there anything else I may have forgotten?
Hope you can advise? _________________ Leigh
TomTom Navigator 5
Checkpoint 2.02 |
| Back to top |
| Back to top |
