Pocket GPS World :: View topic - 19mph, 25mph, 43mph Warnings
PostPosted: Sat Nov 18, 2006 1:09 pm    Post subject: 19mph, 25mph, 43mph Warnings Reply with quote
If you get warnings at seemingly strange speeds then this is why:
The maths:
30 mph = 19kph
40mph = 25kph
70mph = 43kph
In POILoader, on the screen where you select the directory where the data files can be found, it also asks 'What units should be used for distance and speed?' Make sure you set this to Feet and MPH. At present yours as Meters and KPH.
Re-upload the camera's and make sure you change the setting! It will remember this setting so you only need to do it once.
TomDavison
PostPosted: Mon Nov 27, 2006 6:15 pm    Post subject: Re: 19mph, 25mph, 43mph Warnings Reply with quote
The maths:
30 mph = 19kph
40mph = 25kph
70mph = 43kph
Not when I went to school.
11.9 mph = 19kph
15.6mph = 25kph
26.9mph = 43 kph
PaulB2005
PostPosted: Mon Nov 27, 2006 6:17 pm    Post subject: Reply with quote
Damm. I used to have a grey import motorcycle with KPH clocks and i never noticed this mistake!!!
TomDavison
PostPosted: Mon Nov 27, 2006 6:23 pm    Post subject: Reply with quote
I think it's the other way round.
Lets assume you set speeds of 30units, 40units and 70 units, thinking you stting MPH as the unit , but you are actually setting KPH. If you now measure your speed in MPH, you get 18.75mph, 25mph, and 43.74 mph. Bingo!!
I'm not sure how Garmin works, but I assume from this that you need to change to MPH from KPH, and then set the speeds to 30, 40 and 70, once you are in mph mode.
swing
PostPosted: Mon Nov 27, 2006 6:27 pm    Post subject: Re: 19mph, 25mph, 43mph Warnings Reply with quote
MaFt wrote:
30kph = 19mph
40kph = 25mph
70kph = 43mph
ie The speed database has the values 30, 40, 50, 60 and 70 in it - with POI Loader set to KPH it will translate those values as if they were kph speeds, hence the very wrong mph warnings.
PostPosted: Mon Nov 27, 2006 7:23 pm    Post subject: Reply with quote
human error.... doh!
anyway, the thread still kinda makes sense...
i was tempted to edit my post and then delete all yours, but i thought i'd be a big boy and own up!
swing
PostPosted: Tue Nov 28, 2006 12:04 pm    Post subject: Reply with quote
I'm happy for you to edit your post and delete mine - that way it'll be clearer for all new people who come here...
PostPosted: Tue Nov 28, 2006 12:45 pm    Post subject: Reply with quote
but they won't have as much fun then :D Laughing
Ayla
PostPosted: Fri Dec 29, 2006 1:35 pm    Post subject: Reply with quote
It certainly gave me a chuckle! I'm sure they'll figure it out - after all, it's not exactly rocket science is it! We all know that 60mph = 100 kph - don't we? Rolling Eyes (too many years of living in a country which changed to metric measurement when I was just learning to drive, and totally screwing up my brain!)
JockTamsonsBairn
PostPosted: Fri Dec 29, 2006 2:17 pm    Post subject: Reply with quote
You'd think so, but have you seen how many posts there are complaining that the database doesn't work, because of this problem?
Jock
orfy
PostPosted: Tue Feb 06, 2007 11:39 am    Post subject: Reply with quote
Right, that explains the error.
Not all of us like to play with the garmins we just want to use them with as little hassle as possible.
Scarecrow
PostPosted: Fri Jul 20, 2007 12:35 pm    Post subject: Reply with quote
Just remember that if you download and install the new European camera databases, you will need to set POILoader to kmh settings, other wise in an 80mph limit (130kmh) you won't get a warning unless you are doing close to 130mph!!
This means that you won't be able to load the European and UK databases at the same time, as they are not compatible with the same setting in POILoader.
swing
PostPosted: Fri Jul 20, 2007 12:37 pm    Post subject: Reply with quote
If you search the forums there are a number of suggestions for having both mph and kph alerts at the same time - basically you either change the values in one set of files to the other units, or you use the multiple POI Loader upload tricks (not available on all units).
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
gardenshed
PostPosted: Fri Jul 20, 2007 5:06 pm    Post subject: Reply with quote
is that a garmin only problem? seems like a biggie to miss if you are in europe 8O
inspiredron
PostPosted: Fri Jul 20, 2007 9:55 pm    Post subject: Reply with quote
You might want to look at my post here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=57496
23.122 (10 Dec 25)
