Pocket GPS World :: View topic - tomtom 6 on to an ipaq 2490
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Aviation / Marine Software
glenjstockton
PostPosted: Thu Apr 26, 2007 10:12 pm    Post subject: tomtom 6 on to an ipaq 2490 Reply with quote
it can be done, if you get an wav error fault
I suggest that you perform a clean reset on the iPAQ and check if the issue persists.
Note: A clean reset clears all user-installed settings, programs, and data, and it restores your HP iPAQ to factory settings. Please backup the data because all data would be lost when you perform a clean reset.
To perform a clean reset and return your HP iPAQ to factory settings:
Press and hold the Calendar(left most button), Power, and Messaging (second button from the right) buttons.
While holding down these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts.
When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Once the Clean reset is completed, without restoring the previously backed up data on to the iPAQ perform the following steps:
Reinstall TomTom program _Install .cab
Do not reboot the iPAQ.
Tap Start_Programs_ File Explorer_Windows
Go to menu_Show all files
Search for file BTCOREIF and delete it
Soft Reset the iPAQ
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Aviation / Marine Software All times are GMT + 1 Hour
24.034 (25 Mar 26)
