Pocket GPS World :: View topic - New Problem !
New Problem !
Goto page Previous  1, 2, 3
timanfiya
PostPosted: Fri Feb 10, 2006 7:37 pm    Post subject: Reply with quote
What version are you currently on. I can send you the files you need to get up to 5.1.145 just PM me your email if you want it.
Goodmans GNAV10
WinCE 4.20(0)
OEM: Centrality Communication Inc
Destinator OP v 5.1.174
safetyman
PostPosted: Sun Feb 12, 2006 12:31 am    Post subject: Reply with quote
Ive just upgraded my sd card in my gnav 10 all i done was took the small one out of the unit connected to the pc inserted new card powered on unit and pc then loaded maps to new larger card through des consol works fine and i now have my uk and euro maps on one card.
Regards
Safetyman
View user's profile Send private message Yahoo Messenger
mike1954
PostPosted: Fri Apr 07, 2006 9:40 am    Post subject: Reply with quote
i have tried 3 brand new SD cards, all formatted thru my card reader as FAT, same as card that came with gnav10, and every time gnav10 says "card removed, closing down". i therefore suspect that the format is wrong, but how on earth do i get beyond it? the supplier says it should accept new cards, and no more help.
alanf
PostPosted: Fri Apr 07, 2006 10:24 am    Post subject: Reply with quote
I'm an Acer user, not gnav10, but I'm puzzled why you're formatting SD cards. Have you tried a card without formatting it first?
These cards come pre-formatted and have a limited number of writes (OK it's thousands but it is limited). if you keep formatting you're shortening the life of the card. As you may have found, formatting an SD (or CF etc) card can be risky.
mike1954
PostPosted: Fri Apr 07, 2006 11:59 am    Post subject: Reply with quote
all 3 new cards would not work at first, so supplier said to format them, and see if that worked. it doesnt make any difference at all, so im at a loss with it
Page 3 of 3
24.034 (25 Mar 26)
