Pocket GPS World :: View topic - i3 mounts
i3 mounts
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Dilcymro
PostPosted: Sun May 07, 2006 7:56 pm    Post subject: Reply with quote
You`re all too kind, I`ll try no 4 again, like I said , I have now removed the velcro and the cables and covered the hole. I think I will just about get my phone on there aswell Mat.
[img]
See if it works this time, thanks again....DIL[/img]
matb
PostPosted: Sun May 07, 2006 10:35 pm    Post subject: Reply with quote
dil
why have you removed the cables from the console ? it looked perfect to me from close up pic 4 Confused is this a full time ammendment.
would also like to see the fully finished article with the mobby sited below the i3 with the added bonus of its power supply in situ, all wires connected to both items, as it were Wink
i hope mr.g is pleased with the images to date. come on andy give us some feedback :D
707
PostPosted: Mon May 08, 2006 10:28 am    Post subject: Reply with quote
Mr G is so good with his balls! Wink and what service
8)
Thanks very much, orderd Thurs, and package was there when I got home Fri.
The dog had chewed the package, but Mr G's balls are made of strong stuff and no damage was done (just hope that it didn't hurt) Wink
Colin
Garman i3, Nuvi 300. and now a dissatisfied owner of a Nuvi 3598 LMTD
Mr_Gonzales
PostPosted: Mon May 08, 2006 10:50 am    Post subject: Reply with quote
Yep - I'm very pleased! It's nice to see what people can do with such a simple part. It's growing quite big now - not just on here but elsewhere, to the point where I suspect it can't be long before Garmin or Ram-mount start sniffing about. But until then... keep up the good work!
bumpkin
PostPosted: Mon May 08, 2006 12:02 pm    Post subject: Mr G's balls of steel Reply with quote
Mr G made a custom adaptor to mount my i3 on my bike using a Ram mount. This gives great positiong flexibility as I use an exapnding tank bag but want to obscure the intruments as little as possible. Additionally removal as an assembly is very quick and a very in-obtrusive Ram ball is all that remains. When I eventually get a higher spec GPS I'll already have the bike mount as the Ram will take whatever I eventually choose.
In short, although it's only a part of the solution, Mr G's stainless 1 inch to 17mm adapter looks good, is durable and performs as well as anticipated. Cost about half the price of the i3 all in including the Ram bits but is rock solid and just what I was looking for.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
Mr_Gonzales
PostPosted: Thu May 11, 2006 1:29 pm    Post subject: Reply with quote
Shameless plugging but there's now a website at http://www.mounts.pwp.blueyonder.co.uk/ with more pics on. Some of you may see yourselves on there!
Andy
Spaceliner
PostPosted: Thu May 11, 2006 6:49 pm    Post subject: Reply with quote
Thanks to Mr G I have been able to make a custom Garmin i3 dash mount in my 306.
This is my first attempt at posting photos so I hope it works...
The first step was to drill and tap an M6 hole in the dash, I couldn't work out how to remove the vents but could see that there was a web just behind where I wanted to mount the i3, this was ideal as it would be stronger. I started with a 2mm drill, then 3.5 then 5mm before tapping a thread to about 15mm deep. I ground the point off of the plug tap so that the thread went right to the end of the hole:
I cut about 30mm of thread from an M6 bolt, deburred the cut end and threaded it into one of Mr G's black Delrin balls, slipped a 10mm length of black plastic pneumatic hose onto the exposed thread and screwed it into the dash:
The result is nice and firm and doesn't look out of place amongst the extra controls for the Inforad etc...
With the i3 mounted here I can still see the stereo, use the vents, access all existing switches and reach the i3 with ease (not whilst driving of course).
one challenge I had was working out how to remove the i3 from the ball, I knew I didn't want to tug on the dash as eventually something would break and I would have a pair of vents hanging from the back of my i3. I found that if I mounted the ball 10mm from the dash it would pivot up far enough for the ball to pop out of the socket without a risk of breaking anything.
matb
PostPosted: Thu May 11, 2006 7:00 pm    Post subject: Reply with quote
Andy
andy great web site Exclamation
if i may be as so bold to make one observation Question
pic 1 and 2 of dils "a" pillar mounting, as spectacular as they are, do not show your work hence selling yourself short.
i am not suggesting that you show my rather crude adventure but other examples showing the famous mr. g ball may be more beneficial.
all said and done "if you got it flaunt it " Wink
Dilcymro
PostPosted: Thu May 11, 2006 8:22 pm    Post subject: Reply with quote
Hi all,
Good site Andy, but as Matb said, the photos of my A post mount are not really suitable as I used the original garmin suction mount so do not show the expertise in your balls. You are quite welcome to use the console shots if they are any good for you and I should have a couple more in the next day or so and seeing as its you I will waive the copyright on them .
Have you noticed how nice and quiet it`s been on here all week and then all of a sudden....Mat`s back and stirring thing`s already!!!!!
Regards...Dil
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
matb
PostPosted: Fri May 12, 2006 8:19 am    Post subject: Reply with quote
yes thats right dil.
sent to one job in four nights Laughing
andy, i saw one of your bike mounts yesterday on a work mates bike, very impressed. the person who had it previous had it made but luckly thay had the same sat nav.
Dilcymro
PostPosted: Fri May 12, 2006 1:20 pm    Post subject: Reply with quote
Hi all,
Here`s another couple of pics after a few modifications to the console. I have moved Mr G`s ball up a bit , put the cables back where they were and added a mobile phone holder.
First pick : set up
[img]
Second pick : all wired up with phone and i3 in situ
[/img]
Thanks for looking.....regards...Dil
matb
PostPosted: Fri May 12, 2006 2:11 pm    Post subject: Reply with quote
see i had faith in you dil Wink
looks very professional.
off the subject slightly, is the moby wired up with power as well, and is it blue toothed or ear piece. oh and does the sat nav throw a wobbly when the phone rings Question i know people will be thinking these questions and as i have not been on here for four days i must get my broadband usage up again Laughing
Dilcymro
PostPosted: Fri May 12, 2006 2:59 pm    Post subject: Reply with quote
Right mat, do you know I have been to the dentist with less pain than you give me!!
I can wire the moby up to the power if required via double adaptor.
It is capapble to be used with one of those "Borg" things stuck on the side of your head , but no one calls me often enough for me to use one.
It can also be connected to a hands free connection/ earpiece but I dont use them either for the same reason as above.
When it has rung it didnt seem to make any difference to gladys (i3)
Is there anything else now, before I go to work. Have a look on my website in my profile, that will keep you quiet for five mins.
By the way, I`ve got a sticky now aswell, it`s bl**dy roasting down here!!
Regards...Dil
I have a feeling he`s going to ask now what a "Borg" is.
matb
PostPosted: Fri May 12, 2006 3:26 pm    Post subject: Reply with quote
dil
what's a "borg" thingy Laughing Laughing Laughing Laughing Laughing
diolch yn fawr Wink
Dilcymro
PostPosted: Fri May 12, 2006 3:32 pm    Post subject: Reply with quote
Is that a serious question Mat!!!!!
Didnt know you could speak welsh, maybe we can have a welsh language
page on the forum them. ( we shall now wait for the flak )
Regards...DIL
Garmin Nuvi 2415
Page 7 of 8
24.041 (01 Apr 26)
