Pocket GPS World :: View topic - Can't add files to POI on my navman.....PLEASE HELP!!!
elainet35
PostPosted: Mon Mar 19, 2007 11:28 pm    Post subject: Can't add files to POI on my navman.....PLEASE HELP!!! Reply with quote
Have extracted the asc files and added them to the poi on my SmartST map, however, I keep getting error message saying invalid files. I have changed them to csv files but still get same error message. I can't get anywhere and have no idea how to contact anyone on this site for help. Can anyone help me out? PLEASE!!!
tonys66
PostPosted: Tue Mar 20, 2007 9:24 am    Post subject: Reply with quote
Note: Newer versions of the software, by default, ask for 'Files of type: CSV Files (*.csv)' You might have to put *.* in the File Name window in order to show the asc files.
If you can't get this to work you can either simply rename the asc files to csv files or you can download the files for Garmin as these will also work.
elainet35
PostPosted: Tue Mar 20, 2007 9:27 am    Post subject: Reply with quote
Hi, thank you for replying. I have already done all this and it still won't work.
tonys66
PostPosted: Tue Mar 20, 2007 9:53 am    Post subject: Reply with quote
Ime not sure but somewhere i read that some of your model when reputting in cams and stuff you have to reput it all in at same time
philpugh
PostPosted: Tue Mar 20, 2007 4:43 pm    Post subject: Reply with quote
What version of SmartST are you running?
Phil
elainet35
PostPosted: Tue Mar 20, 2007 6:00 pm    Post subject: Reply with quote
The version is SmartST desktop 2005. Do you think maybe this needs updating?
Thanks,
Elaine.
philpugh
PostPosted: Tue Mar 20, 2007 6:08 pm    Post subject: Reply with quote
No - it should work with that version I believe.
What is giving the error message 'invalid files' as you state you have loaded them into the POI screen?
Are you actually seeing them (cameras) in the POI screen on SmartST?
Phil
philpugh
PostPosted: Tue Mar 20, 2007 7:49 pm    Post subject: Reply with quote
There seems to be another thread running here with eth same issue as you.
Try the suggestion in this link...
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=53730
Phil
123381
PostPosted: Sun Apr 08, 2007 5:42 pm    Post subject: Reply with quote
Thanks,
Elaine.
Nope smartST 2005 does not need updating, most poi files on this site are pig to use. I found a link to
http://www.getoutguide.pwp.blueyonder.co.uk/poidownloads/index.htm
these are the only poi I can use on my navman icn 610 so should be working for your satnav (my icn610 is a cut down version)
Kind regards
Michael
elainet35
PostPosted: Sun Apr 08, 2007 7:21 pm    Post subject: Reply with quote
Thank you for that, I had given up on this site but will give this a try.
Elaine.
24.041 (01 Apr 26)
