Pocket GPS World :: View topic - Ash10's Camera Manager Software
Goto page Previous  1, 2, 3 ... 12, 13, 14 ... 75, 76, 77  Next
Ash10
PostPosted: Tue Dec 05, 2006 1:25 pm    Post subject: Reply with quote
ianandrewhay wrote:
thanks ash. I have now changed the timings, but as yet i have no reminders to update, is this normal?
No - you should start getting the reminders pretty much straightaway.
Once Camera Manager has downloaded the database, it won't do so again until the version number changes - this is done in order to reduce bandwidth demands on PGPSW.
It sounds like it can't find the database that it did download - if you've changed the POI directory recently this could be the cause, or it might have accidently got deleted. Have a search on your hard disk for "PocketGPSWorld Speed Camera Database.zip" - it should be in the same directory that POI Loader is using - if not, copy it there.
ianandrewhay wrote:
I have previously manually downloaded a speed camera database onto the unit, do you think this is what is is detecting?
No - Camera Manager won't know if you do anything behind its back manually.
ianandrewhay wrote:
Also do any new updates automatically replace any previous ones?
Yes - old versions of the camera database are overwritten automatically.
ianandrewhay
PostPosted: Tue Dec 05, 2006 3:49 pm    Post subject: Reply with quote
hey ash thanks for your continued help! I cannot find that file on my computer i must of deleted it accidentally - how do i get your camera manager to automatically download a new one?
Ash10
PostPosted: Tue Dec 05, 2006 4:21 pm    Post subject: Reply with quote
To force Camera Manager to download the database immediately, download and run this:
http://tinyurl.com/y73fjb
Some browsers (eg: Firefox) will open this as text - just select File then Save As from the menu to save it to disk... ;)
ianandrewhay
PostPosted: Tue Dec 05, 2006 4:46 pm    Post subject: Reply with quote
Thanks ash... all working now. I think the problem started originally because i put the folders on various drives.
All i need to do now is take the unit for a test drive!!
Thanks for putting in a lot of your own personal time to help a lot of people with this software!
Smile
tomthompson
PostPosted: Sat Dec 09, 2006 6:09 pm    Post subject: Reply with quote
Ash....ASh....ASH..........
Did you see the new POI loader with support for wav files oooohhhh
ASH
ASH
Rolling Eyes
Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ?
PostPosted: Thu Dec 14, 2006 6:16 pm    Post subject: Reply with quote
didn't work for me... can we have a 'check now' button? i know theres an update cos i did it yesterday but it aint picking it up!!
Ash10
PostPosted: Thu Dec 14, 2006 8:42 pm    Post subject: Reply with quote
Don't forget to quit and restart Camera Manager...
I'm working on a few tweaks in this area - watch this space ;)
PostPosted: Thu Dec 14, 2006 11:46 pm    Post subject: Reply with quote
tried that... could the 2.40 beta be the issue?
Ash10
PostPosted: Fri Dec 15, 2006 5:42 pm    Post subject: Reply with quote
When you said that the update wasn't picked up, was it just that you weren't getting reminders? Or did it not even download the new database?
PostPosted: Sat Dec 16, 2006 3:36 am    Post subject: Reply with quote
both 'current version' and 'last checked' are blank... presumably from running the registry hack! but not been 'filled' since
larrens
PostPosted: Fri Dec 22, 2006 1:09 pm    Post subject: Confused with speed cams Reply with quote
I am a bit confused with all the speed cam utilities out there for the i3.
I used to use the one on PocketGPSworld that cost £2 a time & upload it with POI uploader together with other POI's - does this replace it or use the same database as the one I just mentioned?
Is it simply just loading it up & it will install the speed cam settings I need, & not overwrite my other custom POI's?
thanks
tomthompson
PostPosted: Fri Dec 22, 2006 5:19 pm    Post subject: Reply with quote
This is designed by Ash to allow you to adjust the settings of the warnings for the database that you download from pocketgpsworld.
So that you can decide how long before a camera you get a warning and wether you also get an overspeed warning and when.
:D
Ash10
PostPosted: Sat Jan 06, 2007 8:14 pm    Post subject: Reply with quote
Major new release - 1.5.0.0 beta now available!
Camera Manager has had a major re-write over the last few weeks, and here it is:
http://tinyurl.com/nvlm4
Changes made:
A different version of the PGPSW camera database is now used, to facilitate some of the new features.
IMPORTANT - Before running this new version for the first time, you should delete the downloaded database ('PocketGPSWorld Speed Camera Database.zip') from your POI directory.
Removed Quit button. To quit Camera Manager, click on the close icon in the top-right of the settings window. Click on the 'Cancel' button or press 'Escape' to minimise the settings window as before.
Added option to add ACPO margin to the overspeed warnings. This margin is the leeway recommended by the Association of Chief Police Officers before prosececution occurs. Please note that this is just a recommendation, and some forces (notably North Wales) choose to operate a zero-tolerance policy instead. The default setting is off - use with caution!
Added option to display speed limit signs instead of camera type icons:
With camera types displayed (as before)
With speed limits displayed (new)
Added a Paypal button - incase you'd like to contribute something in recognition of the effort that's gone in Camera Manager. Blah, blah, got no job at the moment, mouths to feed, blah, blah... ;)
Tested on my i3, running v2.7 firmware and POI Loader v2.3.1
Enjoy 8)
trevf
PostPosted: Mon Jan 08, 2007 2:16 pm    Post subject: Reply with quote
Well done again Ash. Is great as always.
Changes made:
Enjoy 8)
Garmin i3
Firmware 3.4
PaulB2005
PostPosted: Mon Jan 08, 2007 3:28 pm    Post subject: Reply with quote
Just gets better and better...
Page 13 of 77
24.041 (01 Apr 26)
