Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3, 4 ... 75, 76, 77  Next
welshgasman
PostPosted: Sat Jul 22, 2006 10:59 pm    Post subject: anyone having problems.? Reply with quote
Having seen that a later camera file was available, I ran Camera Updater and it told me to load the new data.
This is where it all started to go wrong. App locked up all the time.
I tried a system restore to before I used the Camera Updater, still locked up. Great I thought, how am I going to track this down.?
Put the laptop back as it was. It is on XPH.
Then loaded POILOADER to my desktop (W2K), same problem.
Suddenly had an idea, as I keep the POIs in one folder and the cameras in another and I realised one replaces the other, and I was just trying to load the cameras.
Tried loading he POIs only, works fine.
Tried loading the cameras,.... locked up.
Anyone experienced this with the latest camera file download after conversion by the program.?
TIA
welshgasman
PostPosted: Sat Jul 22, 2006 11:29 pm    Post subject: Reply with quote
Further investigation.
POIs load fine on their own.
Cameras load fine on their own.
Cameras & POIs load fine as CSV.
Cameras converted to GPX with GPX converter.
POIs and those GPX files load fine.
Dragged camera zip file to Camera Updater (previous version), tried loading, locked up.
Ran new camera updater, it found and updated files, tried loading, locked up.
That is it for now, its late....
deesoft
PostPosted: Sun Jul 23, 2006 12:45 pm    Post subject: POI Loader Reply with quote
Hi, last night I used asshes program , it worked fine, then I THOUGHT I had a problem, POILoader seemed to lock up! Bu ti din't really, I decided to be patient and after many minutes it finally finshed. So try again and have a coffee while you are waiting. There seem to be many more Speedcams than my last download!
But the program seems great.
Ipaq hx2750, TTN5, Globalsat 338 GPS, Garmin Nuvi 310D and GTM12, TomTom GO910 and now GO540
God gave us the Integer, the rest was devised by man.
welshgasman
PostPosted: Sun Jul 23, 2006 2:34 pm    Post subject: Reply with quote
No it definately locks up, comes up with not responding.
This was all for info really as I have located the fault and can bypass it.
As it worked Ok, the very first time, I would *suspect* something different about the file, and how it ended up being converted.
deesoft
PostPosted: Sun Jul 23, 2006 10:07 pm    Post subject: Wrong posting Reply with quote
Hi Weshgasman, look at my topic POIloader (I posted a new topic instead of a reply, silly me)
Ash10
PostPosted: Sun Jul 23, 2006 10:40 pm    Post subject: Reply with quote
PaulB2005 wrote:
OK. Back to the problems i was having before and there definitely IS a bug. New database released 22 July. Camera Manager spots it and downloads it and the does nothing. Open and re-open CM several times. Nothing.
Until i change the value of one of the timings then and only then when hitting OK does it generate new GPX files.
Well spotted, and you're quite right 8)
After a new database is downloaded, the application spoofs a click on the OK button - which as we all know does nothing unless a setting has changed. D'oh Embarassed
Should get a new version out in the next day or two :D
FirebladeDreamer
PostPosted: Sun Jul 23, 2006 11:37 pm    Post subject: Reply with quote
I take it that dragging a previously downloaded zipped db is not an option with this new beastie Ash?
welshgasman
PostPosted: Mon Jul 24, 2006 7:07 pm    Post subject: Re: Wrong posting Reply with quote
If that was the case with my problem, I'd expect the bmp file to cause the same problem, no matter which program created the gpx files.
As long as I know of the problem, I can get around it easily. Whne the nect camera file is ready, I'll try again. The worry was 'what' had gone wrong, and how was I going to load in future.
Ash10
PostPosted: Tue Jul 25, 2006 5:14 pm    Post subject: Reply with quote
v1.0.0.1 beta is now available!
http://tinyurl.com/nvlm4
1. Auto-reload feature is fixed.
2. Settings tab order is sorted.
3. GPX files now automatically regenerated following database update.
Enjoy! ;)
Beerbellybill999
PostPosted: Wed Jul 26, 2006 10:23 am    Post subject: Reply with quote
Thanks Ash,
unfortunalty the auto reload still doesn't work on my setup
Im i correct in thinking that this routine doesn't actually install as a program?
I have XP pro with SP2.
Any idea's?
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
trevf
PostPosted: Wed Jul 26, 2006 10:51 am    Post subject: Reply with quote
Beerbellybill999 wrote:
Thanks Ash,
Any idea's?
There is still a problem with this which I will PM to Ash directly. To make it work ensure that there are no spaces in the path for Camera Manager.exe (that includes the space in Camera Manager). So put it in a location such as C:\AshTools\Camera_Manager.exe , run it once and then it will work from that location.
Garmin i3
Firmware 3.4
Ash10
PostPosted: Wed Jul 26, 2006 11:02 am    Post subject: Reply with quote
Odd - no problem whatsoever with spaces in filenames using Win2K SP4... Confused
Must be another one of those XP "features" Laughing
Ash10
PostPosted: Wed Jul 26, 2006 11:36 am    Post subject: Reply with quote
Okay, it looks like there's a subtle difference in the way that XP and 2K handle filenames that contain spaces.
If you're running XP, either do as suggested above and rename the file, or wait until I can issue a fix later today 8)
PaulB2005
PostPosted: Wed Jul 26, 2006 12:06 pm    Post subject: Reply with quote
Windows XP Pro SP2 works fine without renaming the file and with spaces in the path - D:\Garmin\Software\Camera Manager.exe
Beerbellybill999 - did you get the latest download and run it?
Request:
Can we have an option where CM quits after checking for an update if there is no new update? i.e. it only remains running in the tray when an update has been downloaded etc etc? Maybe with a 5 second pause so you can see it DID run and then quit.
PaulB2005
PostPosted: Wed Jul 26, 2006 12:37 pm    Post subject: Reply with quote
If you QUIT CM at anytime then the auto start registry entry is removed until you run CM again, so if like me like CM to run and then hit QUIT to close it it won't auto start next time.
Page 3 of 77
23.102 (08 Oct 25)
