| Author |
azreal1983 Occasional Visitor
Posted: Tue Oct 11, 2005 4:53 pm Post subject: tomtom mobile |
I am using tomtom 5 app version 5.020 (535)
does anyone out there have the sound editor to change to data.chk file for this version.
I can email the data file to them if they wish. |
| Back to top |
media23 Occasional Visitor
Posted: Tue Oct 18, 2005 11:10 am Post subject: |
it mentions...
| Quote: | | NB if you want to use the subcategories then you need to load and activate all of them else you will not be warned! |
how do you activate them ??? |
| Back to top |
Joined: 30/12/2002 17:36:20 Posts: 4923 Location: Oxfordshire, England, UK
Posted: Tue Oct 18, 2005 11:47 am Post subject: |
Hi media23,
to the forum!
| media23 wrote: | | how do you activate them ??? |
It depends on the SatNav system that you wish to use them on.
Garmin Camper 770 LMT-D |
| Back to top |
etters Lifetime Member
Joined: Jan 18, 2005 Posts: 172 Location: Sunny Spain
Posted: Thu Oct 27, 2005 3:32 pm Post subject: |
Hi Everyone
Having read all the question's and answers on seven pages, could someone please tell me how I can download the speed camera's onto my Falk navigator2 system, I would be very pleased to know.
regards _________________ Takara GP56 igo primo 1.1
Dont rely on them use your brain as well |
| Back to top |
sdjohnstone Occasional Visitor
Posted: Tue Nov 01, 2005 8:54 pm Post subject: |
| Hi,i hope someone can help i have a navman 510 can i add the speed cameras to this and how ,i am not great with computers |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
| Back to top |
Vizz Occasional Visitor
Posted: Thu Dec 01, 2005 4:12 pm Post subject: |
I'm sure the answer is here somewhere but I'm afraid I've not found it!!
I have put the correct version of the POI warnings on my TT Go, and assigned the warning to the correct type of camera, so far so good!!However I don't know how to get the correct speed warning to be announced when a camera is detected.
Any help would be appreciated - Thanks :D |
| Back to top |
| Back to top |
Posted: Thu Dec 01, 2005 4:56 pm Post subject: |
Thanks for the speedy reply, I have managed to find the articles refered to before and have read them, I have correctly installed the data.chk file and that is working ok, my problem is getting the actual speed limit to be announced/activated.
Sorry to be such a thicko!!
| Back to top |
Posted: Thu Dec 01, 2005 5:33 pm Post subject: |
Hi Vizz,
As long as you have installed the correct DATA.CHK file for your TomTom GO software version, then you:
| PocketGPSWorld guide to installing POIs onto a TomTom GO wrote: | Step 5. Display POIs on your TomTom GO
Finally, to enable POIs in your TomTom GO select them in your POI categories:
Change Preferences | Manage (or Maintain) POI | Enable / Disable POI
Select POI
They now are displayed on your GO screen in both 3D maps and 2D maps.
Even if you do not display POIs on screen, you can now "navigate to" your Poi’s, find POIs near your location, etc.
Step 6. Set up Proximity Alerts (optional)
Change Preferences | Manage (or Maintain) POI | Warn when near POI
Select each POI in turn,
Select the distance for warning
Select the warning sound
Uncheck the "Warn only if POI is on route" box
Repeat until all POIs are set up to warn.
NB. If you check the "Warn only if POI is on route" box, then you will not be warned of POIs that you approach if:
1. The POIs are slightly away from the road.
2. You have no destination and therefore no route planned. |
I hope the above helps!
| Back to top |
BlueBox Regular Visitor
Joined: Dec 02, 2004 Posts: 87 Location: High Wycombe
Posted: Thu Dec 01, 2005 10:31 pm Post subject: |
Anyone know how i check if i have the lastest camera database on my TTGO 300  |
| Back to top |
Posted: Fri Dec 02, 2005 7:56 am Post subject: |
| BlueBox wrote: | Anyone know how i check if i have the lastest camera database on my TTGO 300  |
Check the Version.txt file in the download. It should be 3.114. _________________ Richard
TT Via 135 App 12.075: Europe Map v1165 |
| Back to top |
Posted: Fri Dec 02, 2005 9:45 am Post subject: |
Thanks again for the reply.
I have done everthing within the info you posted.
When I approach a camera my TT tells me what it is correctly, ie Gatso, Specs, Temp etc but does not give the current speed limit.
Have I got the wrong idea here? Is that as good as it gets, or am I still not doing something. Should the software give you the speed limit.
As I set the Tempoarary Camera warning at the first verbal warning available ie Tempoary 50, I am warned at all temporayr camera locations 'Temporary 50'
Thanks for your help - sorry to appear so stupid!!!!!!!! |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Fri Dec 02, 2005 11:38 am Post subject: |
Vizz
Lets go back to the beginning and take this one step at a time....
Firstly, have you put THESE files into your map folder?
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ov2
pocketgps_uk_mobile_20.ov2
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_50.ov2
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_temp.ov2
pocketgps_uk_specs.ov2
pocketgps_uk_redlight.ov2
(plus their matching .bmp icon files) |
| Back to top |
Posted: Fri Dec 02, 2005 1:23 pm Post subject: |
I've been looking back over this thread, and it is getting terribly unwieldy, with several different questions all going on at the same time.
Can I suggestit might be better to start a new thread, if there are any more follow-on questions? |
| Back to top |
| Back to top |
