Pocket GPS World :: View topic - Mio168 USB problems
Mio168 USB problems
benedictheal
PostPosted: Tue Oct 10, 2006 11:20 pm    Post subject: Mio168 USB problems Reply with quote
My Mio168 has recently stopped communicating with PCs. When connected, I get the message:
USB device not recognised. On of the USB devices attached to this computer has malfunctioned, and Windows does not recognised it.
I get the same behaviour on three different machines. I've done hardware resets, and reinstalled ActiveSynch, but it sounds more fundamental than software.
Does anyone have any ideas about what might be causing it, and whether it is likely to be reparable?
Thanks,
Benedict
highwayman212
PostPosted: Wed Oct 11, 2006 7:31 am    Post subject: Reply with quote
Benedict
Have you tried a different cable?
Chris
Nokia 5800 XM
Navmii
Sequin
PostPosted: Wed Oct 11, 2006 10:55 am    Post subject: Reply with quote
Ensure that Activesynch is started on the Medion before you connect the USB cable - this is the only way I can get it to connect on mine...
Pc-Mobile
PostPosted: Thu Oct 12, 2006 7:44 am    Post subject: Reply with quote
As you have the Mio for a long time so I should think you know what to do.
I suspect your cable is faulty. There is nothing else you could do if that is the case.
Pc-Mobile
http://pc-mobile.net/gps.htm
benedictheal
PostPosted: Thu Oct 12, 2006 10:32 am    Post subject: Reply with quote
Thanks for the replies. I did buy a new cable, to no avail, and having done a hardware reset, there is no activesynch on the Mio to start before connecting!
If it is a h/w problem, is it likely to be reparable? Is the USB h/w a separate part of the electronics, or is everything so integrated that it really means a new machine? Are there any UK repairers anyone has used?
Thanks for suggestions,
Benedict
Border_Collie
PostPosted: Thu Oct 12, 2006 4:15 pm    Post subject: Reply with quote
How old is your 168? Don't forget they came with a 2 year guarantee. There was a known problem with the connector inside the unit breaking.
If yours is less than 2 years old contact your supplier who should arrange a free repair.
Be aware that you will have to re-activate your maps on the 'new' unit.
Bobiusdogius
PostPosted: Thu Oct 19, 2006 8:13 pm    Post subject: No syncronization Reply with quote
Hi, I may have the soloution to your problem as this happened to my Medion 9500(same as the mio) about 2 years ago. I just used it as a GPS from then on but then it stopped charging as well so it was time to investigate.
The fault was physical. the small connector block had come free of the PCB.
I decided as I had nothing to loose that I would clean the connections and re solder it in place. Now beware, this is nano tech and it was done with a 10x eyepiece and a ground down soldering iron (still covered 4 contacts at once)
When I was sure that no two contacts were shorting I reassembled it and plugged it in......... Voila not only charging but sync ed with the pc.
Chuffed to bits :D
Sequin
PostPosted: Thu Oct 26, 2006 4:32 pm    Post subject: Reply with quote
Mine came with a three year warranty from Aldi, but my dad bought one from Kwiksave and when he called recently to enquire about a repair was told that it only had a 30 day warranty when bought there
Sequin
PostPosted: Wed Nov 01, 2006 4:30 pm    Post subject: Reply with quote
Activesynch is built in to the operating system - it will be in the Programs folder from the Start menu
Border_Collie
PostPosted: Wed Nov 01, 2006 4:57 pm    Post subject: Reply with quote
Go back and tell them they are talking rubbish and to read a copy of the Sale of Goods Act - Products must be of merchantable quality and fit for their purpose. It's a known problem with the connector on the Mio 168 and Mio will repair or replace the device. The Kwiksave guarantee has nothing to do with the Mio guarantee and cannot take away your rights.
Sequin
PostPosted: Thu Nov 02, 2006 2:39 pm    Post subject: Reply with quote
He was told this by Medion!
24.041 (01 Apr 26)
