| Author |
sleepy184 Occasional Visitor
Posted: Tue May 30, 2006 3:01 pm Post subject: |
Are there any bridges in your database under 9ft? If so, I would be interested in a copy of it please.
Thanks |
| Back to top |
antonini Occasional Visitor
Posted: Fri Jun 02, 2006 6:01 am Post subject: thanks....... |
thanks for the info mullet.....I have created my warning as you suggested but don't know how to convert it to OGG format?? as I do not have soundforge audio or any programs like that.......can you suggest something that will do the job that I can download.....??
By the way.....I already have all the speed camera voices.......just need to add one for the bridges......do I need to replace the whole data file with a new one containing the whole lot or can I just add the new one to it??
cheers
Toni |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
| Back to top |
Mullet Frequent Visitor
Posted: Fri Jun 02, 2006 1:46 pm Post subject: Re: thanks....... |
| antonini wrote: | thanks for the info mullet.....I have created my warning as you suggested but don't know how to convert it to OGG format?? as I do not have soundforge audio or any programs like that.......can you suggest something that will do the job that I can download.....??
cheers
Toni |
Oldboy's link for the file conversion.
Load your Data.chk into POIExtend and add the warning, though this can be done as you say by just editing, I would check and varify the whole of the warning prompts for what little time it takes. |
| Back to top |
neil01 Frequent Visitor
Posted: Fri Jun 02, 2006 4:12 pm Post subject: |
A great compilation, but is there any chance of a file with the information in height order, so that those of us without one of the supported products, but with a bit of knowledge, could create our own suitable files.
We could also pass them back once we had done that, if required. |
| Back to top |
Posted: Sat Jun 03, 2006 4:09 pm Post subject: help |
hi guys........I've created my voice file which plays at the right speed and then converted it to OGG format using the program richard suggested and put it into Poiextend but when I play it on there it sounds like mickey mouse at 100 speed. I found a topic on this earlier but now cannot find it anywhere.......how do I slow it down to play correctly??
cheers
Toni |
| Back to top |
Posted: Sat Jun 03, 2006 4:14 pm Post subject: not to worry |
| sussed it myself guys.........cheers |
| Back to top |
Posted: Sat Jun 03, 2006 5:50 pm Post subject: Re: not to worry |
| antonini wrote: | | sussed it myself guys.........cheers | Care to share what you did to sort it out for the benefit of others? - was it the sample speed 22050Hz set wrong per chance? - Mike |
| Back to top |
Posted: Sat Jun 03, 2006 9:02 pm Post subject: yeah of course |
yeah sorry....of course.......still had a couple of problems.....!
Use the link above from oldboy
choose "settings" from the menu boxes along the top and then choose "OGG settings" from the tabs....
I am using tom tom navigator 5 on a pda so I picked 16000khz at 96 Kbps from the drop down menus
choose "mono" from the other drop down menu and then do the convertion
copy this over into POIextend and all should be ok when you play........
I used "ATTENTION!! Low bridge ahead" and wanted to get more emphasis on the word attention and put loads of exclamation marks after the word.....had to delete them down to 2, otherwise the final message on the PDA came out as "attention".......and nothing else.......
As I had the voice speed camera warnings already on the PDA which I had downloaded elsewhere in the forums I loaded this data.chk file into POIextend and just replaced the "polite 3 message"(the credits").....sound 15 on my version with the new OGG file and created a new data.chk file. This was then used to replace the original speed camera file on the PDA(found in navigator)........
All the original camera warnings stayed as they were.......and "polite 3" became the bridge warning message.......
Note.....you only get 8 or 9 trial goes with the link from oldboy to convert your wav file to an OGG one.........then I'm guessing that you have to buy it..........!!
Hope this helps........
Toni
Toni
hope this helps |
| Back to top |
cdalmeida Occasional Visitor
Posted: Sun Jun 04, 2006 3:15 am Post subject: |
Robin:
Amazing work you've got at your website. I downloaded a couple of programs and hopefully I will have the time to understand how POI works on the TomTom. I have just bought a TomTom 910 and am very excited about its capabilities. I will be going to Italy in a few days and was wondering if you know any POI files covering Italy for download.
Best regards. |
| Back to top |
| Back to top |
