Pocket GPS World :: View topic - I3 firmware 3.20
I3 firmware 3.20
Goto page Previous  1, 2, 3, 4, 5 ... 12, 13, 14  Next
Almahadeus
PostPosted: Thu Sep 21, 2006 1:45 am    Post subject: Reply with quote
PaulB2005 wrote:
Just been for a quick drive. In Nav mode all has been fine for the last 2 days.
However 15 minutes in Map Mode and it's lagging like a fat kid on Sports Day. It only updated the last 1/2 mile once i got on my drive. Most of the time it was about 50 meters behind me. Weird thing is the Speedo updates ok but not the map (again).
More tests coming...
I and mussey1 have reported exactely the same problem earlier. I have noticed this only on map mode (which is not of much use to me anyway) and I have the full set of POIs loaded (GPX files for the speedcams from Ash's old application - so 48,000+ POIs -). Haven't tried it without the POIs as they are more important to me than "map Mode" and my Garmin is the older version with the maps on TF card if this piece of information is useful. Interesting to know the experience of others but I have a feeling that the maps are slightly more zoomed out now which could be exaggerating the screen lag problem.[/b]
Almahadeus
PostPosted: Thu Sep 21, 2006 1:48 am    Post subject: Reply with quote
Just to say that all in all I am really very happy with the latest version (despite my previous posts) and I think that this could be the version to use for people who are hesitant to give it a try.
trevf
PostPosted: Thu Sep 21, 2006 9:01 am    Post subject: Reply with quote
PaulB2005 wrote:
I wonder if it makes a difference if you have memory card or not?
I have a card that came with the i3 and have no problems.
I have the built in maps and POIs on card. No problems encountered yet.
Garmin i3
Firmware 3.4
mussey1
PostPosted: Thu Sep 21, 2006 9:37 am    Post subject: Reply with quote
I have reverted my own unit back to FW 2.4 and it seems to have helped, however it is still not as good as the non transflash 2.7 unit.
Unfortunately I mostly use map mode as here in NI I don't need navigate all that often.
I mostly use the i3 for the camera alert, however I also intend to install a further 3000 + poi's in connection with my work, which I hoped would be able to alert me as I passed certain points.
With the lag in the screen this will be useless as the poi would be long passed by before the graphics on the screen caught up!!
What is annoying me is that 3.2 works 110% with no poi's, so what could be causing the problem??
Perhaps PaulB or Almahadeus could reinstall 3.2 without poi's and run a test on map mode and report back?
Mussey1.
nitelife
PostPosted: Thu Sep 21, 2006 10:09 am    Post subject: Reply with quote
Morning,
Well i've tested it on the way to work today, and it seems much better. The zooming is more appropriate, and dare I say it, the route calculation seems better! I have to drive past the AWE in burghfield, and since its not allowed to be on any maps the previous version was having trouble routing me around it, this one seemed fine! Unless I was imagining it before (which at that time of the morning is entirely possible!).
It recalculated as soon as I went of track as well (I knew a better way at one point), much sooner than before. It just seemed crisper generally, but hopefully im not speaking too soon!
Im going to risk taking it to our long weekend in Cornwall this weekend, hopefully it'll last the night at Jamaica Inn on saturday night (wooooo... ).
So far so good! Driving
nitelife
PostPosted: Thu Sep 21, 2006 10:10 am    Post subject: Reply with quote
Ohh forgot to mention, I dont know if anyone else has noticed this, but on one particular sharp left bend the older version said turn left, this one now says bear left!
PaulB2005
PostPosted: Thu Sep 21, 2006 10:14 am    Post subject: Reply with quote
Second drive last night and driver this morning confirm definite lag in Map mode.
Dear Garmin...... etc etc etc
PaulB2005
PostPosted: Thu Sep 21, 2006 10:26 am    Post subject: Reply with quote
I have found that even with the lag the speedo, direction and banner at the top of the screen still updates correctly (i.e. Smith Road ahead, Jones Avenue ahead etc) it's just the map section that lags.
Also the camera alerts (and therefore i presume all POI alerts will) still function ok.
zogman
PostPosted: Thu Sep 21, 2006 10:48 am    Post subject: Reply with quote
paul, just wondering whether your sat signal strength could be a contributing factor for the screen lag..
BERT_UK
PostPosted: Thu Sep 21, 2006 10:50 am    Post subject: Reply with quote
MaFt wrote:
regarding the timings for final prompt before a turn i wonder if it'd be worth a few of us emailing garmin about it and recomending instead of the automatic distance being assumed from the max speed for that road (i.e. if the road is a 60 you get 0.3miles warning even if you're only doing 30mph) that it could be calc'd from the current speed? think that would solve most problems assuming the extra calculation didn't slow things down too much...
Definitely. The new voice promptings are dreadful for areas where road turnings are clustered together. The first version of firmware that did this I hated and so went back to v2.7 as soon as I got home. I'd like to be able to take advantage of some of the improvements in later firmware but the "improved" voice prompts have stopped me.
In defence of the "improved" voice prompts I do think they are better for motorways etc as the final turn left prompt on the older firmware versions is often given as the sliproad exit disappeared (although if you hadn't listened to the first prompt and got over that was your fault really Smile )
However, do the "improved" voice prompts use the max speed for the road at all? Is it just a hard coded x.x miles from the turn?
PaulB2005
PostPosted: Thu Sep 21, 2006 10:54 am    Post subject: Reply with quote
Not sure how. The 3.2 acquires the Satellites a lot quicker than 2.7, and the lag doesn't exist with the 2.7 FW! The i3 also consistently shows 4-5 bars when it lags with 3.2 FW and the back button is pressed.
See my Sig for my antenna set up. Works every time, just fine with 2.7 since release.
PaulB2005
PostPosted: Thu Sep 21, 2006 10:57 am    Post subject: Reply with quote
Also if the signal strength is to blame then why does it still know what roads are coming up and what speed i am doing? These still display ok. It just seems to be that the main map section of the screen stops updating and freezes.
zogman
PostPosted: Thu Sep 21, 2006 11:27 am    Post subject: Reply with quote
you're right paul, it does seem a software problem..back to v2.70 then?
PostPosted: Thu Sep 21, 2006 12:09 pm    Post subject: Reply with quote
definate lag in map mode but nav mode is fine... i can live with it as the only time i would need map mode only is if i am driving somewhere i know - in which case i wouldn't have ivy with me anyway...
will still email garmin about it though and also mention that nav mode has improved a lot
Ash10
PostPosted: Thu Sep 21, 2006 12:40 pm    Post subject: Reply with quote
I have this terrible sense of deja-vu Sad
Page 4 of 14
24.041 (01 Apr 26)
