| Author |
brian3315 Occasional Visitor
Joined: Feb 18, 2005 Posts: 37 Location: South Cheshire
Posted: Tue Jul 05, 2005 12:34 pm Post subject: Volume |
| I have a Dell Axim X5 And I find the volume when using TT5 very low. It is set to full in TT5 menu and in the X5 settings. Is this a fault with TT or with the PDA and if so is there any fix available. Thanks in anticipation. |
| Back to top |
nearlylost Regular Visitor
Joined: Nov 22, 2003 Posts: 67 Location: Weardale Co.Durham
Posted: Tue Jul 05, 2005 7:25 pm Post subject: |
| Amplified mounts are available for about £30 try a google or check the sponsers adverts |
| Back to top |
Posted: Tue Jul 05, 2005 7:32 pm Post subject: |
I use this one really sticks to the windsceen, if you have a car radio with a cassette player u can buy an adaptor from ebay looks like a cassette with a wire & plug coming from it costs about £5 snag is u cant listen to the radio at the same time
More info
Silver Shield Dell Axim X5 Amplified Speaker Mount for GPS Navigation.
Already have a PDA ? Can't hear the speaker ? Well at PDAMODS we have the perfect solution provided by our fully patented amplified speaker mount available exclusively at PDAMODS from the Silver Shield Powered Range (click on more info for information and more pictures). The silver shield amplified speaker mount will allow you to hear each and every word spoken by your navigation system with the utmost clarity - guaranteed. This mount will never fall off, it is by far the best mount we have seen.
Perfect for bluetooth and wired GPS navigation
Slot your PDA into the mount and you're ready to go
No messy wiring, simple two wire connection
Can be easily hard wired to give a neater solution
Charges your PDA continuously, never run out of power
Full volume control, we guarantee you that this is the loudest mount available
Works with most PDAs (additional adaptors available for future compatibility)
High quality silicone patented "Ultra-Suction" cup works in hot and cold climates
Foam side inserts holds PDAs securely
Spring Ratchet locking pivot point.
5 angle positioning allowing you to set the perfect viewing angle
You can also use this as a vent mount by choosing the additional vent mount option below
NOTE: This mount does not include a GPS receiver. If you are purchasing this mount it is assumed that you have a Rikaline/Tomtom wired GPS receiver OR any bluetooth GPS receiver. If you already have navigation software, then see our GPS receiver and Silver Shield Powered Range bundles below.
Vent attachment: _Please Select... Add attachment (+£4.99)
GPS receiver: Please Select...Bluetooth Haicom Wired Holux Wired Rikaline Wired Tomtom Wired
In Stock: 10+ available now Price: £27.99 (£32.89 Inc. |
| Back to top |
alan_m Regular Visitor
Posted: Tue Jul 05, 2005 7:45 pm Post subject: Re: Volume |
| brian3315 wrote: | | I have a Dell Axim X5 And I find the volume when using TT5 very low. It is set to full in TT5 menu and in the X5 settings. Is this a fault with TT or with the PDA and if so is there any fix available. Thanks in anticipation. |
Do you get enough volume with the PDA out of the car mount?
I have a Dell Axim 3 and although the volume is not that good I found that it was halved when I placed it in the car cradle.
On examination I found that around 90 percent of the PDAs speaker grill was covered by the mount. A needle file and 5 minutes work doubled the sound output :D |
| Back to top |
Soulah Occasional Visitor
Posted: Wed Jul 06, 2005 10:34 pm Post subject: |
Im having this problem. I use a seidio amplified mount and an IPAQ22xx PDA. Tomtom3 was wicked no probs. But now?
The volume is too quite, turning the volume up creates distortion. No matter what combination I seem to try, the volume is too quiet or too distorted.
Does anyone have this combination of equipment and would like to share there set up for nice volume? |
| Back to top |
Robin2 Lifetime Member
Posted: Wed Jul 06, 2005 11:40 pm Post subject: |
I use the Holux CR100 combined GPS receiver and amplified mount. The receiver works very well, and the sound output from the built in speaker is loud and very clear when used with my iPAQ 2210
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
| Back to top |
Deleth Occasional Visitor
Joined: Feb 14, 2004 Posts: 20 Location: United Kingdom
Posted: Thu Jul 07, 2005 12:59 pm Post subject: |
I upgraded from tom tom 3 to 5 on my 2210.
On tom tom 3 the volume was fine, tom tom 5 the volume was very low until the other day.
Driving along as normal with tom tom 5 whispering the instructions then all of a sudden the volume increased to how it used to be with tom tom 3
Very weird and thankfully it's stayed loud. I haven't done anything, no programs added or deleted.
May happen to you as well if your lucky :D |
| Back to top |
Crammy Occasional Visitor
Posted: Sat Jul 09, 2005 8:47 am Post subject: |
Just to say in the volume has a setting to link to driving speed.
Need to check your setting for volume in TT5 settings and remove Volume Speed option.
I hope this helps! |
| Back to top |
Posted: Sat Jul 09, 2005 10:46 am Post subject: |
Ahh of course. Thats something I havent tried at least. Ill have a look and report back
Thanks dude. |
| Back to top |
Gerco Occasional Visitor
Posted: Mon Oct 10, 2005 11:58 am Post subject: |
I found an interesting box (FastMute) which make it possible to connect ANY PDA to your car speakers(stereo).
No special radio required.
The box has a Mute-Generator (VOX) implemented.
In the moment (5ms later) the internal car speakers are switched off and the PDA sound comes amplified (9W Sin) to your car speakers.
There is only one 2 wire connection, from the ear phone jack to that box.
2 sec after the PDA sound has finished the speaker will be switched back (fall back) to your radio.
If you have a DIN loudspeaker connector just remove connectors from your radio and plug this box in between, connect to earphone output and power it, thats all.
Add On implemented for PDA MP3 users.
Autodetect for music. If the box is detecting music the fall back time will now be changed from 2s to now 15s. So no low volume music will cause any jitter in switching.
You can find this box here
http://www.fastmute.de/
The only problem is, that all informations are in German.
If there is some interest, I can translate the main items
Gerco |
| Back to top |
Masked-Marauder Regular Visitor
Posted: Mon Oct 10, 2005 3:25 pm Post subject: |
| At 25 Euros that is a steal. I will get my brother to translate it for me! |
| Back to top |
Posted: Mon Oct 10, 2005 3:29 pm Post subject: |
| Masked-Marauder wrote: | | At 25 Euros that is a steal. I will get my brother to translate it for me! |
That looks like it is only some kind of power module for it! |
| Back to top |
SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Mon Oct 10, 2005 5:18 pm Post subject: |
90 Euros - try http://babelfish.altavista.com/ which will translate the site for you, not perfectly but enough to get by....
Cheers,
Steve |
| Back to top |
Davemazo Occasional Visitor
Posted: Sat Nov 12, 2005 1:55 pm Post subject: |
| I have the same problem with my Axim X5. The spoken instructions are barely audible even with the radio switched off. I have found that if you start TT5 then insert it into the cradle (the Tomtom one for the Axim) it seems to work. |
| Back to top |
Posted: Sun Nov 13, 2005 4:03 pm Post subject: |
This site
is mainly translated now to English.
Gerco |
| Back to top |
| Back to top |
