| Author |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15505 Location: Bradford, West Yorkshire
Posted: Sat Nov 18, 2006 1:09 pm Post subject: 19mph, 25mph, 43mph Warnings |
If you get warnings at seemingly strange speeds then this is why:
The maths:
30 mph = 19kph
40mph = 25kph
70mph = 43kph
In POILoader, on the screen where you select the directory where the data files can be found, it also asks 'What units should be used for distance and speed?' Make sure you set this to Feet and MPH. At present yours as Meters and KPH.
Re-upload the camera's and make sure you change the setting! It will remember this setting so you only need to do it once.
MaFt |
| Back to top |
TomDavison Lifetime Member
Joined: Mar 02, 2006 Posts: 384 Location: Bedford, England
Posted: Mon Nov 27, 2006 6:15 pm Post subject: Re: 19mph, 25mph, 43mph Warnings |
| MaFt wrote: | If you get warnings at seemingly strange speeds then this is why:
The maths:
30 mph = 19kph
40mph = 25kph
70mph = 43kph
MaFt |
Not when I went to school.
11.9 mph = 19kph
15.6mph = 25kph
26.9mph = 43 kph |
| Back to top |
Posted: Mon Nov 27, 2006 6:17 pm Post subject: |
| Damm. I used to have a grey import motorcycle with KPH clocks and i never noticed this mistake!!! |
| Back to top |
Posted: Mon Nov 27, 2006 6:23 pm Post subject: |
I think it's the other way round.
Lets assume you set speeds of 30units, 40units and 70 units, thinking you stting MPH as the unit , but you are actually setting KPH. If you now measure your speed in MPH, you get 18.75mph, 25mph, and 43.74 mph. Bingo!!
I'm not sure how Garmin works, but I assume from this that you need to change to MPH from KPH, and then set the speeds to 30, 40 and 70, once you are in mph mode. |
| Back to top |
swing Pocket GPS Verifier
Posted: Mon Nov 27, 2006 6:27 pm Post subject: Re: 19mph, 25mph, 43mph Warnings |
| MaFt wrote: |
30kph = 19mph
40kph = 25mph
70kph = 43mph | ie The speed database has the values 30, 40, 50, 60 and 70 in it - with POI Loader set to KPH it will translate those values as if they were kph speeds, hence the very wrong mph warnings. |
| Back to top |
Posted: Mon Nov 27, 2006 7:23 pm Post subject: |
human error.... doh!
anyway, the thread still kinda makes sense...
i was tempted to edit my post and then delete all yours, but i thought i'd be a big boy and own up!
MaFt |
| Back to top |
Posted: Tue Nov 28, 2006 12:04 pm Post subject: |
| I'm happy for you to edit your post and delete mine - that way it'll be clearer for all new people who come here... |
| Back to top |
Posted: Tue Nov 28, 2006 12:45 pm Post subject: |
but they won't have as much fun then :D  |
| Back to top |
Ayla Occasional Visitor
Posted: Fri Dec 29, 2006 1:35 pm Post subject: |
| MaFt wrote: | but they won't have as much fun then :D  |
It certainly gave me a chuckle! I'm sure they'll figure it out - after all, it's not exactly rocket science is it! We all know that 60mph = 100 kph - don't we? (too many years of living in a country which changed to metric measurement when I was just learning to drive, and totally screwing up my brain!) |
| Back to top |
JockTamsonsBairn Lifetime Member
Posted: Fri Dec 29, 2006 2:17 pm Post subject: |
| Ayla wrote: | I'm sure they'll figure it out - after all, it's not exactly rocket science is it! We all know that 60mph = 100 kph - don't we? | You'd think so, but have you seen how many posts there are complaining that the database doesn't work, because of this problem? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
| Back to top |
orfy Occasional Visitor
Posted: Tue Feb 06, 2007 11:39 am Post subject: |
Right, that explains the error.
Not all of us like to play with the garmins we just want to use them with as little hassle as possible. |
| Back to top |
Scarecrow Lifetime Member
Posted: Fri Jul 20, 2007 12:35 pm Post subject: |
Just remember that if you download and install the new European camera databases, you will need to set POILoader to kmh settings, other wise in an 80mph limit (130kmh) you won't get a warning unless you are doing close to 130mph!!
This means that you won't be able to load the European and UK databases at the same time, as they are not compatible with the same setting in POILoader. |
| Back to top |
Posted: Fri Jul 20, 2007 12:37 pm Post subject: |
If you search the forums there are a number of suggestions for having both mph and kph alerts at the same time - basically you either change the values in one set of files to the other units, or you use the multiple POI Loader upload tricks (not available on all units). _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
| Back to top |
gardenshed Frequent Visitor
Posted: Fri Jul 20, 2007 5:06 pm Post subject: |
| is that a garmin only problem? seems like a biggie to miss if you are in europe 8O |
| Back to top |
inspiredron Frequent Visitor
Joined: Dec 17, 2006 Posts: 302 Location: Ellesmere UK
| Back to top |
| Back to top |
