Pocket GPS World :: View topic - I can`t get my pc to recognise my 700
Simbo_Wales
PostPosted: Sun Sep 24, 2006 11:04 am    Post subject: I can`t get my pc to recognise my 700 Reply with quote
Hello all,after d/l and installing the new hardware ,version 6.15 I cant get my TT to be recognized by my pc either when connecting it via TT home or directly as drive (x).TT goes straight to map mode.
I have tried 2 different usb cables,both of which work with another usb device and I am scratching my head at the moment!!
Just tried a factory reset and still no luck Sad
PostPosted: Sun Sep 24, 2006 12:17 pm    Post subject: Reply with quote
Hve you made sure that the Plug has been firmly pushed into the 700? They are a tight fit sometimes.
If you go straight into Map Mode, it suggests that the 700 doesn't know it's plugged into the PC. Have you tried another USB Port?
TT Via 135 App 12.075: Europe Map v1165
Simbo_Wales
PostPosted: Sun Sep 24, 2006 12:56 pm    Post subject: Reply with quote
Sorry about the double post Oldboy,yes I have tried a few usb ports,including a powered usb hub,but still the 700 goes directly to map mode.
PostPosted: Sun Sep 24, 2006 3:24 pm    Post subject: Reply with quote
Have you tried plugging it in firmly at the TT end? If you have and the Cable is OK, it would suggest that the problem rests with the TT USB Socket.
Simbo_Wales
PostPosted: Sun Sep 24, 2006 4:20 pm    Post subject: Reply with quote
Yep,thats what I am begining to think, I have mailed TT support so I should hear something in a day or two.
Many thanks for your suggestions.
nudda
PostPosted: Tue Sep 26, 2006 9:37 pm    Post subject: Reply with quote
my 700 is doing the same. Arghhh
Does anyone know what to do ?
trog100
PostPosted: Tue Sep 26, 2006 11:55 pm    Post subject: Reply with quote
try removing the sd card then make the connection.. if the connection is made then insert the card..
no great logic to this but some computors dont like a card reader which is what the tomtom is being plugged in with a card in..
trog
nudda
PostPosted: Wed Sep 27, 2006 7:49 am    Post subject: Reply with quote
Thanks trog but the 700 doesnt have an sd card Smile
Simbo_Wales
PostPosted: Thu Sep 28, 2006 12:32 am    Post subject: Reply with quote
Did a reset with a paperclip and everything back to normal!!
nudda
PostPosted: Thu Sep 28, 2006 8:03 am    Post subject: Reply with quote
Sorry I forgot to update here.
Yes the paperclip trick did it but I find I now have to reset it everytime before I connect it to my PC !! GGggrrrr
gg2000
PostPosted: Sun Oct 01, 2006 7:57 pm    Post subject: Reply with quote
Just discovered I have the same problem, fortunaly the reset work-around does indeed do the trick. Never had this problem with v6.14
Hopefully TT will fix on the next release
TTGO 700 v6.15 External Aerial
sixonenine
PostPosted: Mon Oct 02, 2006 7:54 pm    Post subject: Reply with quote
i can connect m,y 700 to my computer but 'Home' doesn't seem to recognise, tellin' me my TomTom isn't connected. Aaargh. but it is!!! - As above, I do hope TomTom can sort this problem out with the next update.... [619]
sixonenine
PostPosted: Mon Oct 02, 2006 7:58 pm    Post subject: Reply with quote
Hmmm. I just quit 'Home' on my comp and reopened it. Seemed to do the trick and recognised my 700. Hohum. I'll not moan so fast next time!
PostPosted: Wed Oct 04, 2006 9:27 am    Post subject: Reply with quote
TTGO700
I have just been suffering this problem for the last hour. Different cables, different ports, paperclip reset after reset.
Eventually it came to life, so that I could install yesterday's camera updates.
This problem happened to me after Tom Tom Home downloaded and installed an update - v1.3, build 25 September 2006 - so I rather suspect that (I seemed to lose the TT icon on the taskbar too). Time will tell.
tonygold
PostPosted: Thu Oct 05, 2006 9:51 am    Post subject: Reply with quote
i had same prob with my tomtom ONE. eventually realised that i had set the tab on my sd card to 'lock'. when i unlocked sd card tomtom was recognised immediatly by my pc. not sure if same happens on 700 but may be useful to others???
24.041 (01 Apr 26)
