Pocket GPS World :: View topic - The Navman N20 - POIs etc
Tim Buxton
PostPosted: Sat Nov 18, 2006 11:35 pm    Post subject: Reply with quote
What does it say when you try to open an .asc file?
Tim
nav-man
PostPosted: Sat Nov 18, 2006 11:54 pm    Post subject: Reply with quote
I am sure I have tried that, but it will try it again.
I will come back and let you know how I get on.
Cheer's
Gee-Pee
PostPosted: Sun Nov 19, 2006 11:55 am    Post subject: Reply with quote
barrados wrote:
nav-man wrote:
I have but the new N Series poi editor needs it to be in CVS format
Just use poi edit and convert the files from one format to .csv format.
I did this and the Desktop reported files successfully downloaded to the device. I saved them on the internal memory as the files are so small rather than on the SD card.
They appear on the Navman screen with the names I allocated to the files (and they are in bold text indicating they are activated) but when I went for a drive none of them showed up or gave any warnings.
Is it possible to use the default icon for all the cameras - I didn't, just used those with the PGPSW download.
There is also a choice of warning sound - again this time I used the default wav file.
Did all yours load and work OK Question
Gee-Pee
Gee-Pee
PostPosted: Sun Nov 19, 2006 12:13 pm    Post subject: Reply with quote
Tim - see expanded dialog by email.
Graham
Gee-Pee
nav-man
PostPosted: Sun Nov 19, 2006 1:23 pm    Post subject: Reply with quote
You can only load CSV files into the N20 POI editor it will not let you load any other type of file unlike the ICN510 POI editor.
Somehow they will have to be changed before.
If we were able to download the safety camera files from Pocket GPS in Excel spreadsheet ( xls ) format I have a programme to convert it to CVS then all would be great
Any sugestions !
Gee-Pee
PostPosted: Sun Nov 19, 2006 1:27 pm    Post subject: Reply with quote
Any sugestions !
I just opened files in Notepad then 'saved as' *.csv into the same folder which I used to extract them from the zipped/dowloaded file.
Gee-Pee
nav-man
PostPosted: Sun Nov 19, 2006 1:39 pm    Post subject: Reply with quote
I just loaded a safety camera file onto note pad as you suggested and then tried to save as a CVS file but you only have the option of saving as a text file which is the same as it a is already.
PostPosted: Sun Nov 19, 2006 1:52 pm    Post subject: Reply with quote
nav-man wrote:
If we were able to download the safety camera files from Pocket GPS in Excel spreadsheet ( xls ) ........Any sugestions !
Only one sugestion, when in the download speed camera options open the dropdown box for the SatNav system and look at the fourth item in the list Wink - Mike
Gee-Pee
PostPosted: Sun Nov 19, 2006 2:07 pm    Post subject: Reply with quote
In Notepad, select File - Save as then at the bottom of the Notepad screen there should be a dialog box which gives you the opportunity to "Save as type" - select this and take the option to save as "All files" (there should be a 'down' arrow against the box), then on the name of the original file add .csv and save to the same folder where you extracted the files to from the downloaded zipped folder.
[/img]
Gee-Pee
nav-man
PostPosted: Sun Nov 19, 2006 3:26 pm    Post subject: Reply with quote
Thank you very much for that Gee-Pee it works great you really know your stuff.
portman
PostPosted: Sun Nov 19, 2006 5:01 pm    Post subject: Reply with quote
Just use the safety camera file for the garmin, poiloader version, works fine as do all other garmin poi's as they are csv.
Samsung Mega
Tomtom 500
portman
PostPosted: Sun Nov 19, 2006 5:03 pm    Post subject: Reply with quote
If you want more wav sound files use these.
http://www.waveevents.com/
Wave Events - WAV files,
Samsung Mega
Tomtom 500
Gee-Pee
PostPosted: Sun Nov 19, 2006 5:12 pm    Post subject: Reply with quote
Thank you, thank you, Portman Wink
Gee-Pee
Gee-Pee
PostPosted: Sun Nov 19, 2006 9:53 pm    Post subject: Reply with quote
Just downloaded and installed an extra file, just to see how it works. Dead easy installation and quick through the N20's POI editor - 'My Sounds Admin' - page 96 in the Manual.
Gee-Pee
mostdom
PostPosted: Mon Nov 20, 2006 1:54 am    Post subject: Reply with quote
note for nav-man re file types. Discussed before see post.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=43372&start=0&postdays=0&postorder=asc&highlight=
Dom
Page 2 of 3
24.041 (01 Apr 26)
