Pocket GPS World :: View topic - can a gps receiver be repaired
cliff1959
PostPosted: Fri Jul 21, 2006 3:23 pm    Post subject: can a gps receiver be repaired Reply with quote
hi,
my Haicom HI-204S has lost its led light and the pda can't see any satillites.
there is still power going in according to my voltmeter so it must be something else - how tough are these receivers? and does anyone know who could repair it in the uk? Crying or Very sad
alix776
PostPosted: Fri Jul 21, 2006 3:33 pm    Post subject: Reply with quote
it think it woud be cheeper to replace it as the gps patch antena may have given up
device Lumia 950 xl
Quantum
PostPosted: Fri Aug 04, 2006 3:06 pm    Post subject: Reply with quote
I'd try a hard reset, using SirfTech.
cliff1959
PostPosted: Mon Aug 07, 2006 9:36 am    Post subject: Reply with quote
copied sirftech onto palm but it says 'there is no application associated with sirftech. Run the application first, then open this file from within the application.'
doh, what have i done wrong?
AllyCat
PostPosted: Tue Aug 08, 2006 1:14 am    Post subject: Reply with quote
Hi Cliff,
doh, bought a Palm Smile (or at least not stated the fact on your profile/sig file). Sorry, AFAIK SiRFTech, like many applications, won't run on a Palm PDA, only a PPC.
You may be able to reset the Haicom by removing the backup battery, or waiting for it to discharge (but this might take a long time). If the battery isn't removable, as a last resort you could try shorting it out briefly (a second or two).
Cheers, Alan.
Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter.
cliff1959
PostPosted: Wed Aug 09, 2006 9:36 am    Post subject: Reply with quote
AllyCat wrote:
Hi Cliff,
hi alan,
i think i may be getting confused, i said palm but what i actually have is a HP1710 ipaq, (i don't think this is a palm after all, is it?), anyway if it's not then any ideas why the software won't ru?
thanks for your interest and reply.
AllyCat
PostPosted: Wed Aug 09, 2006 11:09 am    Post subject: Reply with quote
Hi Cliff,
I reset my Holux (when necessary) using SiRFdemo on my PC. But I think I did once install SiRFTech successfully on my PPC, before an unintentional Hard Reset (i.e. flat battery Sad). I don't think I found the User Interface very intuitive. Did you downlaod the file from this page, Unzip, and follow the Installation section?
If you still have no success, I believe you can also use CE Monitor to reset a SiRF receiver (assuming that's the only problem with your GPS). BTW, don't try to use 56k baud with a Bluetooth GPS.
Cheers, Alan.
24.041 (01 Apr 26)
