Pocket GPS World :: View topic - Windscreen mount stuck fast
bernie_rubber
PostPosted: Sun Jun 25, 2006 10:12 am    Post subject: Windscreen mount stuck fast Reply with quote
Hi...in comparison to some who have problems with the mount falling off the windscreen...mine's get molded on...I haven't been able to get it off and had to remove the i3 by pulling it out of the ball and socket joint...leaving the mount on the windscreen.
I've now had a chance to try harder to get it off...but that's just caused some damage to the mount...if I continue I'm going to leave some of the mount on the windscreen and the rest torn on the mount - it obviously needs replacing....will garmin replace do you think...and of not what sites do you recommend for a replacement?
Garmin i3
Firmware 3.3
Audio 2.5
sfcman
PostPosted: Sun Jun 25, 2006 2:37 pm    Post subject: Reply with quote
Have a look at http://www.globalpositioningsystems.co.uk/garmin-vehicle-suction-cup-replacement-for-streetpilot-i-seriesnuvi-description.html?PHPSESSID=d8774e8ae7bc9ac4bc5604f9cc5100df
bernie_rubber
PostPosted: Sun Jun 25, 2006 3:37 pm    Post subject: Reply with quote
Thanks...used the link and got it on order now!
Now just need to avoid the same problem again Confused
Garmin i3
Firmware 3.3
Audio 2.5
timber
PostPosted: Sun Jun 25, 2006 3:49 pm    Post subject: Re: Windscreen mount stuck fast Reply with quote
bernie_rubber wrote:
Hi...in comparison to some who have problems with the mount falling off the windscreen...mine's get molded on if I continue I'm going to leave some of the mount on the windscreen and the rest torn on the mount - it obviously needs replacing....will garmin replace do you think...and of not what sites do you recommend for a replacement?
Contact Garmin
Garmin (Europe) Ltd. Unit 5, The Quadrangle
Abbey Park Industrial Estate
Romsey, Hampshire
SO51 9DL, UK
Phone: 44 1794-519944
0808 2380000
Fax: 44 1794-519222
I'm sure they will send you a replacement out FOC if not then the link in the previous post is the cheapest (I can remember searching when the original post was made)
When you were trying to remove you were pulling/lifting the little tab Question when mine was new once had to use my finger nail to lift the edge of the rubber to break the seal, been ok ever since.
p4ult
PostPosted: Sun Jun 25, 2006 3:50 pm    Post subject: Reply with quote
Are you pulling the little rubber flap at the bottom?
This helps break the suction
bernie_rubber
PostPosted: Sun Jun 25, 2006 4:42 pm    Post subject: Reply with quote
Thanks for additional info...
Yes I released the lever and then tried to pull the rubber tab...but it didn't budge it...I tried to loosen it...but as it finally started to come away it left a small residue of some of the rubber suction mount on the screen...then began to tear - so stopped at that point till I had some form of a replacement!
Garmin i3
Firmware 3.3
Audio 2.5
PaulB2005
PostPosted: Mon Jun 26, 2006 9:16 am    Post subject: Reply with quote
How long had it been on the windscreen?
bernie_rubber
PostPosted: Mon Jun 26, 2006 2:11 pm    Post subject: Reply with quote
@PaulB2005
Only about 3-4 weeks (taken it off once previously)
Garmin i3
Firmware 3.3
Audio 2.5
bernie_rubber
PostPosted: Mon Jun 26, 2006 2:31 pm    Post subject: Reply with quote
Just been on the phone to Garmin...who have told me they'll pop one in the post and should be with me tomorrow or the day after - can't complain at that!
Cancelled my other order...thanks guys!
Garmin i3
Firmware 3.3
Audio 2.5
timber
PostPosted: Mon Jun 26, 2006 3:29 pm    Post subject: Reply with quote
If this is true Exclamation then when your new mount arrives I don't think you will have the same problem again (you won't have them long enough).
Have you not heeded the warnings about leaving the Gps or Mount in view when the vehicle is un-accompanied, you have been lucky the vehicle has not been broken into and its not been stolen, you might not be next Exclamation time
bernie_rubber
PostPosted: Mon Jun 26, 2006 5:14 pm    Post subject: Reply with quote
[quote="timber"]
I never said it was unaccompanied! Driving But I take your point! Wink
Garmin i3
Firmware 3.3
Audio 2.5
Lester_Burnham
PostPosted: Mon Jun 26, 2006 5:27 pm    Post subject: Reply with quote
[quote="bernie_rubber"]
Do you live in your car, then? ;-)
Or do you just kennel a ferocious dog in there...
timber
PostPosted: Mon Jun 26, 2006 6:23 pm    Post subject: Reply with quote
Lester you have made my day Clap, brought back memory's of when we left our dog in the rear of the car while we went for breakfast in Wales. While we were away there was wild roaming donkies who used to come into the area searching for food. What happened next was they came up to the car and the dog went beserk to get out and get them.
The result was the roof lining parted company with the car, when looking in to the car it looked like a snow storm (those glass balls with liquid in you shake)
So moral to the story the ferocious dog may be better trained to give the thief the GPS rather than rip your car to bits protecting it!
bernie_rubber
PostPosted: Tue Jun 27, 2006 12:09 am    Post subject: Reply with quote
I'm afraid I can't disclose my counter measures...otherwise I'd have to Stop it! you
Garmin i3
Firmware 3.3
Audio 2.5
sherman
PostPosted: Tue Jun 27, 2006 8:10 am    Post subject: Reply with quote
nice one bernie hehehe
24.034 (25 Mar 26)
