| Author |
DavidW Pocket GPS Moderator
Posted: Sun Sep 14, 2003 8:04 am Post subject: Navigator 2 Map Errors |
Russ,
I'd mentioned the A6 Clapham Bypass (Paula Radcliffe Way) at the top of page 5 of this thread.
It's a hard choice with forthcoming roads. I think this one is simply a case of the maps being correct at the time of release (the data is supposedly correct at December 2002), but they have become outdated by the new road opening.
If a forthcoming road were put in the map, then Navigator would try to route along it before it was open. It's also the case that there are sometimes minor changes between the published plans (at least so far as they make it into road atlases as 'under construction') and what is eventually opened.
I think this particular one shows the value of buying the periodic map updates - though maybe someone can figure out a really good way of handling roads known to be "under construction".
David |
| Back to top |
mstockha Occasional Visitor
Joined: 10/02/2003 16:33:03 Posts: 54 Location: United Kingdom
Almost all of the development that I live on (8 years old and counting) is missing. It appears on the 2003 V of Autoroute (launched Nov) so I stupidly asssumed it would be in Navigator 2! Its KingsHill, West Malling, KENT. Oh well, in the next version perhaps..... _________________ Why me?
ipaq 3630, Pretec CF GPS, Ipaq 5550 Fortuna Slim GPS, TTNAV 5.10 w traffic , SPV C500 |
| Back to top |
..and also on the M25 / M20 Juntion (the sliproad from the M25 ontoto the M20 clockwise) Navigator ignores the sliproad and directs you to use the next roundabout instead, it gets you there, but isn't really a good choice
TTN2.24 GPS 2.08 iPaq 5555 Lexar 256SD Danelec 256CF Pretec CompactGPS with Ant Trafcam Checkpoint and too many cables _________________ Why me?
| Back to top |
superkev6969 Occasional Visitor
Joined: 17/07/2003 21:30:54 Posts: 15 Location: England
Highlands Grove, Great horton, BRADFORD, BD7 4BG is shown as in Buttershaw, BRADFORD which is incorrect.
Kev _________________ superkev |
| Back to top |
russgunn Regular Visitor
Joined: 15/08/2003 19:24:12 Posts: 223 Location: United Kingdom
Sorry David, didn't spot your A6 post at p.5!! My eyes were getting sore by p.3 so I jumped to the end to post!
May be worth mentioning at this point that there is also another new section of the A6 just opened. The Rushden/Higham Ferrers bypass.
It would be good if the software developers could think of an efficient and fast way of updating, without any charge to us, for say 12 months after purchase. I'm sure there is a better way for us to help them as well. How about some sort of record/stop button which the user presses at the beginning and end of the new road? This file is then automatically sent to the manufacturers by us when we sync. They then get confirmation of this new road from the local planning depts from the co-ordinates in the file, and then update their data. Perhaps a small yearly charge to cover all updates would be better than paying for a one off download and then finding out another road has been opened the next day! The system above would be a bit like the MS Windows XP Help and Support Centre where it scans your files and folders and shows you what you've downloaded in the past and what you need to keep up to date.
How much are the periodic map updates by the way? Does everyone pay, even those who may have just bought software? |
| Back to top |
Russ,
No worry on not spotting the previous suggestion of Paula Radcliffe Way. You're quite right about the other new A6 sections as well.
Your suggestion of a CheckPOInt type screen you can bring up seems quite sensible - you could have various options (junction wrong shape, no left/right turn allowed, left/right turn allowed when mapping doesn't show it, missing slip road, new road, road in wrong place, roundabout added/deleted - possibly many more, with, of course, an Other option that you can come back to later and annotate manually) and the ability to submit the file for the attention of the map data supplier. Whether we'll see it implemented is another matter!
Periodic map updates - for TomTom Navigator, the only set so far were in the update from Navigator 1 to Navigator 2, which cost, if I remember rightly, 40 Euros.
David |
| Back to top |
Guff Occasional Visitor
Joined: 05/09/2003 16:29:36 Posts: 13 Location: United Kingdom
| A507 Stotfold Bypass in Bedfordshire is mis-plotted. The road is on the map, but offset from the real road. |
| Back to top |
Oldie Pocket GPS Moderator
Joined: 22/11/2002 13:33:48 Posts: 992 Location: Surrey, UK
The A417, going East, between M5 Junction 11A and the roundabout at the junction with the A46 is mis-plotted. The TTN position for the road is too far to the South. Navigator jumps back to the true track on the slip road of the A46 roundabout and issues a message to rejoin the main road when you are already on it. Cross-referencing the position of the road in Navigator with that shown in AutoRoute 2001 shows the difference quite clearly.
Also quite often on the A417/A419 to Swindon, Navigator failed to track the road correctly even when showing 7/8 satellites. |
| Back to top |
Ginger Lifetime Member
Joined: 02/07/2003 18:39:46 Posts: 38 Location: Warrington UK
Posted: Fri Oct 10, 2003 3:04 pm Post subject: |
Oaklands Avenue LS16 8NR is missing from database; approx 6 years old _________________ Alan |
| Back to top |
Posted: Mon Oct 13, 2003 5:31 pm Post subject: Navigator 2 Map Errors |
Travelling west on the M62 and leaving at J16 to the end of the slip road, Tom Tom instructs to turn left and then U turn to turn right. This is incorrect as a straight right turn is possible. _________________ Alan |
| Back to top |
DaveBrown Occasional Visitor
Joined: 22/08/2003 13:18:19 Posts: 2 Location: United Kingdom
Posted: Fri Oct 24, 2003 1:25 pm Post subject: |
Baker Street and New-England Hill in Brighton are one way streets, but in the opposite direction than the Tom Tom Map.
The New Forest road system is appaling, hardly any roads are named and there are a few phantom A roads on the map which don't exist. |
| Back to top |
M@rtin Occasional Visitor
Joined: 21/12/2002 13:16:54 Posts: 11 Location: United Kingdom
Posted: Sat Oct 25, 2003 10:46 am Post subject: |
| Hyde in Cheshire isn't listed at all; to find my street I need to search on either Denton, which is a neighboring town smaller than Hyde, or on Tameside, which is the local council district! |
| Back to top |
frmarcus Occasional Visitor
Joined: 02/02/2003 12:25:09 Posts: 40 Location: Somerset
Posted: Mon Oct 27, 2003 7:29 pm Post subject: |
| Any idea when a TTN2 map update may be available? Having recently upgraded from TTN1 to 2, I'd be very irritated to have to pay for an update when there are glaring omissions. |
| Back to top |
Dave Frequent Visitor
Posted: Mon Oct 27, 2003 9:00 pm Post subject: |
Current UK maps were updated by TeleAtlas in December, they didn't hit TTN2 until March/April time, so I would expect a simiar arrangement going forward. [Mike hates me when I use that phrase]  |
| Back to top |
PeteB Occasional Visitor
Posted: Mon Oct 27, 2003 10:07 pm Post subject: Re: Navigator 2 Map Errors |
I got this on the same stretch, and on 3 other roads. If you use demo mode on that stretch of M11 it does it too.
PeteB
Luton, UK
| iancjc wrote: | M11 northbound between harlow and stansted, last night I was told to keep left keep right keep left keep left keep righ etc etc for apprx 1.5 miles.
Great advice if I was a nutter in a Kilt running up the main straight at Siverstone but not much use on a straight (& cone free) piece of motorway.
Not sure if this did this in an earlier version of TTN2 (I'm pretty sure it didn't but could be wrong).
Ian
ipaq3850, pretec cf gps-lp, 256mb sd card. |
| Back to top |
| Back to top |
