Pocket GPS World :: View topic - Destinator 6 camera help needed
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator
tonyjeffrey
PostPosted: Sun Apr 29, 2007 5:13 pm    Post subject: Reply with quote
i have a destinator 6 downloaded speed cameras speed cameras ok mobile camera i get a warning change name.also i need sound voice foe camera`s please help
regards tony
PostPosted: Sun Apr 29, 2007 5:19 pm    Post subject: Reply with quote
Tony, I have moved your post to a location where it will get an answer from a user of the same software, I don't use Destinator myself so I cannot offer additional assistance, Welcome to the forum by the way - Mike
bbkoz
PostPosted: Sun Apr 29, 2007 9:42 pm    Post subject: Reply with quote
regards tony
What do you mean that you take a warning change name?Could you be more specific?
tonyjeffrey
PostPosted: Wed May 02, 2007 6:15 pm    Post subject: Reply with quote
bbkoz wrote:
regards tony
when i downloaded the speed camera into my destinator gatso-mobile ok pmobile-redeye get a message warning name not known thus they will not work.
i have also tried installing the cameras off the cd that came with it they downloaded ok on screen it just says-sc but i do not get a voice warning with any of them.
i am new to this so any help would be gratefully received.
thanks tony
bbkoz
PostPosted: Fri May 04, 2007 2:26 am    Post subject: Reply with quote
in favorites can you see the speedcameras?If so you are ok.To have voice for every speedcamera,you will need to have a wav file with the same name of speedcamera.You have to put this in destinator\voice\all folder
PostPosted: Fri May 04, 2007 6:51 am    Post subject: Reply with quote
If you need some pre recorded wav files you can download the ogg files which we use on TomTom and Route 66 from This Page, then use Audacity to save each file as .wav format - Mike
tonyjeffrey
PostPosted: Fri May 04, 2007 5:03 pm    Post subject: Reply with quote
thanks for the reply but i still get stuck.i can see the cameras in favorites but i get the wav file to the console-favorite importer press convert it then say`s 9 records loaded -file created-count of bad recordings=579. and the download button does not work. the file name is pocketgps-uk-sc the speed cameras name is also pocketgps-uk-sc. you say i have to put this file into destinator\voice\allfolder/[quote] but i don`t have a clue where to find this. regards tony
bbkoz
PostPosted: Sat May 05, 2007 9:43 am    Post subject: Reply with quote
What is your device?You must copy manually the files to the folder i have said not from the console.In many devices the path is destinatorapps\destinator\voice\all in storage card or main memory.
tonyjeffrey
PostPosted: Sat May 05, 2007 2:42 pm    Post subject: Reply with quote
my device is a compasseo 600-destinator 6 year 2006
bbkoz
PostPosted: Sun May 06, 2007 8:51 pm    Post subject: Reply with quote
i dont know this device but i suppose that destinator is installed to sd card.Can you see via active sync what folders do you in your sd card?
tonyjeffrey
PostPosted: Sun May 06, 2007 9:49 pm    Post subject: Reply with quote
on the sd card this is what shows folder ukireland and nbo file G200Eboot-07
2006A
hope this will help i am at a loss and getting no where
tonyjeffrey
PostPosted: Tue May 08, 2007 2:42 pm    Post subject: Reply with quote
2006A
hi sorry to keep troubleing you but i have found the files----active sync then explore\ file destinator app\destinator\voice\all i then drop & drag the wav voice alert pocketgps-uk-sc to the \all file\ press copy. the alerts pocketgps-uk-sc are the same name as speed cameras as i downloaded the single file cameras.then i go back to my destinator my favorites where the speed cameras are but i still have no alerts any help would be great.
regards tony[/quote]
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator All times are GMT + 1 Hour
23.103 (15 Oct 25)
