Pocket GPS World :: View topic - TomTom Home locks my PC
LittleDuceCoupe
PostPosted: Mon Nov 13, 2006 12:48 pm    Post subject: TomTom Home locks my PC Reply with quote
I have just got my new TomTom One. I installed "Home" to my PC and did a back-up as recommended. Copied the SD card to a spare and am using the spare in the unit. Connect back to "Home" to get the updates and my PC locks-up during the download. Try to use the back-up and the TomTom One unit is locked-up! Try to turn off my PC and it just hangs at the "Windows is shutting down" phase. Only way out was to power-off. Dissconnected the TomTom One which is still stuck in the do-not dissconnect phase! Only way out was a pin in the reset hole. Now when re-starting the TomTom One it doesn't recognise my SD copy.
I hate computers! Thank goodness I still have the original SD card.
Dave.
SAMSUNG Galaxy S8 - CoPilot Europe and Australia
PostPosted: Mon Nov 13, 2006 8:39 pm    Post subject: Reply with quote
Go to TT's Website and download the latest HOME Version (1.3 Build 200 I believe), from HERE.
I admit that I prefer to do a Backup Manually, as then I know what's been Copied.;)
Format your new Card and Manually Copy everything to it, and you should be up and running.
TT Via 135 App 12.075: Europe Map v1165
LittleDuceCoupe
PostPosted: Mon Nov 13, 2006 8:54 pm    Post subject: No shutdown lock-up! Reply with quote
Thank's for that Richard, I will download "Home" from your link. The version that I have allready is the one that you state but I am not sure if that was due to an update after I installed from the CD in the box. So I will give your link a try!
Dave.
LittleDuceCoupe
PostPosted: Wed Nov 15, 2006 12:29 am    Post subject: I still have problems! Reply with quote
I have just downloaded HOME V1.3 Build 308.
I am using a 2Gb SD card to which I have copied my original TomTom One V3 Europe data which is almost 1Gb. This works fine in my unit until I connect to HOME, even this Build 308.
When I connect to HOME it says that there is an updated application available for GO RIDER and ONE. When I try to restore this to my connected ONE some files are deleted and then it tries to install the new data. The progress bar freezes at downloading F:\data.chk and then I cannot dissconnect my ONE even through the taskbar "safely remove hardware icon". It says try later! When I try to turn of my PC, it won't. Even ctl/alt/delete doesn't work. Power-off PC and reset button on my ONE which leaves the SD card currupt. Format and re-copy from my original gets it working again.
Is there some reason why I can not use this bigger card?
Dave.
Macbobby
PostPosted: Wed Nov 15, 2006 12:56 am    Post subject: Reply with quote
It could be your 2.0GB SD Card. Previous TomTom devices and firmwares have had difficulties with certain brands of SD Card especially the 2.0Gig ones. I won't mention the brand names of the ones I had problems with but I will say my 2.0GB Integral High Speed has never failed me on any firmware or device
TT ONE v2
GO 300 WE 660.1219
PostPosted: Wed Nov 15, 2006 8:34 am    Post subject: Re: I still have problems! Reply with quote
I'm presuming that the update is to V6.520.
The quick way is to download the Manual Version from my WebSpace.
There is a text file included that tells you what to do.
Try that and see if it works,
If it does, and I see no reason why not, do a Backup and connect to HOME again.
24.041 (01 Apr 26)
