| Author |
exbootneck Occasional Visitor
Posted: Mon Mar 05, 2007 11:17 am Post subject: rotating screen |
| hi. I used this forum to successfully convert my medion 96800 to run tomtom5. while TT is running it is possible to rotate the screen in 90 degree stages. what I'd like to know is this, can the screen be rotated whilst in windowsCE before I actually start tomtom. I've tried to do it in control panel to no avail. any ideas anyone? |
| Back to top |
amhosib Occasional Visitor
Posted: Mon Mar 05, 2007 6:20 pm Post subject: |
I have now installed TomTom v5.21 on many medion units including a mdpna150,as well as 95900, both of which are landscape in orientation.
You select the landsacpe within TomTom by rotating the screen, and it is automatically stored for future use (at least on mine).
TomTom now always starts in correct landscape mode.
Which version of TomTom are you using? |
| Back to top |
Posted: Tue Mar 06, 2007 9:23 am Post subject: rotating screen |
i wasn't going to post a lengthy explanation but i can see that i'm going to have to in order to clarify what i'm up to.
i'm using tomtom 5 on the medion 96800
I know how to rotate the screen when in tomtom 5
i uninstalled t5
i installed tomtom6 but it freezes when i start the programme
only a soft reset gets me out of it
i installed TT6 on my mio P350
TT6 will only start on the P350 if the windows os is in portrait.
if i start TT6 whilst windows is in landscape it freezes.(same symptom)
my thought process is that if i can get the windowsce on the 96800 to rotate from landscape into portrait when i run the TT6 programme may start giving me more upto date maps |
| Back to top |
scottgw82 Occasional Visitor
Posted: Thu Mar 29, 2007 2:54 pm Post subject: |
hi, i have a medion pna 250t, when i get to step 5 and do the soft re set the regedit file appears like you said but go streight back off again, you've got to help me with this its driving me mad!!
thanks,
scott |
| Back to top |
dogsofwar Occasional Visitor
Posted: Fri Apr 27, 2007 9:04 pm Post subject: |
Hi All,
I am runninning TomTom Nav 5 on a Medion MD PNA 175 and if you guys want to know how to make the little bars display how many sat's you are seeing/signal strength...install an app called GAPI, I found it by accident while looking for other software that will run on a Medion, found quite a bit of stuff and the app as mentioned, lost the link but google it and see what you find, after I installed this app everything worked properley in TomTom the sat bars turn blue now when it has a fix and the signal strength is displayed in the display bar, hope this is of use to you guys. |
| Back to top |
ImCrackers Occasional Visitor
Posted: Tue Jul 31, 2007 12:21 pm Post subject: |
| This works well on a mdpna175 but theres a big problem that i cant work out. if you let the battery go flat you loose all tomtom setup you have to do the whole process again. has anyone else had this adn if so can it be fixed ? |
| Back to top |
smifo Occasional Visitor
Posted: Fri Aug 03, 2007 7:44 am Post subject: 210 |
Hi All
Will the tutorial for the 175 work on the 210? I have used the search button, but can't find any specific posts about putting tomtom the 210.
Help always gratefully received.
Smifo  |
| Back to top |
hoodbran Occasional Visitor
| Back to top |
liza283 Occasional Visitor
Joined: Sep 25, 2005 Posts: 6 Location: United Kingdom
Posted: Sun Oct 19, 2008 6:16 pm Post subject: |
| Hi, I've followed the wonderful instruction on how to access Windows CE on the Medion 175 thanks to the chap that posted it. However, not only am I turning blonde by the sec, its now being pulled out by the roots! I copied the tomtom 5 to the sd card using the card reader. but how to get it activated is a mystery to me. Nothing is happening. If someone has an idiot guide on how to install the tom tom please contact me. I succesfully installed tomtom onto an spv m2000. But onto this Medion 175 unit is beyond me. Email me, phone me even! i'm despertate haha |
| Back to top |
Gazdaman Occasional Visitor
Posted: Tue Dec 21, 2010 2:03 pm Post subject: |
| ImCrackers wrote: | | This works well on a mdpna175 but theres a big problem that i cant work out. if you let the battery go flat you loose all tomtom setup you have to do the whole process again. has anyone else had this adn if so can it be fixed ? |
Hi guys, a big thanks for this tutorial, got it working perfectly. But I have the problem listed above, and as my Sat Nav gets older, and I use it less, it always seems to be dead when I come to use it.
Forcing me to put the old Navigon SD card back in, and use the useless Navigon software.
Anyone got any tips, or where to start?
All I really need to do is edit the standard installation so it does the hack on itself when it 'installs'.
Gaz |
| Back to top |
GsiSte Occasional Visitor
Posted: Tue Dec 21, 2010 5:34 pm Post subject: |
| Gazdaman wrote: | | ImCrackers wrote: | | This works well on a mdpna175 but theres a big problem that i cant work out. if you let the battery go flat you loose all tomtom setup you have to do the whole process again. has anyone else had this adn if so can it be fixed ? |
Gaz |
From memory the old Navigon program is stored on ROM where as the hacks that boot to tomtom on the SD card use RAM. The trouble with the RAM is its wiped when the battery goes flat and there is nothing you can do to stop it apart from a new battery. |
| Back to top |
Posted: Tue Dec 21, 2010 11:46 pm Post subject: |
I did wonder as much, as luck would have it I bought a new battery a few hours ago. £8.99 off eBay. Should stave off the majority of the problems.
I also found that I hadn't put the original Navigon install files on the SD card I was storing TTN on. So when the battery died, the entire GPS was rendered useless. At least now in the worst case I'll simply have to use the Navigon software, crap as it is.
Gaz |
| Back to top |
| Back to top |
