| Author |
cuk0724 Occasional Visitor
Joined: 04/08/2003 20:00:20 Posts: 44 Location: Essex
Posted: Sun Sep 14, 2003 8:04 am Post subject: Check Point & PPC2003 |
| Has anyone got an iPAQ 2210 and using Check point? If so does it run OK without any problems. I have been using GPS Assist, but found it has too many problems. |
| Back to top |
Dave Frequent Visitor
| Yes it works okay on a 2210, this is what I'm currently using when I use TomTom Navigator 2. You'll probably find v2.0.2 better than v3, as this is what many people are finding and reporting here. v2.0.2 isn't available from the CheckPOInt website anymore, but we have a copy on our Downloads page. |
| Back to top |
| Thanks for the quick answer |
| Back to top |
alix776 Pocket GPS Moderator
Posted: Wed Sep 17, 2003 8:50 pm Post subject: |
dave v3 is working fine on my 2210 no probs at all  _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
| Back to top |
bigfatjohn Regular Visitor
Joined: Oct 29, 2003 Posts: 114 Location: Market Harborough
Posted: Wed Oct 29, 2003 1:54 pm Post subject: |
Not on mine it isn't. (PPC2003)
I have installed it but can get no further than the disclaimer page. There is no way to accept the disclaimer and I can't go anywhere else until I have.
Any ideas please? |
| Back to top |
iangus Occasional Visitor
Posted: Wed Dec 24, 2003 12:32 pm Post subject: |
ack well at least u can get to a disclaimer page!!!
i too the advice and did not install 3.2 at first. i tried the prev vers and this did not work so uninstalled. i intalled 3.2 and nothing works at all for this when tapping the icon. it is also proving more or less impossible to uninstall the program (certainly the icon for it seems positively glued onto the programmes screen!). i am dying to get speed camera warnings working - any advice would be a delight |
| Back to top |
DavidW Pocket GPS Moderator
Posted: Fri Dec 26, 2003 6:01 pm Post subject: |
The only thought I have is that you've somehow picked up some garbage in the registry that is causing the problems.
I'm still using 2.0.2 on Pocket PC 2003 - it's the only version I've ever installed on my iPAQ 3970 since I upgraded the OS. It works fine for me, once you get past the slightly unintuitive configuration method (tap the flashing icon at the bottom of the Today screen when you first run the program).
This is a strictly untested suggestion, and I do not guarantee anything (including that it will not cause more problems). I believe that CheckPOInt puts some registration information in other parts of the registry that we haven't yet found (look at my comments on the first version 3 release) and it could be the problems lie there.
However, the only thing I can think of is uninstalling CheckPOInt, then, using a registry editor, such as the one you can get here, delete the entire "CheckPOInt Software" key in HKEY_CURRENT_USER\Software. Backup the Pocket PC before you try this, particularly if you're not confident in what you're doing - Sprite Backup is highly recommended.
David |
| Back to top |
Ginnser Occasional Visitor
Posted: Mon Jan 05, 2004 12:08 am Post subject: |
Hi All
I was having a nightmare with version 3 on the 2210, running really slow, so back to the older version. |
| Back to top |
Posted: Mon Jan 05, 2004 9:36 am Post subject: |
| I have noticed D3 running extremely slow on MicroDrives, so I think the disk access in loading maps is much more intense than in D2 or other mapping programs. This may affect slow storage cards also. |
| Back to top |
Posted: Mon Jan 05, 2004 11:14 pm Post subject: |
Dave - were you confused between Destinator and CheckPOInt in your last post in this thread? It sounds like you're writing about Destinator in a CheckPOInt thread.
David |
| Back to top |
AliT Occasional Visitor
Posted: Tue Jan 13, 2004 10:50 am Post subject: |
Having installed Checkpoint v 3 on a new Axim 5 with TTN2 I could not find how to register the software to allow the Pocket GPS database to be used. I uninstalled it and then (mistake !!) re-installed to see if I had missed a step. Now I have 2 Checkpoint icons. Uninstalling leaves the icons behind.
Can you provide a few more instructions about how the register should be edited. |
| Back to top |
Posted: Tue Jan 13, 2004 11:02 pm Post subject: |
Multiple program icons is nothing to do with the Registry.
Assuming you're talking about what you see in Start -> Programs, or in the Start Menu itself, you need to go into \Windows\Start Menu using either a file manager program on the Pocket PC, or the Explore function in ActiveSync (select My Pocket PC first if you try this). You should then be able to find and delete the unwanted extra program icons - they may be in subfolders of \Windows\Start Menu.
David |
| Back to top |
| Back to top |
