| Author |
paul623 Occasional Visitor
Posted: Sat Apr 21, 2007 10:27 am Post subject: c510e setting a start point ? |
c510e V3.2 setting a start point
Hi, at the risk of appearing stupid, can anybody give me a blow by blow
method of plotting a route between 2 points other than my GPS location, seems that when i select a point on the map view and tap start i get the flag, i then select the other point and then tap route it still start me from home (my GPS location)!
Also is the any way of seeing the post code of a destination address shown on the map.
Hope i have made myself clear
Paul |
| Back to top |
Retty Frequent Visitor
Posted: Sat Apr 21, 2007 4:03 pm Post subject: Re: c510e setting a start point ? |
| paul623 wrote: | c510e V3.2 setting a start point
Paul |
Oddly there's no option to do what you want to do in terms of setting a route that doesn't include your current location. Miomap has no option to turn off GPS (although "flyover" mode does this you can't put it to your own use).
The only workaround is to cheat - to block the GPS signal for example by putting your hand over the receiver bloock whilst in a building.
You can't do reverse postcode lookup. |
| Back to top |
Sallyann Lifetime Member
Posted: Sat Apr 21, 2007 5:13 pm Post subject: Re: c510e setting a start point ? |
| paul623 wrote: |
Hi, at the risk of appearing stupid, can anybody give me a blow by blow method of plotting a route between 2 points other than my GPS location
Just go to Settings - General and set Off-route Recalculation to Disabled. Then enter the start and finish points.
Sal |
| Back to top |
Posted: Sat Apr 21, 2007 6:19 pm Post subject: Re: c510e setting a start point ? |
| Sallyann wrote: | | paul623 wrote: |
Sal |
many thanks this works!
but unfortunately the reason I wanted to do this was to check the mileage for proposed journeys from alternative start points, but although i can now do this the mileage to destination is not available in the cockpit view!
Paul |
| Back to top |
Posted: Sun Apr 22, 2007 11:02 am Post subject: Re: c510e setting a start point ? |
| paul623 wrote: | | Sallyann wrote: | | paul623 wrote: |
Sal |
Paul |
No, because as I said in the original response to you you can't set a route that doesn't include your current GPS position without using the cheat of blocking the GPS signal. |
| Back to top |
Posted: Sun Apr 22, 2007 12:00 pm Post subject: Re: c510e setting a start point ? |
Well using the other method it does appear to plot the route , but no distance displayed , could you clarify the purpose of the start tab/button
| Retty wrote: | | paul623 wrote: | | Sallyann wrote: | | paul623 wrote: |
Sal |
Paul |
| Back to top |
Posted: Mon Apr 23, 2007 9:51 pm Post subject: Re: c510e setting a start point ? |
| paul623 wrote: | Well using the other method it does appear to plot the route , but no distance displayed , could you clarify the purpose of the start tab/button
The other method is basically the same as covering the GPS receiver with your hand and then plotting a route from a hypothetical start point to the end point.
One difference is that you don't have to reset the off route calculation to on when you've finished :-)
I'm not sure what you mean by the start tab/button. |
| Back to top |
Posted: Tue Apr 24, 2007 9:36 am Post subject: Re: c510e setting a start point ? |
| paul623 wrote: |
but unfortunately the reason I wanted to do this was to check the mileage for proposed journeys from alternative start points |
Paul, you are trying to do something that the Mio wasn't really designed for. You'll find it much quicker to use Google Maps
http://maps.google.co.uk/maps
Sal |
| Back to top |
| Back to top |
