| Author |
Ricko61 Occasional Visitor
Posted: Fri Feb 02, 2007 12:03 am Post subject: Camera update problem. |
After a right load of rigmorole last month (mostly down to me being thick)I finally managed to get the new system up and running with Liz's voice prompts.
Yesterday I downloaded the latest camera update and the bleedin' bells and whistles are back. I've checked the directory and the ogg files are still there, I've unchecked and rechecked the "warn when near" etc etc, but no good. Bizzarly, all of my favourites and Home destination have mysteriously disappeared as well (though this could be a red herring).
Any thoughts please from you clever people. If I had any hair left I'd be pulling it out now.
Steve |
| Back to top |
Andy_P Pocket GPS Moderator
Posted: Fri Feb 02, 2007 2:45 am Post subject: |
Might you have the same problem as HERE?
If you have accidently added another camera file as well as the normal 24, it will take over with the default bells.
Or have you either renamed the new files or (more likely, renamed the old files, so the file names don't match the oggs any more?
What really helped to solve the problem in that link above was that the guy downloaded a tiny utility called DriveZ so he could post a list of the files in his map folder for us to look at. Could you do that? |
| Back to top |
Posted: Fri Feb 02, 2007 8:57 am Post subject: |
| Thanks Andy. Its possible - I'll have a look tonight. |
| Back to top |
Posted: Sun Feb 04, 2007 12:02 pm Post subject: |
Right finally sussed it out. I've had a look and they all look ok to me (doesn't mean much though).
Thanks for any advice.
_Need_Help.htm
CLINE.DAT
CNAME.DAT
CNODE.DAT
FACES.DAT
Great_Britain.mid
Great_Britain.mms
Great_Britain.pna
Great_Britain-Map.cfg
Licence.txt
lincense.txt
MAPINFO.DAT
Mercedes Sub, United Kingdom.ov2
pocketgps_uk_gatso_20.ogg
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ogg
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ogg
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ogg
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ogg
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ogg
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ogg
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ogg
pocketgps_uk_gatso_var.ov2
pocketgps_uk_mobile_20.ogg
pocketgps_uk_mobile_20.ov2
pocketgps_uk_mobile_30.ogg
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_40.ogg
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_50.ogg
pocketgps_uk_mobile_50.ov2
pocketgps_uk_mobile_60.ogg
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_70.ogg
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_tba.ogg
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_mobile_var.ogg
pocketgps_uk_mobile_var.ov2
pocketgps_uk_redlight.ogg
pocketgps_uk_redlight.ov2
pocketgps_uk_specs_20.ogg
pocketgps_uk_specs_20.ov2
pocketgps_uk_specs_30.ogg
pocketgps_uk_specs_30.ov2
pocketgps_uk_specs_40.ogg
pocketgps_uk_specs_40.ov2
pocketgps_uk_specs_50.ogg
pocketgps_uk_specs_50.ov2
pocketgps_uk_specs_60.ogg
pocketgps_uk_specs_60.ov2
pocketgps_uk_specs_70.ogg
pocketgps_uk_specs_70.ov2
pocketgps_uk_specs_tba.ogg
pocketgps_uk_specs_tba.ov2
pocketgps_uk_temp.ogg
pocketgps_uk_temp.ov2
POI.DAT
Pubs Sub, United Kingdom.ov2
release.txt
Shell Petrol Stations Sub, United Kingdom.ov2
TMCCODES.DAT
TRAFFIC.DAT
TRAFFIC.INC
Volkswagen Sub, United Kingdom.ov2 |
| Back to top |
Posted: Sun Feb 04, 2007 2:15 pm Post subject: |
Hmmm....
You're right, everything looks right to me.
(Apart from some extra .bmps (pocketgps_uk_gatso.bmp, pocketgps_uk_mobile.bmp, pocketgps_uk_specs.bmp) that look like they have been left over from an earlier install of the "consolidated by type" version of the database - you could erase those for neatness, but they won't help your problem).
I'm intrigued by the loss of your favourites and home location, though. As you say, that shouldn't have happened with just a camera database update.
