| Author |
Snakey Occasional Visitor
Posted: Tue Nov 01, 2005 4:22 am Post subject: Can you use TomTom 5 on a NavMan Pin ? |
| Loaded TomTom, no GPS found. Is it possible, what do you set the gps to in TomTom ? |
| Back to top |
lbendlin Pocket GPS Staff
Posted: Tue Nov 01, 2005 4:47 am Post subject: |
Something like "Other Cable NMEA", 4800 or 9600, SP2: _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
| Back to top |
TheMoosehunter Occasional Visitor
Posted: Tue Nov 01, 2005 11:45 am Post subject: |
Just completed this process on my 570
Baud rate is 9600, and works OK on mine
You may need to reset to get it to function OK
Cheers |
| Back to top |
StevenGourlay Frequent Visitor
| Back to top |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Wed Nov 02, 2005 5:39 pm Post subject: |
If that is the Mio 168 clone then the settings are as follows
Other Cable NMEA
Baud 4800
Serial cable on sp2
Then you need to wait for several mins (2-10) to get a lock, the bars should be grey on the screen, then should turn blue when locked.
You need a good view of the sky, next to window or outside. Although I live in a bungalow and it works fine in any room! |
| Back to top |
Posted: Wed Nov 02, 2005 8:16 pm Post subject: Navman Pin 570 |
The navman is completely different from the Mio and the options
are different as well.
somebody please help |
| Back to top |
Posted: Wed Nov 02, 2005 11:13 pm Post subject: Re: Navman Pin 570 |
| Snakey wrote: | The navman is completely different from the Mio and the options
So its not this ONE |
| Back to top |
| Back to top |
Posted: Thu Nov 03, 2005 7:48 pm Post subject: Re: no, its this one |
| Snakey wrote: | | http://www.navman.com/land/products/pin570/index.html |
Here you go then, from another post, but someone also said you need to turn the GPS on first before starting TomTom from one of the menus within the Pin570.
| Quote: | I finally figured how to get TomTom 5 on Navman PiN 570, so here goes
Firstly turn on your GPS by going into "Start:Settings:GPS on SystemTab:ON"
The amber light should be flashing in the top left of your PIN 570
Next start tomtom
On "Main menu 1 of 3" tap "Change preferences"
On "Preferences 4 of 6" tap "Show GPS Status"
Tap "Configure"
Choose "Other Cable NME GPS"
Set "GPS baud rate to either 9600(worked for me) or 4800"
Now the tricky bit, this is where i got lost before
You are now faced with
GPS is connected to
SC2410 USB Cable:
COM3:
S2410 IRDA2410
S2410 UART0
GPS ON NAVIGATOR
Choose "GPS ON NAVIGATOR"
Done
Make sure your NAVMAN aeriel can see the sky and you'll be picking up satellites in no time.
Hope this helps took me a while to figure out but it definately works!! |
I cannot comment as I have not seen that working for myself. |
| Back to top |
Posted: Thu Nov 03, 2005 9:51 pm Post subject: FANTASTIC !!!!! |
It Works...
Thanks everyone for all the help,,,, |
| Back to top |
Posted: Fri Nov 04, 2005 4:31 am Post subject: Re: FANTASTIC !!!!! |
| Snakey wrote: | It Works...
Your Welcome  |
| Back to top |
larkshall Regular Visitor
Joined: Nov 11, 2004 Posts: 112 Location: Selby North Yorkshire
Posted: Sat Nov 05, 2005 11:50 pm Post subject: |
| er why would anyone want to run tom tom software on a navman device?would seem to be doubling softwre costs. |
| Back to top |
Posted: Sun Nov 06, 2005 12:58 am Post subject: Matter of Fact |
| Navman Pin's own software is crap, Tom Tom 5 is easily the best, It's worth spending the money... |
| Back to top |
psychocandy Occasional Visitor
Posted: Wed Jan 24, 2007 4:48 pm Post subject: |
Is there anyway to get the Pin to start the GPS automatically when you go into TOmTom?
SmartST seems to do this...
Otherwise, its just a pain to start GPS before TomTom (Not for me but explaining this to the Mrs !!!) |
| Back to top |
Rickyt Occasional Visitor
Posted: Fri Jun 22, 2007 12:19 pm Post subject: |
| I've had to ditch my TT5 as it kept freezing and blacking out the screen causing a full re-set to get things back to normal on my PIN570 .I hated having to load all my programs back on again . Anyway , I got a version of TT6 with the latest UK & WE map . Absolutely fab , No freezes , no black screens . Still have the capability of running SmartST should I need it , but TT is MILES better |
| Back to top |
| Back to top |
