| Author |
PONDEROUS Frequent Visitor
Joined: Aug 25, 2004 Posts: 634 Location: Lincolnshire, England
Posted: Thu Dec 01, 2005 4:47 pm Post subject: |
I guess this is very much a matter of taste, but why spoken speed camera alerts?
I find the straightforward clang of a bell or something else that I have associated with speed cameras far preferable to the fuzzy and unnecessarily long message from another navgation package that I use. You can of course choose three or four tones to represent as many different speeds, if you wish. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
| Back to top |
mini1400 Lifetime Member
Posted: Thu Dec 01, 2005 5:53 pm Post subject: |
| PONDEROUS wrote: | | I guess this is very much a matter of taste, but why spoken speed camera alerts? |
So you are aware of the speed you should be doing without having to look at the GPS.... |
| Back to top |
Posted: Thu Dec 01, 2005 6:02 pm Post subject: |
mini400wrote:
| Quote: | | So you are aware of the speed you should be doing without having to look at the GPS.... |
Not always, but that's why I have a few different sounds for them. I've got on with them well, but it sounds as of that might be just me
I suppose my view is a bit skewed because of the implementation of voice-based warnings that I have actually experienced. Maybe I'll feel different if I get around to trying the ones for TomTom. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
| Back to top |
gripp Regular Visitor
Posted: Thu Dec 01, 2005 6:14 pm Post subject: |
| lbendlin wrote: |
you only need two files
TomTom Navigator.exe
Data.chk
Thanks Lutz, you've solved my problem and I'm now up and running with v5.21.
Why, oh why, do TomTom make the upgrade procedure so difficult when it's just a case of replacing two files? _________________ Nokia E65 & TT Nav6 |
| Back to top |
spook51 Lifetime Member
Joined: Mar 26, 2004 Posts: 548 Location: East Midlands
Posted: Thu Dec 01, 2005 6:35 pm Post subject: |
| mini1400 wrote: |
How does the camera database make you aware of the speed you should be driving at? |
| Back to top |
Posted: Thu Dec 01, 2005 7:01 pm Post subject: |
Further to my earlier post about different tones for different speeds, I got a couple of things mixed up there after not using TomTom for a week or two. So, in fact what I was describing was rubbish!!
Apologies for that. _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
| Back to top |
Posted: Thu Dec 01, 2005 10:01 pm Post subject: |
Quite right, B-C. If someone is using their SatNav to prompt them of the speed limit of the road they're on, perhaps they shouldn't be on it?
And to expect SatNav to give the speed at which they should be driving is the most idiotic thing I've read in a long time. |
| Back to top |
raptorheli2 Occasional Visitor
Posted: Fri Dec 02, 2005 12:09 am Post subject: |
does anyone know if this fixes the lag problems?
or what it has fixed?
cheers |
| Back to top |
Posted: Fri Dec 02, 2005 12:15 am Post subject: |
Yes, a simple list of bug fixes and/or enhancements in v5.210 has been conspicuously absent so far.
Any reputable software vendor would have no hesitate publishing such a list with a new version.
So TomTom, WHERE IS YOUR LIST? _________________ Nokia E65 & TT Nav6 |
| Back to top |
vitalogy Occasional Visitor
Posted: Fri Dec 02, 2005 2:07 am Post subject: |
Please help me with this: i'm about to by the QTEK 9100, to use as PDA and aslo as a navigation device. I like to use Tom Tom Navigator 5 (TTN5), but, the OS of the QTEK 9100 is the new Windows Mobile 5 (WM5). The Tom Tom site refers that this OS is not supported by the TTN5 or the bluetooth receiver.
Looking to the posts above, i find some users using the TTN5 with PAD with WM5. Therefore, is possible to use TTN5 with WM5?
It is possible to use the bluetooth receiver from Tom Tom with the WM5?
To finish: anyone use the QTEK 9100 with the TTN5? Anyone nows if it is possible, despite the Tom Tom site say it still not possible?
Thank's.
Regars,
Marco |
| Back to top |
DLCPhoto Occasional Visitor
Posted: Fri Dec 02, 2005 2:09 am Post subject: |
| gripp wrote: | | Any reputable software vendor would have no hesitate publishing such a list with a new version. |
I think you've answered your own question...
DonDLC Photography |
| Back to top |
AnisKhan Occasional Visitor
Posted: Fri Dec 02, 2005 9:37 am Post subject: Backlight Problem for 5.2 and WM5 |
Hi there - this is my first post here.
I have installed the latest update 5.2 but when I start the program, the backlight switches off.
This would also happen in 5.1 but I found a fix on the XDA.Developers site.
Does anyone else have this problem?
Anis
XDA2 with WM5 |
| Back to top |
Posted: Fri Dec 02, 2005 11:19 am Post subject: |
Forgot to mention in my previous post, I have made sure that the Backlight does not turn off in Settings but this makes no difference. When I load TomTom, it switches the backlight off.
Close down TomTom, and the Backlight come back on.
Lovely. |
| Back to top |
schneid Regular Visitor
Posted: Fri Dec 02, 2005 5:22 pm Post subject: If it was |
| Lowrance would probably call that a feature. |
| Back to top |
Posted: Fri Dec 02, 2005 5:38 pm Post subject: |
| spook51 wrote: | Quite right, B-C. If someone is using their SatNav to prompt them of the speed limit of the road they're on, perhaps they shouldn't be on it?
I agree you should know what the speed limit of the road is that you are on, but sometimes you may go from one limit to another without realising - like the North Circular at the bottom of the M11 - why is that a 50 limit when its in a cutting??? |
| Back to top |
| Back to top |
