| Author |
gassy Occasional Visitor
Posted: Tue Nov 18, 2003 10:28 am Post subject: Speed indication? |
I'm a complete newbie to both GPS and Pocket PC. I'm very pleased with the Aldi package, and I've also downloaded the POI-Warner software.
I know that some GPS systems can show your road speed, and although I know my SAAB speedo is very accurate (1% - tested on a rolling road) I would be interested to find out what Medion - Navigator thinks it is. But this doesn't seem to be a display/programme option.
Am I missing something? Or do I need to buy another piece of software? |
| Back to top |
Roy Occasional Visitor
Posted: Tue Nov 18, 2003 5:29 pm Post subject: |
| I would like to know aswell. My speedo is out due to bigger wheels being installed. I thought it would be on the program but can't see it like you say |
| Back to top |
aero Regular Visitor
Joined: 12/03/2003 01:20:45 Posts: 121 Location: United Kingdom
| Back to top |
Dave Frequent Visitor
| Back to top |
Posted: Sat Nov 22, 2003 11:38 pm Post subject: |
| Is there a program which is free which tells you your speed? |
| Back to top |
Posted: Sun Nov 23, 2003 1:39 am Post subject: |
Crux View does, and it's free, but we need a Pocket PC guru to tell us whether it'll work with GPS receivers other than the Emtac wireless one.
I provided a link to it in my first post.
| Back to top |
Darren Frequent Visitor
Posted: Sun Nov 23, 2003 10:20 am Post subject: |
There are a few freeware GPS Info Utilities that will report speed but none will work in conjunction with your navigation software, it's one or the other I'm afraid as only one application at a time can communicate with the GPS COM Port. _________________ Darren Griffin |
| Back to top |
Posted: Sun Nov 23, 2003 11:32 am Post subject: |
| Quote: | | There are a few freeware GPS Info Utilities that will report speed but none will work in conjunction with your navigation software, it's one or the other I'm afraid as only one application at a time can communicate with the GPS COM Port. | yeah that would be fine. Only want to see what the speed works out like.
| Quote: | Crux View does, and it's free, but we need a Pocket PC guru to tell us whether it'll work with GPS receivers other than the Emtac wireless one.
I provided a link to it in my first post. | I downloaded that but had troble getting it working[/list] |
| Back to top |
Posted: Sun Nov 23, 2003 11:53 am Post subject: |
Try TomToms GPS Info Application. Get it at http://www.tomtom.com/support/ce/downloads/ppcgps207.zip
You'll need to configure the Medion GPS as 'NMEA 0183v2 4800' on 'COM1'
On the Status Tab if you have configured it correctly you will see a line of dots moving from left to right between the GPS and PDA Icons. Once a lock is acquired you will have Lat/Lon and Speed Readouts, you can switch between Km/H, MPH or even Kts! on the GPS tab. _________________ Darren Griffin |
| Back to top |
pronto Occasional Visitor
Posted: Mon Nov 24, 2003 6:56 pm Post subject: |
Tried that on my Aldi/Medion setup and it works perfectly. Reads about
3mph below the speedo - so I guess the speedo is reading high. Don't know what he accuracy of GPS is at about 30mph tho'?
Mike |
| Back to top |
Posted: Mon Nov 24, 2003 7:02 pm Post subject: |
Given a constant speed on level ground the GPS is as near accurate as you will get in a consumer device. Uneven acceleration or rapid changes in altitude will affect the accuracy.
If you drive at an indicated 30mph on the GPS then you will be as near to excatly 30mph as possible, of course using the speedo at least gives you a margin of error should you encounter our boys in blue or a safety camera one day  _________________ Darren Griffin |
| Back to top |
peeved Occasional Visitor
Posted: Tue Dec 16, 2003 6:38 pm Post subject: |
| Darren wrote: | Try TomToms GPS Info Application. Get it at http://www.tomtom.com/support/ce/downloads/ppcgps207.zip
On the Status Tab if you have configured it correctly you will see a line of dots moving from left to right between the GPS and PDA Icons. Once a lock is acquired you will have Lat/Lon and Speed Readouts, you can switch between Km/H, MPH or even Kts! on the GPS tab. |
I have downloaded this application and it works as stated on my Medion, there is one question I would like to ask, what does the blue arrow shown top right point to? |
| Back to top |
Posted: Tue Dec 16, 2003 7:04 pm Post subject: |
That is your direction of travel in relation to North with your bearing in degrees below that. So if you are heading due East the arrow would point to 3 'O' Clock and the heading would 90 degrees. _________________ Darren Griffin |
| Back to top |
Posted: Thu Dec 18, 2003 9:59 am Post subject: |
| Darren wrote: | | That is your direction of travel in relation to North with your bearing in degrees below that. So if you are heading due East the arrow would point to 3 'O' Clock and the heading would 90 degrees. |
Ah! Thank you very much, all is now clear!
Paul |
| Back to top |
dejongj Regular Visitor
Joined: 06/02/2003 23:17:38 Posts: 118 Location: United Kingdom
Posted: Tue Dec 23, 2003 11:11 am Post subject: |
| Roy wrote: | | I would like to know aswell. My speedo is out due to bigger wheels being installed. I thought it would be on the program but can't see it like you say |
Depending the car you have, it is quite easy to recalibrate. My 15 year old BMW has got the function on the board computer to 'correct' the speedo if you fit inappropriate tyres. Might be worth checking out as it is a lot safer to use your speedo to check the speed than a PDA. |
| Back to top |
| Back to top |
