| Author |
larrens Occasional Visitor
Posted: Mon Dec 18, 2006 3:42 pm Post subject: i3 taking ages to get a satellite fix |
My brother's i3 has been taking a long time to get a sattelite fix.
I have an i3 as well, so I put mine (batteries) & his (12v cig lighter cable) (both on v3.20 firmware) into my car.
My unit got a fix after a minute, but his took 5 - 10 minutes.
Does anyone have any ideas what I can do to rectify this, or will a reset work. Alternatively should I send it back to Garmin?
| Back to top |
Posted: Mon Dec 18, 2006 4:37 pm Post subject: |
Where are you doijng this?
In the car? If so, what make and model? Are you stationary or moving when you try? Moving delays the lock on time. If you have a Anthermic windscreen this will block your signal too.
Indoors - probably won't work.
Outdoors - move away from tall buildings etc |
| Back to top |
Posted: Mon Dec 18, 2006 4:38 pm Post subject: |
Now notices.....
| Quote: | | My unit got a fix after a minute, but his took 5 - 10 minutes. |
| Back to top |
philai3 Lifetime Member
Joined: Oct 10, 2006 Posts: 71 Location: Manchester, UK
Posted: Mon Dec 18, 2006 5:42 pm Post subject: |
For comparison purposes, you must make sure that both units have been 'off' for the same time. Get a satellite lock on both units, then power off. Leave for (say) overnight, then switch both on under the same conditions. Mine gets a lock in about 30 seconds under these conditions. One thing that seems to cause a longer time to lock is if the unit is moved whilst off - it might ask if its been moved hundreds of kilometres when you've moved it just a couple of miles! It will then take a bit longer, but, in my case, only a couple of minutes. _________________ Garmin I3 October 2006
Garmin 1310 December 2009
(Firmware 3.2-2.7-3.4-2.7)
Renault Scenic with inbuilt Carminat Tom-Tom April 2013
Renault Clio
Mazda MX5 2010 |
| Back to top |
big_ash Occasional Visitor
Posted: Mon Dec 18, 2006 6:46 pm Post subject: |
| Dont know if it makes any difference but since leaving the batteries in the unit I find that it locks on a lot quicker than without them. I use the batteries just for this reason use the cig adapter all the time. |
| Back to top |
Posted: Mon Dec 18, 2006 10:31 pm Post subject: |
I use rechargeables, and I used to replace them with alkalines whilst charging, in case there was some kind of semi-volatile memory that needed a voltage to keep going. However, after a little experimentation, I've decided it makes no difference, I just take the batteries out, charge them, and put them back. They are quick charge ones, though, only take about an hour. _________________ Garmin I3 October 2006
Renault Clio
Mazda MX5 2010 |
| Back to top |
portman Frequent Visitor
| Back to top |
Posted: Tue Dec 19, 2006 2:28 pm Post subject: |
All I can say is that my unit takes nowhere near the 12.5 minutes quoted on the above website to get a fix after whipping out the batteries for a couple of hours, the implication being that it's not doing a full cold start under these circumstances. The only times it's taken anything like this period is when I first got the unit, and if I roll-back or roll-forward the firmware. _________________ Garmin I3 October 2006
Renault Clio
Mazda MX5 2010 |
| Back to top |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Tue Dec 19, 2006 3:39 pm Post subject: |
never used batteries in my i3 and it got a sat lock within seconds ,every time.... _________________ *************************** |
| Back to top |
| Back to top |
