Pocket GPS World :: View topic - GO update of 5.420 has been released.
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Zaki
PostPosted: Mon Nov 21, 2005 7:18 pm    Post subject: Reply with quote
Kitch wrote:
I was running a ttg 500 with 5.201, latest speed cameras and custom sounds. i then did the upgrade and it would get to the splash screen, change to night colours(this is as i had it set on night colours before the update) and freeze. i have just reverted back to the orginal setup and it works fine.
please help
Ian
Remove your custom sounds and try again, it will not load properly with anything else but pocket gps camera database
Kitch
PostPosted: Wed Nov 23, 2005 4:03 pm    Post subject: Reply with quote
Thanks, I will do that this afternoon and let you know.
Cherers
Kitch
PostPosted: Wed Nov 23, 2005 9:50 pm    Post subject: Reply with quote
When trying to install the origninal backup i get an error. Could someone please send me the standard data.chk file.
PostPosted: Wed Nov 23, 2005 10:15 pm    Post subject: Reply with quote
You've got it. Smile
Kitch
PostPosted: Wed Nov 23, 2005 10:47 pm    Post subject: Reply with quote
So I had it wasn't where I thought it was. It is now put where it should be.
Ian
toasty71
PostPosted: Wed Nov 23, 2005 11:55 pm    Post subject: Reply with quote
Oldboy wrote:
Zaki wrote:
Is it not possible for Pocket GPS to leave a couple of "Bells" and "Bongs" in their data.chk file for use with other POI's. Or have I got it all wrong !!!
Have a look at www.tomtomsatnav.info to see if Ray has worked a new data.chk yet.
Hi,ive tryed doing that tonight,could not see it on the site so i e-mailed ray to see if he was going to do an update and he said that he is working on it at the moment.
duneclifftcooper
PostPosted: Sun Nov 27, 2005 7:39 pm    Post subject: Reply with quote
hi all
TG300 owner, i have just installed the new upgrade directly from tt's website and now it would appear that i have lost all of my own poi sounds, any ideas on how i can get thm back, it has gone back to the old, cow, bell, cukoo thing, really annoying :x
Many thanks in advance
ttg300
View user's profile Send private message Yahoo Messenger
beashley
PostPosted: Sun Nov 27, 2005 8:16 pm    Post subject: Reply with quote
duneclifftcooper wrote:
hi all
Go here and update
http://www.pocketgpsworld.com/tomtom-poi-alerts.php
duneclifftcooper
PostPosted: Tue Nov 29, 2005 12:33 pm    Post subject: Reply with quote
Thanks beashley
Minor issue, that is the info for pgps' poi sounds, i would like my own back
dc
ttg300
StanStill
PostPosted: Tue Nov 29, 2005 8:14 pm    Post subject: Reply with quote
Have you tried copying the data.chk file from your backup?
PostPosted: Tue Nov 29, 2005 9:19 pm    Post subject: Reply with quote
That will NOT work. You have to recompile your own DATA.CHK the same way you did it for the previous version.
beware though - there's a data issue in the new data.chk , and it's not trivial to fix. the compiler needs to be updated too.
soopahfly
PostPosted: Thu Dec 08, 2005 3:46 pm    Post subject: Reply with quote
I'm slightly concerned about this 39Poi limit.
I've not got my tomtom yet, and so far i'm not familiar with the terminology.
Does this mean I can only have the locations of up to 39 speed cameras?
Or does it refer to groups of POI's?
Pleas help clarify!!
EQtomtom300
PostPosted: Thu Dec 08, 2005 3:55 pm    Post subject: Reply with quote
No mate the POI limit of 39 means that you can have 39 different categories of places.
e.g
X amount of Gatsos at 50 1 slot
X amount of Petrol Stations is 1 slot
X amount of Gatsos at 40 is 1 slot
etc
You can have say for example 500 Mobile Cameras @30mph and this will only be one slot filled
Just remember its not the number of sites it's the number of different types of POI's
The PocketGPs Camera Site database takes up IIRC 23 slots if you use the different kinds of cameras and speed zones ie
Mobile 20,30,40,50,60,70 - 6 slots
Gatso 20,30,40,50,60,70 - 6 slots
Specs 20,30,40,50,60,70 - 6 slots
Redlight - 1 slot
Temp or TBC - 1 slot
Continental - 1 slot
All Gatsos - 1 slot
All Mobiles - 1 slot
All Specs - 1 slot
Still leaving you around 16 of your own to play with.
Make things any clearer?
EQ
soopahfly
PostPosted: Thu Dec 08, 2005 4:01 pm    Post subject: Reply with quote
Spot on, thanks matey!!
PostPosted: Thu Dec 08, 2005 4:21 pm    Post subject: Reply with quote
Generally yes, well said... except
1) You'd probably not want to have the speed-zoned AND the all-in-one versions at the same time, they would conflict
2) Your list is a bit out of date now. The complete download consists of:
Gatso 20, 30, 40, 50, 60, 70, tba and var
Mobile 20, 30, 40, 50, 60, 70 and tba
Specs 20, 30, 40, 50, 60, 70 and tba
All Redlight
All Temp
All Continental
All Gatso
All Mobile
All Specs
and Everything, all-in-one
Before the Specs were sorted into speed-zoned files as well, a common set to use was:
All Redlight
All Temp
All Specs
which means using up 18 categories.
If you use the speed-zoned Spedcs as well it's 24 slots.
Page 6 of 7
23.104 (22 Oct 25)
