Pocket GPS World :: View topic - TomTom One Sound Problem
geordie9
PostPosted: Sun Sep 17, 2006 7:48 pm    Post subject: TomTom One Sound Problem Reply with quote
Wonder if anyone can help?
Trying to sort out a prob with my friends TT One. It plays no sounds (voices). It has the latest firmware ver 6.150.
Sounds play ok when used with TomTom Home software but nothing thru TomTom when disconnected from comp.
Checked to make sure sound is on and it is.
Any help will be much appreciated!
Thanks!
Daz
geordie9
PostPosted: Sun Sep 17, 2006 7:54 pm    Post subject: Reply with quote
update.....sound works ok when headphones are plugged in...suggests its the built in speaker!
has only one fixed this sort of problem before???
PostPosted: Sun Sep 17, 2006 8:11 pm    Post subject: Reply with quote
Not too sure if the following is available on this device (as I have not had a try of one yet) go to change Preferences/ Speaker Preferences and de-select the "Play music over external speaker" check box, at the same time de-select the "Play spoken instructions over external speaker"
If you cannot see these menu options please go to Change Preferences/ Show ALL menu options then press continue - and the above selections should be available - Mike
geordie9
PostPosted: Sun Sep 17, 2006 8:19 pm    Post subject: Reply with quote
that option is not there...i think it cos the tomtom one can not play mp3's like the 910 can. I have a 910 and that option is there.
Im pretty sure there is a prob with the internal speaker.
Just wondering if anyone has had a similar prob and how did they fix it.
thebinman
Banned
PostPosted: Sun Sep 17, 2006 9:05 pm    Post subject: Reply with quote
See if these good people can help; http://www.satnav-shop.com/
geordie9
PostPosted: Mon Sep 18, 2006 9:30 pm    Post subject: Reply with quote
Took back off to check for any loose wires and unplugged and replugged the speaker connector but still no sound.
Now for some reason I am getting the TomTom start up sound which now lets me know that all is ok with speaker. Also noticed that the clock has reset to 12:00am. Maybe the faults are linked??
Still can only get sounds and voices thru the headphones.
Anyone got any ideas?
The firmware is ver 6.150.
Thanks!
trog100
PostPosted: Mon Sep 18, 2006 9:53 pm    Post subject: Reply with quote
it cant be software else it wouldnt work thru the headphones..
it cant be the speaker else u wouldnt hear the startup sounds..
errrr.. yes.. that does kinda leave a mystery.. he he
trog
eme
PostPosted: Thu Sep 21, 2006 9:25 pm    Post subject: Reply with quote
i have the same problem after updateing software, can not seem to get a answer anywhere. Confused
Tadger
PostPosted: Tue Oct 10, 2006 8:32 am    Post subject: Reply with quote
I've also got the same problem !!!
Has happened since I upgraded to 6.150 !!
meriva
PostPosted: Wed Oct 11, 2006 2:33 am    Post subject: Sound Problem Reply with quote
This happend to me tonight but after reseting a few times and taking the card out and putting it back in a few times it's now working ok. It was very strange and I hope it doesn't happen again. I realise this does not help much and is a bit vague but I was just trying anything. when the speaker was not working i could hear it through headphones. Question
TomTom one with a 1 Gig Scandisk SD card
wibbly
PostPosted: Wed Oct 11, 2006 8:38 am    Post subject: Reply with quote
I had a similar problem last night withe my TT1 Europe. No sound out at all. I toggled the mute icon. No help. Then, wierdly, it just started working again without even a reset....
thebinman
Banned
PostPosted: Wed Nov 01, 2006 10:21 pm    Post subject: Reply with quote
Sorry to bring this one back up again but is there a definitive fix for this on a One V1?
TomTom drums sounds after removing/replacing SD card but no voices whatsoever.
Volume on 90%, select Tim, press Test....silence!
Select Jayne, press Test....silence!
Select volume, wind to 100%, press Test....silence!
Toggled between Turn on Sound/Turn off Sound....Silence!
Hard reset, updated firmware....silence!
Tried original & backup card....silence!
Is it just a matter of "keep on trying all the above" till it sorts itself out or is there a proper fix?
thebinman
Banned
PostPosted: Fri Nov 03, 2006 11:57 am    Post subject: Reply with quote
THANKS TomTom....NOT!
They reckon it's a speaker problem & suggest I return it for repair.
HOW can it be a speaker problem if the drums roll??
Anyone actually worked out a fix for this yet? Pretty please....
wibbly
PostPosted: Fri Nov 03, 2006 12:49 pm    Post subject: Reply with quote
Has you got a backup of the original install? Maybe restore that? It's possible some file somewhere on the card tyat affects sound has got corrupt.
Also, if TomTom are offering a 'repair' you may instead get a new unit, and in any case you should get a unit back that actually works.
thebinman
Banned
PostPosted: Fri Nov 03, 2006 1:54 pm    Post subject: Reply with quote
Cheers for the suggestion wibbly but back up card, different country map etc still nowt!
Hassle of sending it back irks me as I STILL cannot believe it's the speaker at fault.
Please keep 'em coming.
24.041 (01 Apr 26)