It's ringing alarm bells because it's just happened to a work colleague when he bought the new map (and updated the operating software at the same time ) using Home. But you haven't done any of that have you?
We've not mentioned the reset button yet... Try that?
Also, there is another thing you could try, so long as you've made a good "copy and paste" backup, which worked for another, slightly different problem for someone.
In the preferences menu, is "Reset Factory Settings". I'm afraid I don't have any detailed knowledge of what EXACTLY this is resetting, but it worked! (Obviously the "Warn when Nears" will need setting up yet again though).
Good luck!
Come back with your findings... |
| Back to top |
DennisN Tired Old Man
Posted: Sun Feb 04, 2007 2:32 pm Post subject: |
Old man's stupid question. 8O
Why aren't these four | Quote: | Great_Britain.mid
Great_Britain.mms
Great_Britain.pna
Great_Britain-Map.cfg | all the same name except for the extension? _________________ Dennis
Two of them are obesiting!! |
| Back to top |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10645 Location: Suffolk, UK
Posted: Sun Feb 04, 2007 9:18 pm Post subject: |
The names given are for a V5 GB Map.
Which Software and Map are you trying to use? _________________ Richard
TT Via 135 App 12.075: Europe Map v1165 |
| Back to top |
Posted: Sat Feb 10, 2007 8:47 pm Post subject: |
Wits end!!
I've tried a soft reset, I've wiped the memory card and reloaded it all from disc, reloaded the camera data base and re-done all the "warn when nears". Its still bells and whistles! :x
One thing thats strange though. Last month when I was having all the problems setting it up in the first place, I was getting the same problem as a lot of people on the forum i.e when setting the "warn when near" they still had the option of the cow mooing etc. I had the same problem at the time, but with much fiddling and resetting, the option disappeared and the system worked ok.
Now I don't have that option; its "warn when near", distance, warn only if on route. |
| Back to top |
Posted: Sat Feb 10, 2007 9:04 pm Post subject: |
| Ricko61 wrote: |
Ahh, hold on.. this might well be relevant...
Are you saying that when you go to "Warn when near" it IS skipping the stage where it asks for a warning sound?
If so, the Go is trying to use the ogg, but maybe the oggs are in the wrong format or corrupted somehow.
Two things to try:
1) Delete all the ogg files completely and re-download a new set
Try Without siren
(Right click and "save as..")
If still no luck:
2) Email me one of your ogg files and I'll look at its format and also try it on mine. PM me to get my email. |
| Back to top |
Posted: Sat Feb 10, 2007 9:06 pm Post subject: |
| Ricko61 wrote: | Wits end!!
That's the correct situation for the OGG files to be working - you don't get to choose the warning sound. Are the bells and stuff due to TomTom cameras being alive and well? Have you Disabled them? You should. _________________ Dennis
| Back to top |
Posted: Sat Feb 10, 2007 9:12 pm Post subject: |
There's no TT cameras in his file list above, Dennis  |
| Back to top |
Mullet Frequent Visitor
Posted: Sat Feb 10, 2007 9:40 pm Post subject: |
deleted
| Back to top |
Posted: Sat Feb 10, 2007 11:08 pm Post subject: |
At last thats cracked it.
Thanks guys for all the suggestions and particularly thanks Andy for all your patience and for finally sorting it. Still not sure what happened and how, but downloading the "clean" version did it.
I'm going to back it up now then I'm going to try and get Liz's voice back. No doubt I'll be on here later.
Cheers again.
Steve |
| Back to top |
| Back to top |
Posted: Sun Feb 11, 2007 9:55 pm Post subject: |
Right! Now that this is sorted, one of the other problems is still there. I'm not sure if it should be a new thread, but as it happened at the same time as the update, there might be a connection.
Also (pardon the wittering), this might be a PDA/Windows for Pocket PC issue rather than a "not knowing enough about Tom-Tom" issue.
My favorites, home page and camera settings (warn when near) disappear every time I turn the PDA off! Everything else is ok, but if I reset my home page, enter a favourite or set the warn when nears for the cameras, when I turn the PDA off for a second then turn it back on again, they've all gone.
Any ideas again please? |
| Back to top |
| Back to top |
