| Author |
davidi Occasional Visitor
Posted: Mon Dec 05, 2005 1:25 pm Post subject: A Turn Off |
Had unit for two days.
I3, turns itself off while trying to aquire sats.
It has only done this twice.
Battery showing just 1/3 capacity.
Any ideas. |
| Back to top |
Posted: Mon Dec 05, 2005 2:13 pm Post subject: |
| David, Welcome to the forum, I sugest you need some new batteries, get the highest capacity you can, this is specified in mA - go for at least 2500mA with the correct charger its cheaper in the long run than using copper top disposable units - Mike |
| Back to top |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Mon Dec 05, 2005 2:18 pm Post subject: |
i agree wtih mike...cheap poundland batterys will not work properly in the i3....stick some duracells or rechargables in it ... _________________ *************************** |
| Back to top |
Posted: Mon Dec 05, 2005 3:57 pm Post subject: Thanx Guys |
Thought power may be the problem.
By the way got mine for £131.00, with a staff discount.
Hows that for a real beargain :D |
| Back to top |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Mon Dec 05, 2005 7:34 pm Post subject: Re: Thanx Guys |
| davidi wrote: | By the way got mine for £131.00, with a staff discount.
Wow! Where do you work (if you don't mind us asking!)
Watch out or you will have a steady stream of new friends wanting you to buy gadgets for them.  _________________ Gone fishing! |
| Back to top |
dougconran Regular Visitor
Joined: Oct 07, 2004 Posts: 175 Location: Bury St Edmunds, Suffolk
Posted: Mon Dec 05, 2005 8:57 pm Post subject: Re: A Turn Off |
| davidi wrote: | Had unit for two days.
Any ideas. |
Didn't some people have this problem with v2.7? What version are you using? |
| Back to top |
Posted: Tue Dec 06, 2005 12:08 am Post subject: |
Skippy
Not me but the good lady, at Somerfield.
dougconran
Yes mine is V2.7 |
| Back to top |
charlies Occasional Visitor
Posted: Tue Dec 06, 2005 8:02 pm Post subject: |
I had this problem on cheap alkaline batteries only yesterday...Would turn off virtually straight away despite showing full power.
I usually use 2500mah rechargeables, and get about five hours of continous use out of them and maybe three if lots of turning off and on.
Cheaper to go for decent rechargebles in the long run and does away with the unsightly wire |
| Back to top |
Posted: Tue Dec 06, 2005 10:27 pm Post subject: |
| charlies wrote: | | Cheaper to go for decent rechargebles in the long run and does away with the unsightly wire |
Agree go for the best batteries you can get (there are 3,200mA AA size cells available now - if you can find them) but use the charger lead at the same time as it reduces the burden on the batteries, you will get considerably longer usage this way - Mike |
| Back to top |
| Back to top |
