Pocket GPS World :: View topic - Check Point & PPC2003
cuk0724
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Check Point & PPC2003 Reply with quote
Has anyone got an iPAQ 2210 and using Check point? If so does it run OK without any problems. I have been using GPS Assist, but found it has too many problems.
Yes it works okay on a 2210, this is what I'm currently using when I use TomTom Navigator 2. You'll probably find v2.0.2 better than v3, as this is what many people are finding and reporting here. v2.0.2 isn't available from the CheckPOInt website anymore, but we have a copy on our Downloads page.
cuk0724
Thanks for the quick answer
alix776
PostPosted: Wed Sep 17, 2003 8:50 pm    Post subject: Reply with quote
dave v3 is working fine on my 2210 no probs at all Laughing Thumbs Up
device Lumia 950 xl
bigfatjohn
PostPosted: Wed Oct 29, 2003 1:54 pm    Post subject: Reply with quote
Not on mine it isn't. (PPC2003)
I have installed it but can get no further than the disclaimer page. There is no way to accept the disclaimer and I can't go anywhere else until I have.
Any ideas please?
iangus
PostPosted: Wed Dec 24, 2003 12:32 pm    Post subject: Reply with quote
ack well at least u can get to a disclaimer page!!!
i too the advice and did not install 3.2 at first. i tried the prev vers and this did not work so uninstalled. i intalled 3.2 and nothing works at all for this when tapping the icon. it is also proving more or less impossible to uninstall the program (certainly the icon for it seems positively glued onto the programmes screen!). i am dying to get speed camera warnings working - any advice would be a delight
DavidW
PostPosted: Fri Dec 26, 2003 6:01 pm    Post subject: Reply with quote
The only thought I have is that you've somehow picked up some garbage in the registry that is causing the problems.
I'm still using 2.0.2 on Pocket PC 2003 - it's the only version I've ever installed on my iPAQ 3970 since I upgraded the OS. It works fine for me, once you get past the slightly unintuitive configuration method (tap the flashing icon at the bottom of the Today screen when you first run the program).
This is a strictly untested suggestion, and I do not guarantee anything (including that it will not cause more problems). I believe that CheckPOInt puts some registration information in other parts of the registry that we haven't yet found (look at my comments on the first version 3 release) and it could be the problems lie there.
However, the only thing I can think of is uninstalling CheckPOInt, then, using a registry editor, such as the one you can get here, delete the entire "CheckPOInt Software" key in HKEY_CURRENT_USER\Software. Backup the Pocket PC before you try this, particularly if you're not confident in what you're doing - Sprite Backup is highly recommended.
Ginnser
PostPosted: Mon Jan 05, 2004 12:08 am    Post subject: Reply with quote
Hi All
I was having a nightmare with version 3 on the 2210, running really slow, so back to the older version.
PostPosted: Mon Jan 05, 2004 9:36 am    Post subject: Reply with quote
I have noticed D3 running extremely slow on MicroDrives, so I think the disk access in loading maps is much more intense than in D2 or other mapping programs. This may affect slow storage cards also.
DavidW
PostPosted: Mon Jan 05, 2004 11:14 pm    Post subject: Reply with quote
Dave - were you confused between Destinator and CheckPOInt in your last post in this thread? It sounds like you're writing about Destinator in a CheckPOInt thread.
AliT
PostPosted: Tue Jan 13, 2004 10:50 am    Post subject: Reply with quote
Having installed Checkpoint v 3 on a new Axim 5 with TTN2 I could not find how to register the software to allow the Pocket GPS database to be used. I uninstalled it and then (mistake !!) re-installed to see if I had missed a step. Now I have 2 Checkpoint icons. Uninstalling leaves the icons behind.
Can you provide a few more instructions about how the register should be edited.
DavidW
PostPosted: Tue Jan 13, 2004 11:02 pm    Post subject: Reply with quote
Multiple program icons is nothing to do with the Registry.
Assuming you're talking about what you see in Start -> Programs, or in the Start Menu itself, you need to go into \Windows\Start Menu using either a file manager program on the Pocket PC, or the Explore function in ActiveSync (select My Pocket PC first if you try this). You should then be able to find and delete the unwanted extra program icons - they may be in subfolders of \Windows\Start Menu.
24.041 (01 Apr 26)
