Pocket GPS World :: View topic - Beginner’s Guide
Beginner’s Guide
Goto page Previous  1, 2, 3 ... 19, 20, 21 ... 31, 32, 33  Next
shaz123456789
PostPosted: Mon Dec 04, 2006 4:31 am    Post subject: Reply with quote
hello im new to the satnav world baught my very own for the first time 3 weeks ago i have the via michelin v4 i havent a clue were to start even looking and installing sofware nevermind installing speed camera sofware. can can some one please help me reguarding installing camera software on to my viamichelin. as sending me to the right web page i need
and possibly easy instructions on how to install i would be gratfull and also is there a free data base or is it that you have to pay a subscription
for our down loads foer the speed camera software thanks
shaz Embarassed
PostPosted: Mon Dec 04, 2006 7:49 am    Post subject: Reply with quote
Shaz, Welcome to the forum, please have a read through the set-up guide which can be found HERE In addition to the installation you asked about a free database, there is no such thing, please have a read through the Subscriptions page for more information - Mike
BJB
PostPosted: Wed Dec 13, 2006 7:01 pm    Post subject: Pocketgps camera data base and EBay auction item Reply with quote
Mike
EBay item number 260062300685 is for a Navman ic 530 which includes the ' ' pocketgps camera data base free UNDER LICENCE then goes on to quote the required fee for updates. Does this sale meet your rules?
Bryan[/b][/u][/i]
PostPosted: Sat Dec 16, 2006 12:48 pm    Post subject: Reply with quote
Hi Bryan,
When I get a minute, I will investigate further, but on the face of it, it seems OK.
Many thanks for taking the effort to report it.
ksb
PostPosted: Tue Dec 19, 2006 8:09 pm    Post subject: Reply with quote
Hi can anyone help me, i have a tomtom one uk version 2
i have downloaded the required files to my computer, but i cannot, move the files to the tomtom map folder, there is no copy paste available , and you cannot drag and drop, does anyone know what i can do, i am using windows xp homee edition thanks
PostPosted: Tue Dec 19, 2006 8:47 pm    Post subject: Reply with quote
When you open the download you need to click "Extract All Files" save the files to a known location before using copy/ paste to get the files where you need them (the map folder of your TomTom One V3) - Mike
AndrewH13
PostPosted: Wed Dec 27, 2006 4:01 pm    Post subject: Reply with quote
Having got all 24 files onto Memory Card map folder manually, I thought I would investigate POI Sync/Edit for future updates.
Rather than have all 24 files available to sync it seems to have a mixture of method 2 - categories and method 3 individual files (ie spec camera individual sppeds not there). So to use, would have to pick what is available in POI Sync listing then do the others manually, being carefull not to select say Specs (all-in-one file).
Any reason for this? Do others use this Sync with separate speed files and if so am I missing something?
ciderapple
PostPosted: Sat Dec 30, 2006 3:23 pm    Post subject: Reply with quote
Thumbs Up Cheers for all the help and a big Ta! to Privateer for the guide to setting up the TT One. Got my TT One v.2 set up now with all the speed camera warnings up and running. Very simple to do and easy to follow - the only tedious bit was activating each warning and assigning a sound, but shed loads better than copping a ticket! Will now pass on my "expertise" to my bro and niece who also have new TomToms.
Cheers guys.
JockTamsonsBairn
PostPosted: Sat Dec 30, 2006 4:59 pm    Post subject: Reply with quote
POIEdit has not supported synching the Camera db since the site became subscription based early this year. Crying or Very sad
Remember that this setup only needs to be done once! :D
Jock
popeyetheace
PostPosted: Mon Jan 01, 2007 7:59 pm    Post subject: Reply with quote
hi. i have just bought a garmin310d and thought i would update the poi's and camera info. subscibed to this great looking web site, downloaded both into a folder in my documents. then tried sending to my garmin with poi loader but cant do it, get a message saying no data files in directory-pls specify a file that contains a .csv extension. also not sure i downloaded the correct camera version. i am not very good with computers so am really stuck. can someone pls help.
PostPosted: Mon Jan 01, 2007 10:04 pm    Post subject: Reply with quote
What did you download?
If you go through the download process and select "Garmin" in the first box and "UK-POI Loader i3, Nuvi etc" in the second, then download, what you get is a ZIP archive called "pgpsw-speed-cams.zip".
This must be decompressed (double click on it and select "extract all") and you should now have the five 'consolidated-by-camera-type' files (and the bitmap icons to go wityh them).
These files ARE in .csv format.
If you cannot see that, do you have file extensions hidden in Windows Explorer (Tools menu / Folder Options / View tab)?
Is POI Loader looking for them in the right place?
Svengali_uk
PostPosted: Thu Jan 04, 2007 2:52 pm    Post subject: Update Query Reply with quote
I set up my TTG last June, with a lot of help from this site. Being partially deaf, I also installed a sound package that gave a loud siren, and which identified the type and speed of the camera for me.
If I now download & install the update, will I lose my sound files? - they took quite a long time to install, & assign all the verbal warnings correctly.
PostPosted: Thu Jan 04, 2007 3:41 pm    Post subject: Reply with quote
Svengali...
It depends on what method you used when you originaslly set up your alerts.
The "old" way was to use a modified "data.chk" file (that's the file that usually does the built in sounds) - so if, when you set up your vocal alerts, they were still called "cow" etc. that's what you used).
Unfortunately, every version of TomTom software needed its own (different) version of data.chk, so if you upgrade (I assume you are talking about the operating software here) then yes you will lose your custom alerts.
However, there is a better way of doing it now - just putting individual sound files in the same place AND with the same name as each of the ov2 datafiles, will give the same results, but will still work with any new software version. For this to work, the files have to be recorded in the Ogg Vorbis (.ogg) audio format.
In your particular case, what we can try, if needs be, is take your data.chk with your alerts as you like them, put it through a utility to strip out the individual alerts and then recode them individually in the format needed for the "new" method.
But an easier solution might be ready-made from member "Mullet"...
I already did, try these.
Ray Flanagan's Liz Whitaker .ogg files for the PSPSW 24 zoned warnings. Renamed, increased volume, preceded by a siren and the missing 20mph/tba files etc are included.
22050Hz file set http://www.yourfilelink.com/get.php?fid=195525
Watch out though, that is a link to a file-sharing site and the first thing you will see are some pictures of "scantily-clad" (I never thought I'd use that phrase!) women.
Svengali_uk
PostPosted: Thu Jan 04, 2007 6:49 pm    Post subject: Reply with quote
Ah! That's interesting. It was Mullet that originally sent me the soundfiles that I used - but for the life of me, I can't remember just how I did it.
The link was: http://www.tomtomsatnav.info/poiw.html , but in my PM he asked for my email address so that he could send me another file - but I can no longer find it.
Does this give you a clue to what I might have done?
grouty
PostPosted: Sun Jan 07, 2007 10:56 pm    Post subject: re installing database Reply with quote
Hi, i did post a question in another area but had no replies. Just thought i would try here. I installed the database on my navman 530 successfully about 8 months ago and everything works fine. I want to reinstall the new database. Do i need to delete all of the old database first from my navman or just load straight over the top. Grateful for any reply
Page 20 of 33
24.034 (25 Mar 26)
