| View previous topic :: View next topic   |
		| Author |
		speedy_ste Occasional Visitor
				 Posted: Wed Dec 07, 2005 10:03 pm    Post subject:  |
				| can the safety cameras be downloaded to the tom tom go 500 with version 5.201 thanx |
		| Back to top |
  Joined: 30/12/2002 17:36:20 Posts: 4923 Location: Oxfordshire, England, UK
				 Posted: Thu Dec 08, 2005 1:49 am    Post subject:  |
				Hi speedy_ste,
  to the forum!
 	  | speedy_ste wrote: | 	 		  | can the safety cameras be downloaded to the tom tom go 500 with version 5.201 thanx |
Yes it can.
There are some guides that should be read (in the following order):
  The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
  How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
  How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Garmin Camper 770 LMT-D |
		| Back to top |
		YaYo Occasional Visitor
				 Posted: Fri Dec 09, 2005 12:13 pm    Post subject:  |
				| Hi everyone, im really new to all this, does anyone know if the speed camera software would be compatible with viamichelin gps sofware on a Palm Zire 31, just brought the bundle today and was wondering if i could take advantage of this software??? Sorry im a bit of a noob  when it comes to things like this. Thanks |
		| Back to top |
		Darren Frequent Visitor
				 Posted: Fri Dec 09, 2005 12:15 pm    Post subject:  |
				I don't 'think' ViaMichelin supports custom POIs so the answer is no sadly. _________________ Darren Griffin |
		| Back to top |
		drfox Occasional Visitor
				 Posted: Fri Dec 16, 2005 3:34 pm    Post subject: Tom Tom One |
				I was just wondering, does anyone know if the Tom Tom One support the speed camera database?
Cheers |
		| Back to top |
				 Posted: Fri Dec 16, 2005 3:49 pm    Post subject:  |
				Hi drfox,
  to the forum!
Yes the TomTom One can use the PocketGPSWorld camera database. You did read the few previous posts didn't you?
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
  The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
		| Back to top |
		dejaycejay Occasional Visitor
  Joined: Jan 01, 2006 Posts: 13 Location: Bedfordshire
				 Posted: Sun Jan 01, 2006 10:40 pm    Post subject:  |
				Hi All. Happy new year!!
Today a friend bought a tom tom 300. I told him I could put the cameras on it....They work on mine...I have software version 5.201.
His has version 5.410.   The camera database and/or the voices totaly screwed up the way the software worked.  The icons in \change preferences were swapped with their titles. Is the new software very new? Untested? Have tom tom changed things so that the current database wont work? Will the only camera database be available from tom tom? (via the paid for plus service).
Regards all, Clive. |
		| Back to top |
		Oldboy Pocket GPS Moderator
  Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
				 Posted: Mon Jan 02, 2006 12:16 am    Post subject:  |
				The camera database will work the same, with ov2 and bmp files.
The only thing that you have to be careful with is lack of free memory on the SD Card.  Try deleting any unused Voices.
Did you mean that the Camera Warning Voice was at fault?
Have you donwloaded the correct data.chk file for 5.410, as it is different to the one you use on 5.201?
5.420 is the latest version. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
		| Back to top |
				 Posted: Mon Jan 02, 2006 1:10 am    Post subject: new software? |
				Many thanks, I'll look into that. I did free up some memory (voices and licence text files) but it was all the titles under the icons that had been swapped around!!  This only happened when I loaded ovl and bmp files and the data.chk file and added ozzy in the voice folder.
Meybe it was the data.chk file.  I will play with it.
Regards, Clive. |
		| Back to top |
				 Posted: Mon Jan 02, 2006 10:31 am    Post subject:  |
				There have been a number of people having problems with the 'ozzie' voice.
If you do a Search for Ozzie you can have a look to see if that is causing your problem. _________________ Richard
		| Back to top |
		Desmo Occasional Visitor
				 Posted: Wed Jan 11, 2006 6:29 pm    Post subject:  |
				Hey people, I'm new here but read the forums if I need info and use the site as a whole for all my GPS reviews etc. Great work and keep it up :D
Anyhow, I was just wondering if it was possible to use an idea I have had. It may well have been asked before but I can't find anything in a search.
What I was thinking is that would it be possible to have just the .o2v files available for download in separate files rather than the main big zip file. And also to not include the .bmp images.
This way, I could access the relevant webpage via the internet browser on my mobile, download the required .o2v files straight onto the TomTom (or other) map I use. I can update from anywhere I want then, rather than having to download the entire large zip, sort what I want and then transfer to my phone.
Just and idea   |
		| Back to top |
		MikeB Frequent Visitor
				 Posted: Wed Jan 11, 2006 6:32 pm    Post subject:  |
				This is something we are currently working on. _________________ Mike Barrett |
		| Back to top |
				 Posted: Wed Jan 11, 2006 6:40 pm    Post subject:  |
				Ah cool. I'll look forward to it
I currently use the speed zoned files and it wold be great to be able to update  at anytime and from anywhere.
Was also going to post that it's great the amount of time and effort you guys put in to making this happen....FOR FREE. I think it's something a lot of people forget. Actually, it was something that I almost didn't post up my suggestion as I thought it might come across as being ungrateful for what you already do, hehe. |
		| Back to top |
		Pieman1972 Lifetime Member
  Joined: Jan 17, 2006 Posts: 68 Location: Waterlooville - Hants - UK
				 Posted: Tue Jan 17, 2006 5:47 pm    Post subject:  |
				Hi  - I've trawled through all this thread (plus others....) I have one of the Micromaxx MDPPC150 units with Navgon 5 on.
I'm would like to get the Speed camera database provided on the site onto my machine - can anyone point me in the right direction (no pun intended)....
Thanks in advance..... |
		| Back to top |
				 Posted: Tue Jan 17, 2006 6:33 pm    Post subject:  |
				Take a look here for advice on how to achieve this. _________________ Darren Griffin |
		| Back to top |
				 Posted: Today    Post subject: Pocket GPS Advertising |
  Have you considered  making a donation towards website running costs?. Or you could disable your ad-blocker for this site. We think you’ll find our adverts are not overbearing!
		| Back to top |
