| Author |
bumpkin Frequent Visitor
Joined: Feb 08, 2006 Posts: 264 Location: Herefordshire
Posted: Thu May 04, 2006 10:42 am Post subject: |
| Spenk wrote: | | I have sent an email to Garmin asking if there is anyway of telling if the i3 is receiving EGNOS, and also if they know the current operational status and whether losing the signal with EGNOS enabled would cause a temporary loss of signal or whether the unit reverts to manual mode. If I get a reply I'll post it here. |
I had always assumed (maybe incorrectly) that the EGNOS signal is a correction on the regular GPS signal and not an entirely separate system. It's absence just results in regular GPS accuracy.
I've never noticeably lost signal (other than tunnels etc.) and run EGNOS all the time.
Maybe I'm wrong though... _________________ Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10 |
| Back to top |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15506 Location: Bradford, West Yorkshire
Posted: Thu May 04, 2006 10:57 am Post subject: |
| bumpkin wrote: |
I had always assumed (maybe incorrectly) that the EGNOS signal is a correction on the regular GPS signal and not an entirely separate system. It's absence just results in regular GPS accuracy. |
that was my assumption too... |
| Back to top |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 707 Location: Monmouthshire
Posted: Thu May 04, 2006 11:54 am Post subject: |
| MaFt wrote: | | bumpkin wrote: |
Yes and it use up two of the available channels (assuming a 12 channel receiver) looking for the unpredictable/unreliable EGNOS sats that would be better employed looking for the more readily found normal ones which given the fact that the correction is so small could mean that having it enabled may lead to not being as usefull as some would hope. Thats my theory/observations anyway
Dave _________________ TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest |
| Back to top |
mhb Regular Visitor
Posted: Thu May 04, 2006 6:07 pm Post subject: |
| I've never tried this but wouldn't the 'Satellite View' got at via the 'Diagnostics' menu show when WAAS/EGNOS is in play. With the eTrex a 'D' shows for the particular satellites? |
| Back to top |
Posted: Thu May 04, 2006 7:23 pm Post subject: |
| the i3 only seems to show info on 1 satellite in daignostics view... |
| Back to top |
Anita Pocket GPS Moderator
Posted: Thu May 04, 2006 7:33 pm Post subject: |
| MaFt wrote: | | the i3 only seems to show info on 1 satellite in daignostics view... |
Sorry, MaFt, you've lost me
How do you get to diagnostics view, please? _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
| Back to top |
Wildie Occasional Visitor
Posted: Thu May 04, 2006 8:11 pm Post subject: |
how does one get into dianostic mode on the I3 then _________________ tom tom start 25
Waze |
| Back to top |
mhb Regular Visitor
Posted: Fri May 05, 2006 7:47 am Post subject: |
| Turn the i3 on by holding down both left and right buttons. This loads a screen which includes tests for ROM, RAM and ASIC. When these tests are 'passed', press the left button to load a second screen which, amongst others, includes the heading 'Vbattery'. Now press the left button then the right button then rotate the wheel button both up and down and finally press it. This results in a 'Press OK for diagnostics menu' message. Press the wheel button to display the diagnostics menu then scroll to highlight 'Satellite View' and press the wheel button. Voila! |
| Back to top |
Posted: Fri May 05, 2006 10:44 am Post subject: |
Thanks for your help, mhb.
Thought I hadn't RTFM properly, but can still find no reference to diagnostic mode.
What a lot of information's hiding in there! Pity I can't understand most of it 8O _________________ Anita
UK map 1130.12368
| Back to top |
Posted: Fri May 05, 2006 11:36 pm Post subject: |
great thanks _________________ tom tom start 25
Waze |
| Back to top |
Jamas Regular Visitor
Joined: Mar 02, 2006 Posts: 76 Location: Toulouse-France
Posted: Sat May 06, 2006 10:45 pm Post subject: |
| mhb wrote: | | Turn the i3 on by holding down both left and right buttons. This loads a screen which includes tests for ROM, RAM and ASIC. When these tests are 'passed', press the left button to load a second screen which, amongst others, includes the heading 'Vbattery'. Now press the left button then the right button then rotate the wheel button both up and down and finally press it. This results in a 'Press OK for diagnostics menu' message. Press the wheel button to display the diagnostics menu then scroll to highlight 'Satellite View' and press the wheel button. Voila! |
Thanks for the trick but I am stuck in the satellite view as the display seems frozen with no satellite shown. Is there another trick to make this display alive ?
Jamas _________________ SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+ |
| Back to top |
Spenk Occasional Visitor
Posted: Sun May 07, 2006 1:20 am Post subject: |
Ah - the old addage - never assume, check For those of you wondering how EGNOS works, then I suggest clicking on the link in one of my previous posts in this thread, which will take you to the EGNOS website where they give a description of what the system is and how it works. To summarise - the correction data is transmitted by 3 EGNOS satellites (only one of which is over Europe), with EGNOS enabled receivers being able to receive these signals and use them appropriately. The data includes current positions of GPS and GLOSNAS satellites as well as the accuracy of their atomic clocks and how accurate the data coming from those individual satellites is.
If anyone has changed from NORMAL to WAAS/EGNOS you will notice that the unit reverts to looking for satellites again - this was my question about what happens if it loses the EGNOS signal.
I am still waiting for an answer from Garmin, but if they do manage to reply then I will post the answer under this thread. |
| Back to top |
matb Frequent Visitor
| Back to top |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Sun May 07, 2006 11:42 pm Post subject: |
| Spenk wrote: | | what happens if it loses the EGNOS signal. |
If you lose your view of the EGNOS satellite then the GPS will keep using the last known correction data for a few minutes and eventually switch back to non-EGNOS mode if it can't reaquire the EGNOS satellite fix. _________________ Gone fishing! |
| Back to top |
Posted: Sun May 07, 2006 11:51 pm Post subject: |
| Skippy wrote: | | Spenk wrote: | | what happens if it loses the EGNOS signal. |
If you lose your view of the EGNOS satellite then the GPS will keep using the last known correction data for a few minutes and eventually switch back to non-EGNOS mode if it can't reaquire the EGNOS satellite fix. |
Thanks for the reply Skippy. Not wishing to sound rude , but is that statement made from an educated guess or from known information? It will save me having to wait for Garmin to email an answer (if they ever do!!). |
| Back to top |
| Back to top |
