| Author |
bully Occasional Visitor
Posted: Sat Nov 19, 2005 10:49 am Post subject: help withxda 2 with gps receiver |
I have an xda 2 with tomtom 5 installed but cant get the bluetooth gps reveiver to talk to it, the xda can see it but the blue light on the gps flashes every 3 seconds.
Have tried all what it says in the instructions but still cant get it working together any advise or help would be great
thanks chris |
| Back to top |
Posted: Sat Nov 19, 2005 10:58 am Post subject: |
| Have you got the GPS unit paired with the reciever? then use "other wired NMEA device" in the GPS set-up within TT. set Baud speed (4800 or 9600 are the most common) and finally select the Bluetooth port on the last screen it shows. It might take 15 Min to fire up if its the first time, and make sure its got a clean line of sight to the sky - Mike |
| Back to top |
Posted: Sat Nov 19, 2005 2:20 pm Post subject: |
| mikealder wrote: | | Have you got the GPS unit paired with the reciever? then use "other wired NMEA device" in the GPS set-up within TT. set Baud speed (4800 or 9600 are the most common) and finally select the Bluetooth port on the last screen it shows. It might take 15 Min to fire up if its the first time, and make sure its got a clean line of sight to the sky - Mike |
Thanks for the advise i will try that |
| Back to top |
StevenGourlay Frequent Visitor
Posted: Sat Nov 19, 2005 2:26 pm Post subject: |
i would also recommend that you download the TomTom 5 update @
www.tomtom.com -> support -> PDA navigation -> TomTom 5 -> updates and manuals Update July 2005 - TomTom NAVIGATOR 5.10 _________________ Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool |
| Back to top |
Posted: Sat Nov 19, 2005 4:09 pm Post subject: |
| StevenGourlay wrote: | i would also recommend that you download the TomTom 5 update @
www.tomtom.com -> support -> PDA navigation -> TomTom 5 -> updates and manuals Update July 2005 - TomTom NAVIGATOR 5.10 |
I tried the down load but it asks me for a activation code and i dont have one i got tomtom 5 sd card of ebay.
I have tried leaving the xda and bt77 to talk to each other for a bout half an hour with gps setting in various ways but the blue tooth on the gps still flashes every 3 seconds and will not link up to the xda. the xda can see the gps receiver in the blue tooth settings but other than that they dont seem to connect.
I am really stumped now and getting fed up with it
Any advise much appreciated
Thanks Chris |
| Back to top |
Posted: Sat Nov 19, 2005 8:30 pm Post subject: |
| mikealder wrote: | | Have you got the GPS unit paired with the reciever? | Have you actually achieved a succesfull PAIR between the two devices, and during pairing select SPP mode, if not then the problem is not the TT software. It sounds like the devices are not comunicating with each other. I have seen this before with the XDAII, and it was down to the microsoft BT stack, if you load the Widicomm instead it might work - not too easy to do though - I would also sugest you purchase a legitimate copy of the software as without the product code it is more than likely pirated software - Mike |
| Back to top |
ipaq3870 Occasional Visitor
Joined: 02/09/2003 21:37:51 Posts: 8 Location: United Kingdom
Posted: Sat Nov 19, 2005 9:55 pm Post subject: |
Is the red LED actually flashing? If not you've not achieved GPS sync and you won't get any sense from the unit.
This might help you achieve GPS sync....
1. Remove the battery from the BT77;
2. Remove the two small philips head screws from the bottom of the case;
3. Remove the front of the case. There are two small clips at the top, so pull the case updwards and forwards - gently!
4. You should see a small cell battery - possible covered by a coloured (mine was blue) circular label.
5. Remove the label and the battery. The battery is a tight fit and you may need to lever the plastic clip out of the way to remove it. Be gentle - the mechanical integrity of the battery holder is, shall we say, "adequate".
6. With the cell battery out, go away and make a brew. Survey the wonder that is modern day electronics.
7. Suitably refreshed, put the battery back (and the label back on) and reassemble the unit (if you've got this far it should be a doddle).
8. Powering the unit on should result in a fix after a few minutes.
Steve |
| Back to top |
Posted: Sat Nov 19, 2005 10:06 pm Post subject: |
| I can get the bt 77 to have a red light flashing so i can only presume it has got linked to a satalite. the problem i think i have is i dont think the bt77 is talking to the xda, the xda can find the bt gps via bluetooth but but that seems to be about it. The bt gps has a blue light that only flashes about once every 3 seconds i can seem to sort out this problem. How can i tell on the xda if it is receiving signals from the bt gps |
| Back to top |
alix776 Pocket GPS Moderator
Posted: Sat Nov 19, 2005 10:08 pm Post subject: |
you might have a cracked version of the software id buy full version from a dealer not off ebay i believe total pda are pretty good on price and delvery 8) 8) _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
| Back to top |
Posted: Sat Nov 19, 2005 10:12 pm Post subject: |
| If i buy tomtom 5 on sd card do you think this will sort the problem and is it possible to buy just the software on a card |
| Back to top |
| Back to top |
Posted: Sat Nov 19, 2005 11:40 pm Post subject: |
Thanks for all the help and advice i think i might have a dodgy tomtom 5 sd card just hope i can get my money back from the person i bought it from  |
| Back to top |
| Back to top |
