		| Author | Message |
		| Tinpusher Occasional Visitor
				|  Posted: Fri Oct 20, 2006 7:22 pm    Post subject: "here be dragons"- navigating to a map point? |   |
				| Is it possible to select a position from the map, and tell D6 to "navigate to" that point?
 By the same token, is it possible to select a point on a map and add it as a favourite?
 My mum lives in the middle of nowhere- the postcode isn't recognised and it's about 2/3 of the way along a minor road. I want to add her house into my favourites, and at the moment I can't figure out how to do it.
 Home - Dell Axim X51 + BT359 + D6 & MM
 Work - IGI CCNS4, Vexcel Ultracam D & Somag GSM3000, X-Treme L1/L2 GPS receiver all shoved into a Piper Chieftain, registration G-OSGB. See the results on http://local.live.com/
		| Back to top |  |
		| lbendlin Pocket GPS Staff
				|  Posted: Fri Oct 20, 2006 11:38 pm    Post subject: |   |
				| Most street routing programs will only allow POIs on or close to streets. You'll have to set the POI accordingly.
 Report map errors to the map providers - only reporting will help to eventually improve the data.
		| Back to top |  |
				|  Posted: Fri Oct 20, 2006 11:48 pm    Post subject: |   |
				| How about setting a POI from a lat/long position? How can I do this is D6? _________________
		| Back to top |  |
		| barryd Frequent Visitor
				|  Posted: Sat Oct 21, 2006 6:11 pm    Post subject: |   |
				| Assuming you're using a Pocket PC, my free OS GPS Convertor utility will do it: http://www.freenetpages.co.uk/hp/barrydavies/index.htm
 Be warned that I have never used Destinator, but added in support for it at the request of a user on this forum about 18 months ago, who spent a fair bit of time getting it to work. If it doesn't work for your version of Destinator, I'd need your technical input to make it work!
 Good luck
 Barry Davies
		| Back to top |  |
		| Back to top |  |
				|  Posted: Sun Oct 22, 2006 12:02 pm    Post subject: |   |
				| Thanks Barry, that looks like exactly the sort of thing I'm after. I'll let you know how I get on so you can get some feedback as to how it works in D6. _________________
		| Back to top |  |
		| MarkP Occasional Visitor
				|  Posted: Mon Oct 23, 2006 1:47 pm    Post subject: Re: "here be dragons"- navigating to a map point? |   |
				|  	  | Tinpusher wrote: |  	  | Is it possible to select a position from the map, and tell D6 to "navigate to" that point?
 You can tap on a point on the map whilst navigating and a window pops up with "Go there", "Add to favourites" and something else which I can't remember.  Wouldn't that serve your needs?
		| Back to top |  |
				| ![]() Posted: Today    Post subject: Pocket GPS Advertising |  |
  Have you considered making a donation towards website running costs ?. Or you could disable your ad-blocker for this site. We think you’ll find our adverts are not overbearing!
		| Back to top |  |
