Pocket GPS World :: View topic - Beginner’s Guide
Beginner’s Guide
Goto page Previous  1, 2, 3 ... 6, 7, 8 ... 31, 32, 33  Next
azreal1983
PostPosted: Tue Oct 11, 2005 4:53 pm    Post subject: tomtom mobile Reply with quote
I am using tomtom 5 app version 5.020 (535)
does anyone out there have the sound editor to change to data.chk file for this version.
I can email the data file to them if they wish.
media23
PostPosted: Tue Oct 18, 2005 11:10 am    Post subject: Reply with quote
it mentions...
NB if you want to use the subcategories then you need to load and activate all of them else you will not be warned!
how do you activate them ???
Privateer
PostPosted: Tue Oct 18, 2005 11:47 am    Post subject: Reply with quote
Hi media23,
Welcome to the forum! Thumbs Up
It depends on the SatNav system that you wish to use them on.
Robert.
Garmin Camper 770 LMT-D
etters
PostPosted: Thu Oct 27, 2005 3:32 pm    Post subject: Reply with quote
Hi Everyone
Having read all the question's and answers on seven pages, could someone please tell me how I can download the speed camera's onto my Falk navigator2 system, I would be very pleased to know.
regards
Takara GP56 igo primo 1.1
Dont rely on them use your brain as well
sdjohnstone
PostPosted: Tue Nov 01, 2005 8:54 pm    Post subject: Reply with quote
Hi,i hope someone can help i have a navman 510 can i add the speed cameras to this and how ,i am not great with computers
PostPosted: Wed Nov 02, 2005 8:16 am    Post subject: Reply with quote
Yes you can add the cameras to a 510.
Have a look at this -
http://www.pocketgpsworld.com/uksafetycameras-navman.php but note that you now have .asc files to use and you don't need to edit the files to use them. (Where it says .csv use .asc).
See - http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=159842
TT Via 135 App 12.075: Europe Map v1165
Vizz
PostPosted: Thu Dec 01, 2005 4:12 pm    Post subject: Reply with quote
I'm sure the answer is here somewhere but I'm afraid I've not found it!! Embarassed
I have put the correct version of the POI warnings on my TT Go, and assigned the warning to the correct type of camera, so far so good!!However I don't know how to get the correct speed warning to be announced when a camera is detected. Question
Any help would be appreciated - Thanks :D
Privateer
PostPosted: Thu Dec 01, 2005 4:42 pm    Post subject: Reply with quote
Hi Vizz,
Please read:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=18701
http://www.pocketgpsworld.com/tomtom-poi-alerts.php
Robert.
Vizz
PostPosted: Thu Dec 01, 2005 4:56 pm    Post subject: Reply with quote
Thanks for the speedy reply, I have managed to find the articles refered to before and have read them, I have correctly installed the data.chk file and that is working ok, my problem is getting the actual speed limit to be announced/activated.
Sorry to be such a thicko!!
Embarassed
Privateer
PostPosted: Thu Dec 01, 2005 5:33 pm    Post subject: Reply with quote
Hi Vizz,
As long as you have installed the correct DATA.CHK file for your TomTom GO software version, then you:
PocketGPSWorld guide to installing POIs onto a TomTom GO wrote:
Step 5. Display POIs on your TomTom GO
Finally, to enable POIs in your TomTom GO select them in your POI categories:
Change Preferences | Manage (or Maintain) POI | Enable / Disable POI
Select POI
They now are displayed on your GO screen in both 3D maps and 2D maps.
Even if you do not display POIs on screen, you can now "navigate to" your Poi’s, find POIs near your location, etc.
Step 6. Set up Proximity Alerts (optional)
Change Preferences | Manage (or Maintain) POI | Warn when near POI
Select each POI in turn,
Select the distance for warning
Select the warning sound
Uncheck the "Warn only if POI is on route" box
Repeat until all POIs are set up to warn.
NB. If you check the "Warn only if POI is on route" box, then you will not be warned of POIs that you approach if:
1. The POIs are slightly away from the road.
2. You have no destination and therefore no route planned.
I hope the above helps! Thumbs Up
Robert.
BlueBox
PostPosted: Thu Dec 01, 2005 10:31 pm    Post subject: Reply with quote
Anyone know how i check if i have the lastest camera database on my TTGO 300 Wink
PostPosted: Fri Dec 02, 2005 7:56 am    Post subject: Reply with quote
Check the Version.txt file in the download. It should be 3.114.
Vizz
PostPosted: Fri Dec 02, 2005 9:45 am    Post subject: Reply with quote
Thanks again for the reply.
I have done everthing within the info you posted.
When I approach a camera my TT tells me what it is correctly, ie Gatso, Specs, Temp etc but does not give the current speed limit.
Have I got the wrong idea here? Is that as good as it gets, or am I still not doing something. Should the software give you the speed limit.
As I set the Tempoarary Camera warning at the first verbal warning available ie Tempoary 50, I am warned at all temporayr camera locations 'Temporary 50'
Thanks for your help - sorry to appear so stupid!!!!!!!!
PostPosted: Fri Dec 02, 2005 11:38 am    Post subject: Reply with quote
Vizz
Lets go back to the beginning and take this one step at a time....
Firstly, have you put THESE files into your map folder?
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ov2
pocketgps_uk_mobile_20.ov2
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_50.ov2
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_temp.ov2
pocketgps_uk_specs.ov2
pocketgps_uk_redlight.ov2
(plus their matching .bmp icon files)
PostPosted: Fri Dec 02, 2005 1:23 pm    Post subject: Reply with quote
I've been looking back over this thread, and it is getting terribly unwieldy, with several different questions all going on at the same time.
Can I suggestit might be better to start a new thread, if there are any more follow-on questions?
Page 7 of 33
24.041 (01 Apr 26)
