| Author |
stevex9 Occasional Visitor
Posted: Wed Nov 29, 2006 9:51 pm Post subject: TT Itineries and ITNConv - Autoroute |
Hi all
Does anyone out there have any knowledge of the Utility ITNConv. Myself and a very helpfull forum member have been trying to resolve a problem.
This utility is supposed to convert Autoroute files (.axe) to (.itn) files.
I have purchased the latest version of autoroute and have a TT910. When i create a route in AR and try to convert it in ITNConv it gives a load of rubish in the road name column.
Anyone any ideas.
Stevex9 |
| Back to top |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Wed Nov 29, 2006 10:06 pm Post subject: |
It's possible that either MS have changed the format of the .axe file or yours is corrupted. Have you tried reloading it into AR to see what happens? _________________ Tim |
| Back to top |
Posted: Wed Nov 29, 2006 10:18 pm Post subject: |
Hi Tim
It reopens in AR fine.When i open the axe file, it lists the street names as gobbldy gook. I have spoken to someone else andthere version works fine, it is the 2005 version and mine is 2007.
Stevex9 |
| Back to top |
scarer Occasional Visitor
Posted: Sat Dec 02, 2006 6:11 pm Post subject: |
Hi Steve
I have the same problem, have you found a solution yet? |
| Back to top |
henryg Regular Visitor
Posted: Sat Dec 02, 2006 7:12 pm Post subject: |
| stevex9 wrote: | | It reopens in AR fine.When i open the axe file, it lists the street names as gobbldy gook. I have spoken to someone else andthere version works fine, it is the 2005 version and mine is 2007.Stevex9 |
I'll try it in AR2003 if you want to send me the ITN file. Quite how I can get you my email address without it appearing here and being grabbed by a trawling program though?
Henry |
| Back to top |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Sat Dec 02, 2006 7:15 pm Post subject: |
| Quote: | Quite how I can get you my email address without it appearing here and being grabbed by a trawling program though?
| Use the PM, (Private Mesage) Box. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
| Back to top |
Posted: Sat Dec 02, 2006 7:19 pm Post subject: |
| henryg wrote: | | stevex9 wrote: | | It reopens in AR fine.When i open the axe file, it lists the street names as gobbldy gook. I have spoken to someone else andthere version works fine, it is the 2005 version and mine is 2007.Stevex9 |
Henry |
He could always press your 'Email' button, Henry!  _________________ Tim |
| Back to top |
Posted: Sat Dec 02, 2006 7:44 pm Post subject: |
I'll try it in AR2003 if you want to send me the ITN file. Quite how I can get you my email address without it appearing here and being grabbed by a trawling program though? |
| Quote: | | Use the PM, (Private Mesage) Box. |
| Quote: | | He could always press your 'Email' button, Henry! |
Eh? Am I missing something? Where are their e-mail buttons?
| Back to top |
Posted: Sat Dec 02, 2006 8:59 pm Post subject: |
Sorry, Guys. If you haven't enabled your Email button, only Mods and , I presume, Team members can see them. Sorry for inadvertently leading you astray. _________________ Tim |
| Back to top |
Posted: Sat Dec 02, 2006 9:45 pm Post subject: |
So the are on Tim. :P  _________________ Formerly known as Lost_Property
| Back to top |
Posted: Sun Dec 03, 2006 10:47 am Post subject: |
Steve
I suggest you look at the resullting itn file with a text editor (notepad?).
I converted a short axe file I had made in AR to itn, and it showed the waypoint names properly on my TT. However, I compared the converted axe file with an itn I had converted from a gpx file recorded via Tripmaster, and there seemed to be an "|" (field delimiter?) missing toward the end of each line. It didn't seem to make any difference when I manually inserted it using a simple search and replace operation, but perhaps later versions of AR have different file format issues that do make a difference. _________________ Henry |
| Back to top |
Posted: Sun Dec 03, 2006 10:35 pm Post subject: |
Hi Guys
Thanks for the replies people. I have spent ages on the phone with Microsoft on Friday. Guess what, they don't know the answer either.
I have been liaising with someone else on here who has sent me files created in earlier versions of AR. If i open them in 2007 it crashes and re opens AR and loads the file ok. If i then try to convert it to ITN it appears mushed up, in the street/road names column.
If i convert the same files before i open them in 2007 they read perfectly. So, it would appear that 2007 doesn't work with ITN converter.
I have also changed my copy of 2007 at PC World and re loaded it, still doesn't work.
Problems still on going then.
thanks
Stevex9 |
| Back to top |
mallettron Occasional Visitor
Joined: May 19, 2004 Posts: 24 Location: sheffield South Yorkshire England
Posted: Mon Dec 04, 2006 1:32 pm Post subject: |
I have 2007 installed as well and it doesnt work, I am now trying to find an earlier copy to try it.
BTW does anyone know if there is a limit on thr .itn files, no of points etc. I may be wanting to create an itinerary of over 300 points!!!
Ronnie |
| Back to top |
Posted: Mon Dec 04, 2006 2:58 pm Post subject: |
AR2006 works. I've never used more than about a dozen waypoints in an itinerary and have only had two or three on the device at a time so can't answer the second bit. Nothing specific is mentioned in the .pdf manual. _________________ Tim |
| Back to top |
pmcadams Occasional Visitor
Posted: Mon Dec 04, 2006 3:32 pm Post subject: |
Not 100% sure where I read it, but I think tomtom *.itn files can only be 48 in length.
Right just checked, I am using a program called Tyre, im sure you have come across it. Allows construction of *.itn files coupled with google earth.
In the help it states a maximum of 48 points. But it can split the files if over the defined maximum into multiple files.
http://www.janboersma.nl/gett/help/
Hope this answers ur question! Plus it and google earth are free  |
| Back to top |
| Back to top |
