Pocket GPS World :: View topic - Garmin POI Loader
Garmin POI Loader
Goto page Previous  1, 2, 3 ... 10, 11, 12, 13, 14  Next
PaulB2005
PostPosted: Sun Dec 17, 2006 10:33 am    Post subject: Reply with quote
Which database did you use?
What settings did you use for POILoader? Try using Express before playing with the settings.
The cameras should alert if you are over their assigned speed limit.
bfc1912
PostPosted: Fri Jan 19, 2007 2:23 pm    Post subject: Reply with quote
Gent's just used POI uploader to load cameras and MaFt's POI's. Copied them onto SD Card as already crashed one unit. When I boot up unit asks if I want to copy them onto it say NO and unit boots up. Do I need to do this in order to make them run? Problem is I can't seem to see them at the moment.
g0plo
PostPosted: Tue Feb 06, 2007 7:38 pm    Post subject: Reply with quote
Hi there, its im agen, the old wrinkley. a question for the experts please.
[I have the i3 with a 512 card and version 9 mapping] when using the POI loader I put all the poi's I need plus the camera database in a folder and upload all together,. it works fine but I would like to know how to separate the database display on the I3 from the " custom " poi's into a separate heading.
or am I shooting at the moon again.? Embarassed
Regards to everyone, I still think its the best thing including sliced bread, but not Christmas cake !! Cheers ... Ben...
Prodriver
PostPosted: Mon Feb 12, 2007 2:13 pm    Post subject: POI Loader/Speed Camera Database......help! Reply with quote
I've just had a Kenwood KNA-G520 installed and, having looked at the Speed Camera database help I downloaded the POI Loader onto my PC.
I then subscribed to the database and downloaded the speed cameras.
According to the forum I should then be able to open the POI Loader which will then recognise the SD Card (inserted in the reader) and then transfer the database to the SD Card.
However, when I double click on the POI Loader file it says it is already installed and won't let me go any further!
I successfully downloaded a software upgrade via SD Card without a hitch but this is frustrating the hell out of me...............please tell me I'm doing something basically wrong!!!
My POI Loader is in a different file location is that why? Rolling Eyes
Nige
Prodriver
PostPosted: Thu Feb 15, 2007 10:59 pm    Post subject: Reply with quote
Is no one able to help? Sad
Nige
maz8209
PostPosted: Fri Feb 16, 2007 11:51 pm    Post subject: Re: Garmin POI Loader Reply with quote
hi have problem where imbeing tolthe wrong speeds wen i detecta camer . any help
maz8209
PostPosted: Fri Feb 16, 2007 11:53 pm    Post subject: Re: Garmin POI Loader Reply with quote
have down loaed camera warnings but i am being given the wrong speed.
any ideas to why ?
thanks
maz8209
PostPosted: Fri Feb 16, 2007 11:56 pm    Post subject: Reply with quote
everything has been switched on , all cameras get detected just that the speed is incorrect . wondering if there maybe a problem with the software
PostPosted: Sat Feb 17, 2007 1:16 am    Post subject: Reply with quote
maz8209 Why three posts?
This is the oldest and most often repeated question on this forum I think Smile
If you ae getting 19mph insead of 30, it's a setting in POI Loader....and you've left it set to kilometers rather than miles per hour (19mph=30kmph).
You just have to start again, click the right setting in the drop-down box and reload all the pois.
more details HERE
jif
PostPosted: Wed Mar 14, 2007 9:08 pm    Post subject: Reply with quote
I have a Garmin i3. I have downloaded the files using the POI loader and they appear to have gone into the sat nav as when i looked in custom points there are 2 files there pocketsgps-uk-pmobile and pocketgps-uk-sc.
There is no warning when i approach a camera even at speed, the proximity alert is switched on but still no joy.
Could somebody please help, do i have some files missing or something not switched on correctly?
Jif
Alsone1
PostPosted: Sat Apr 07, 2007 5:39 pm    Post subject: Reply with quote
Does anyone know if the POI loader works with Vista 64?
I asked Garmin but they didn't reply.
chaddy
PostPosted: Mon Apr 09, 2007 3:09 pm    Post subject: Reply with quote
Hi Recentley purchased Garmin 3i.
I have loaded the poi loader and when I try to run this all its says is not responding.
I have sat at this PC for two days now and cant get it to work.
Your help would be most appreciated.
Chaddy.
PostPosted: Mon Apr 09, 2007 3:21 pm    Post subject: Reply with quote
Chaddy, Welcome to the forum. Have you got the i3 plugged in to a PC mounted USB socket, we have seen other try to use a Hub or USB connection on their monitor which doesn't reliably work. If that doesn't cure the problem can you describe what you see on the i3 screen when plugged in to the PC.
And what opperating system have you got on the PC, Windows XP or something else - Mike
The_Blitz
PostPosted: Mon Apr 09, 2007 8:56 pm    Post subject: Proximity Distance Reply with quote
Having a problem with changing the proximity distance on POI Loader 2.40 BETA.
Using speed zone files.
Audible warnings are working fine.
Changed distance but it doesn't appear to be recognised when I run simulation.
The original distance appears to remain in place.
Any thoughts?
Bye for now.
jif
PostPosted: Mon Apr 09, 2007 9:34 pm    Post subject: Reply with quote
Mike,
Any chance that you could respond to my post above, unfortunately i am still having no joy.
Page 11 of 14
24.041 (01 Apr 26)
