| Author |
gidon Occasional Visitor
Posted: Fri Jul 21, 2006 2:27 pm Post subject: How to run Navigator and Memory-Map together on an Ipaq 6915 |
Firstly you need this free Port Splitter program:
http://gpsmeter.mobileground.com/
Run this program and select input port as "Internal AGPS NMEA" and baud to 57600. In the output box add two available COM ports (for me 0 and 2 come up). You may have to do a software reset first to clear them. Take a note of these two ports. Hit "Start Splitter".
Download something like this registry editor.
Edit HKEY_LOCAL_MACHINE\SOFTWARE\TomTom\GPSSettings and change the ComPortNumber to one of the COM ports noted above.
You then need to enable the (hidden) GPS control panel on the 6915 by editing the HKEY_LOCAL_MACHINE\ControlPanel\GPS "hide" value to 0. Then go into the control panel (Start|Settings|System|GPS) and click on the access tab. Clear the "Manage GPS automatically" checkbox. (TomTom doesn't pick up the split COM port without doing this).
Now GPS Navigation (TomTom Navigator) should run ok. To run Memory- Map or another GPS application just set it up to use the other split COM port.
Seems to work pretty well in my brief play with it.
Hope this helps someone.
Gidon |
| Back to top |
alix776 Pocket GPS Moderator
Posted: Fri Jul 21, 2006 2:48 pm Post subject: |
| Quote: | Download something like this registry editor.
the above only applies to mw05 pdas . wm2003/2003se doesnot have this built in port splitter so you have to use somehting like fanson's GPS gate _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
| Back to top |
Posted: Fri Jul 21, 2006 3:00 pm Post subject: |
aliz776 - sorry I don't quite understand? I am not using the built in capabilities - I'm using the linked Port Splitter. Are you saying I don't need this Port Splitter? Port Splitter is a free equivilent to GPS gate as far as I can tell?
Gidon |
| Back to top |
Posted: Fri Jul 21, 2006 3:03 pm Post subject: |
if the 69xx has wm05 then the unhidden gps icon on wm05 machines will act as a port splitter _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
| Back to top |
Posted: Fri Jul 21, 2006 4:10 pm Post subject: |
As I understand it, it doesn't make any difference having the applet hidden or not. The device by itself doesn't let TomTom and Memory-Map run at the same time.
I think the issue is WM 05 does support port splitting - but the applications have to understand it. TomTom and Memory Map don't appear to. They still both communicate with the hardware COM port not the program GPD port that I believe they would have to for port sharing to work.
Gidon |
| Back to top |
Posted: Fri Jul 21, 2006 4:34 pm Post subject: |
| gidon wrote: | As I understand it, it doesn't make any difference having the applet hidden or not. The device by itself doesn't let TomTom and Memory-Map run at the same time.
I think the issue is WM 05 does support port splitting - but the applications have to understand it. TomTom and Memory Map don't appear to. | Well I have Memory Map and TomTom running together using a WM2005 equipped device, one issue could be down to the actual provider of the Bluetooth stack loaded to the device the Microsoft stack will work this way, however the Widcomm equipped Ipaq's running WM2005 do not appear to support the feature, so the extra application may well be required to support these devices - Mike |
| Back to top |
Posted: Fri Jul 21, 2006 4:50 pm Post subject: |
| mikealder wrote: | | Well I have Memory Map and TomTom running together using a WM2005 equipped device |
Thats interesting - could you let me know the settings in Memory Map and if you've done anything special to get them working together? If I start TomTom and then start Memory Map - Memory Map says it's can't open the COM port. Does your device have integral GPS? Also what versions of TomTom and MM are you using?
Gidon |
| Back to top |
Posted: Fri Jul 21, 2006 5:10 pm Post subject: |
TTN is version 5,21 and the Memory map is the latest at version 5,0,6
The GPS device is a Bluetooth Holux GPSlim236, the PDA is an XDA-Exec (WM2005 with MicroSoft B stack).
When configuring the Bluetooth on the PDA I set the outgoing port to COM0
In the GPS Applet Hardware port is set to Com0, Program Port is COM4
Manage Automatically is ticked.
In TomTom I use "Other Bluetooth GPS" set to COM0
In Memory map I select the GPS to use COM4 - both applications will work fine on the device, I have it sat next to me at the moment having just configured it again, I couldn't remember the exact set-up , so I have re-created it, I hope this helps - Mike |
| Back to top |
Posted: Fri Jul 21, 2006 6:04 pm Post subject: |
Mike
Many thanks for that. I still can't get it working with the GPS applet alone. The main difference I see between my setup and yours is you are using MM 5 - I'm using 4.4.3. I can't check because all my maps are 2004 as well. Also could be something to do with the GPS being integrated?
The truth is although I'd like to get them working together without the hassle of my top post, I'm not sure I generally need them both working together and I imagine it must slow things down a bit.
Still I would still like to get to the bottom of it - may ring MM next week.
Thanks again,
Gidon |
| Back to top |
Posted: Fri Jul 21, 2006 6:22 pm Post subject: |
Ignore my last post! Just tried more combinations of program and hardware ports and read this Microsoft article properly which helped explained what it's all about!
Now it works just using the GPS applet!
For any 6915 users: hardware port is COM7, program port I used (has to be a free one) is COM0 - and this is the one your programs use. As a 6915 user you still need to show the GPS applet as above and change the TomTom COM port in the registry. But leave "Manage GPS ..." ticked.
Thanks all!
Gidon
(I guess HP don't want you doing this though - not sure why?) |
| Back to top |
Quantum Frequent Visitor
Joined: 16/02/2003 03:21:58 Posts: 285 Location: Seattle, Ecotopia
Posted: Sun Jul 30, 2006 6:20 pm Post subject: |
Hm, I am finding neither:
HKEY_LOCAL_MACHINE\SOFTWARE\TomTom\GPSSettings nor
... in my WM2003. |
| Back to top |
Posted: Sun Jul 30, 2006 7:20 pm Post subject: |
| Quantum, you will not find the GPS applet on a WM2003 based deveice, it is only found (or un-hidden) on devices using WM2005 as the operating system, for your device you can try the port splitter application mentioned at the start of this thread or try Fransons GPS gate program to feed multiple programs with the GPS data stream - Mike |
| Back to top |
| Back to top |
